SDTW Custom Wheels & Tires
Old 05-31-2011, 10:42 PM   #43
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Originally Posted by Speedy1975 View Post
Ok. Random misfire is nothing to play with on a supercharged car. I take it that's not happening now? Never got a code with a load. Only when someone reved it real hard a few times, or when the wheels broke loose if I gassed it wot from a stand still. No more codes? Not yet. But haven't had a code in forever.
I'd like to see some logs from your scan tool. The fuel trims being mentioned can point us in the right direction if there is a vac leak. Like was mentioned, if un-metered air is entering the system, the ECM will try to compensate for it by throwing fuel at it. You should see very positive fuel trims.
Did you ever have a canned Magnuson tune in the car? Yes. If not can you load it and see if the results are the same? The results were the same.
Were the plugs you took out of the car in there with the supercharger installed and this problem occurring? Yes. I just replaced them a few weeks ago. If so, take close up pictures of the tips of the plugs and post them up for us to see. See below.
I'm not convinced it's an air leak.......yet. I'd expect to see high idle with an air leak, not a hesitation like your showing in the video.
Take some video up around the engine bay...specifically around each head and post that up as well.
Finally, 6lbs of boost or ? 7.5 lbs of boost.
I'll have to get the video tomorrow.
Originally Posted by epstein View Post
get rid of those plugs......put platinums back in and watch.
They were already in.
Old 05-31-2011, 10:52 PM   #44
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
Car still in atlanta?
JLE58 is offline   Reply With Quote
Old 05-31-2011, 11:21 PM   #45
Speedy1975
FASTER!
Speedy1975's Avatar
Drives: Dodge Challenger, 2SS Camaro
Ok, that's three plugs. I wanna see all 8 that came outta the car. Those three look good. Gap's a bit wide for a blown car, but burn pattern looks fine.
What gap are the new plugs set to? I'm on 12psi of boost and gapped mine to .032 if memory serves.
The gap won't explain your issue since it's happening at idle, but you do want to tighten the gap just a bit on a supercharged car to keep the spark from being blown out by the boost.
Lemme see all 8 plug tips and we'll go from there.
-Speedy
2016 Go Mango Challenger Hellcat (PB E.T. TBD)
2016 Hyper Blue 2SS Camaro (PB E.T. in 1/4 Mile 12.093 @114.43MPH bone stock)
Speedy1975 is offline   Reply With Quote
Old 05-31-2011, 11:47 PM   #46
PQ
Booooosted.
PQ's Avatar
Nope. Drove it home.
Ok. those pics are from the day I did it. lol
Old 06-01-2011, 12:13 AM   #47
PQ
Booooosted.
PQ's Avatar
Old 06-01-2011, 06:10 AM   #48
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
My opinion is that you are not going to get anywhere until you get a scan tool on it and a smoke machine to find the leak assuming there is one.
You can chase Gremlins like this for a month and not find it.
HufferSS is offline   Reply With Quote
Old 06-01-2011, 08:01 AM   #49
n2oSS
n2oSS's Avatar
Drives: 2010 SS2 Camaro
really sounds like its missing a spark. This happened to me when i put my new wires on, one wire was just not all the way snug.
I have seen vacuum leaks cause cars to idle ruff but usually the idle will be so jerky that the car will die.
Another thing you can do if your thinking leak. There are mics that listen in small areas where you can follow your lines and listen for the hiss.
Vacuum leaks can be the lines or even the valley gasket.
Mods:
Dynatech Headers, High flow cats, MSD 8.5 wires, magnaflow bullits, Halltech intake, SCT tuner,
maggie tvs 2300, Jannetty Tune, BMR driveshaft safety loop, Pfadt drop springs, Pfadt rear trailing arms, Pfadt rear tie rod, ACT Twin Disc Clutch, DSS Aluminum Driveshaft.
Appearance Mods:
AAC Concept Sidemarkers, P13W Plasma LED Bulbs, Iforged Classics 20".
Next Mods:
Cam and Fuel System.
n2oSS is offline   Reply With Quote
Old 06-01-2011, 10:15 AM   #50
Speedy1975
FASTER!
Speedy1975's Avatar
OK, plugs look fine, so I don't think there's problems with that.
