Gen5DIY
Old 05-31-2011, 05:29 PM   #29
Devryn17
Suffers Fools Poorly
Devryn17's Avatar
Drives: 2010 SS/RS, CGM w/ Silver Stripes.
If you have an air leak, you should be able to hear it.
Stupid simple question: Have you checked for a fouled plug, or have you made sure you have the right gap/hot for your car with your supercharger?
2010 2SS/RS, CGM w/ silver stripes. Hurst Shifter, long tube headers, full exhaust, CAI, tune. SAE 407 RWHP/402 RWTQ
Momma didn't bronze my shoes, but when I turned 16 I inherited a lead foot.
Devryn17 is offline   Reply With Quote
Old 05-31-2011, 05:31 PM   #30
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Originally Posted by Speedy1975 View Post
Are you seeing any CEL codes? Typically with any VAC leak you'll get a CEL especially if it's bad enough to cause the engine to idle erratically.
Is it just a bad idle (erratic) or are you sure it's a true miss of the engine?
Did you post up video?
Oh, ya. I had gotten the random misfire code. P0300
Have changed all the plugs.
Old 05-31-2011, 05:33 PM   #31
Devryn17
Devryn17's Avatar
You're certain they're the right plugs and that they're gapped right? You didn't drop one or bang one and mess up the gap? I've done this, and had a very similar problem.
Old 05-31-2011, 05:35 PM   #32
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
i will tell u bro go get a smoke machine and do that u will find the leak if u have one... only way to go !!.. GOOD LUCK
Whipped416 is offline   Reply With Quote
Old 05-31-2011, 05:37 PM   #33
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
Have the wife take a look and see if she can find anything?
You said Post it and you'd try it!
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 05-31-2011, 05:43 PM   #34
PoleCat2SSRS2010
R6P Marketing Lab Rat
PoleCat2SSRS2010's Avatar
Drives: 2015 ZL1 for weekends mostly
Did this all start after installing the bloser?
Fuel quality? did you try bumping up the octane?
Misfires are sometimes the basics. check all the plugs plug wires and coils for proper condition, a cyinder leakdown test and compression test, bad valves and/or seats can cause the same misfire/surge effect.
Is this at low rpms or all rpms or mid to high rpms? High cyclinder pressure due to boost can require a hotter spark than the OEM can provide. High compression/pressure engines need hotter spark to keep the fire going on the plugs.
Just throwing out ideas but stay with the basics before eliminating the deeper harder to solve areas.
PoleCat2SSRS2010 is offline   Reply With Quote
Old 05-31-2011, 06:10 PM   #35
PQ
Booooosted.
PQ's Avatar
Possitive. I actually bought 8 new plugs. TR6 plugs. One of them was bad, or I broke it inadvertently. When I changed them it was misfiring much worse. So it gave off a code. Cylinder 8 misfire. So I moved the number 8 cylinder to the number 1 spot and the 1 to the 8 spot and the code said misfire cylinder 1. Went and bought a new plug and put it in 1 and it ran fine.
Fine being the way it did before. Gapped them correctly yes. Was very maticulous in doing so.
I suppose I should.
Sounds good to me. lol
Originally Posted by PoleCat2SSRS2010 View Post
Did this all start after installing the bloser? Yes.
Fuel quality? did you try bumping up the octane? I let Vengeance set it.
Misfires are sometimes the basics. .... a cyinder leakdown test and compression test, bad valves and/or seats can cause the same misfire/surge effect. This is the most unlikely so will be last. It only reveals bad news if it's the culprit. lol
Good stuff.
Only low RPMs are doing it. High RPMs are either not doing it, or are not detectable
Old 05-31-2011, 07:24 PM   #36
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
What are your fuel trims doing? Are they showing a vacuum leak?
HufferSS is offline   Reply With Quote
Old 05-31-2011, 07:39 PM   #37
CMORGAN
I HAVE GREAT RESULTS WITH SMOKE MACHINE IT SHOWS OFF AND YOU CAN PRESSURIZE FOR LEAKS AS REQUIRED
CMORGAN is offline   Reply With Quote
Old 05-31-2011, 07:52 PM   #38
PQ
Booooosted.
PQ's Avatar
I don't know. Tuner didn't tell me.
He just said I have an air leak. He tuned it for the proper trims. That's all he said. And he told me I have an air leak.
Ok. Meet me at the shop.
Old 05-31-2011, 08:19 PM   #39
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Do you have a scan tool? Plug it in and see what is up with the O2 readings and the fuel trims. If you are getting unmetered air into the system then your O2 should be reading lean and the computer should be adding fuel to enrich the mixture.
Old 05-31-2011, 08:22 PM   #40
PQ
Booooosted.
PQ's Avatar
I left it at Vengeance for Mike to put my tune on.
Old 05-31-2011, 09:01 PM   #41
Speedy1975
FASTER!
Speedy1975's Avatar
Drives: Dodge Challenger, 2SS Camaro
Ok. Random misfire is nothing to play with on a supercharged car. I take it that's not happening now? No more codes?
I'd like to see some logs from your scan tool. The fuel trims being mentioned can point us in the right direction if there is a vac leak. Like was mentioned, if un-metered air is entering the system, the ECM will try to compensate for it by throwing fuel at it. You should see very positive fuel trims.
Did you ever have a canned Magnuson tune in the car? If not can you load it and see if the results are the same?
Were the plugs you took out of the car in there with the supercharger installed and this problem occurring? If so, take close up pictures of the tips of the plugs and post them up for us to see.
I'm not convinced it's an air leak.......yet. I'd expect to see high idle with an air leak, not a hesitation like your showing in the video.
Take some video up around the engine bay...specifically around each head and post that up as well.
Finally, 6lbs of boost or ?
-Speedy
2016 Go Mango Challenger Hellcat (PB E.T. TBD)
2016 Hyper Blue 2SS Camaro (PB E.T. in 1/4 Mile 12.093 @114.43MPH bone stock)
Speedy1975 is offline   Reply With Quote
Old 05-31-2011, 10:06 PM   #42
epstein
Drives: SS/RS
Send a message via AIM to epstein
get rid of those plugs......put platinums back in and watch.
epstein is offline   Reply With Quote
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ AutoAgenda Exterior Parts & Accessories 14 02-06-2013 08:43 PM
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 04:34 AM
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 08:26 PM
Cold Air Intakes 2010 Camaro Blowout! K&N | AIRAID | SLP | Best Price Guaranteed! PM AutoAgenda V8 Bolt-Ons & Tunes 47 01-12-2011 12:35 PM