I agree that a scan tool needs to get on the car and check out some parameters.
Hook the tool up and let the car idle.
Take a look at long term and short term fuel trims. If they're very positive that could indicate a vac leak somewhere.
Take a look at O2 sensors make sure they're enabled and reporting properly.
Take a look at the timing, specifically when the hesitation occurs. See if when the hesitation occurs you see a quick dip to negative timing.
Also take a look at the TPS setting when the hesitation occurs as well to see what it's doing.
Also, do you have a catch can on the car? If so, does it fill up with oil more quickly than normal? Double check the PCV valve make sure it's orientated properly. Had a friend put one in backwards once and have some weirdness.
I'd also do the smoke machine as well.
I'd also check with Jessika at Magnuson. She's a GREAT gal and loves to help. She's also very knowledgeable mechanically, and if she doesn't know she has resources to ask. They can point you to some common areas on the blower to check for this type of issue just to cover all the bases.
-Speedy
Old 06-01-2011, 10:30 AM   #51
anthonyj9h
"First There"
anthonyj9h's Avatar
Drives: 2010 camaro 2ss
so i hate to be the barer of bad news but misfires happen because these reasons. plug which you have changed, coil pack, coil, or valves arnt opening and low compression, bad gas, or vac leak....i just recently had my lifters replaced and it went bad on me again because the lifter tray had wore down and the lifter had turned sideways and started beating down on the cam and wore it down and that made the cam bad....p0300 is multiple misfires not just one need to look deeper and its unfortunate....i dont know if we able to get it but gm has a new software call gme...check the injectors see if they are firing as well might want to take it to a dealer and see if they can find whats wrong
Originally Posted by jewel25 View Post
No one wants to be like aytard. He is a douche for eggs.
it is written......
anthonyj9h is offline   Reply With Quote
Old 06-01-2011, 10:41 AM   #52
Jessika
Drives: Anything Blown
:blush: Thank you. I wish we had answers on this one. But I think this thread has covered all the bases that we would suggest.
Jessika is offline   Reply With Quote
Old 06-01-2011, 10:54 AM   #53
Speedy1975
FASTER!
Speedy1975's Avatar
I don't think it's anything super serious, as the plugs tell the tale and they looked a OK to me.
Misfires are a problem if they occur with any regularity, but he's not reporting that as an issue any longer. That could have been (and likely was) occurring because the blower was blowing out the spark since it happened on a hard rev of the motor. Like I said on forced induction cars you wanna tighten the plug gap a hair.
Jessika you are my girl!
-Speedy
Old 06-01-2011, 11:37 AM   #54
PQ
Booooosted.
PQ's Avatar
Ok. I'll try and find a diagnostic shop. Mike, at Vengeance, had it all hooked up over the weekend. He is pretty thorough from what I hear. He assured me that everything is reading optimaly. Before I left Atlanta, I asked if they couls set it back to where it was before I got there or at least turn the idle up so it wouldn't die on me. Previously it wasn't. They said they would, but that it would be wrong. My car wasn't set right before. But probably to keep the car from dying. I can tell you there is noticeably less carbon funk on my exhaust tips since Vengeance tuned it.
So my decisions were to find leave the tune the same and find the problem, or set it back to a richer and wrong tuning to buy more time. I chose the first one. Car still drives great. Just will die at low idle in gear.
Not gonna buy any more diagnostic tools. Except a cylinder temp gun. I want to check the cylinders as they idle to get the temp. It could tell me which one is misfiring if any. But the rest is gonna be left to a shop. I'll ask the shop if they have mics.
What type of scan tool are we talking about? Vengeance did that. Only thing he said was cylinder 8 was the only one that read a mis at all and that it wasn't hardly anything. Problem for me here in Mobile, AL is I can't find anyone who knows what they are doing as far as this stuff goes. They can hook it up, and look at it, but they don't know what to look for. And so if they see it, they don't know what to do. I've had 3 or 4 shops take a look now and none can figure it out. Everyone wants to run from the supercharged car.
My dealer will change the oil and that's it. They won't do anytning else. Neither one. I've asked. I even explained to them that I understand there is no warranty, I just want them to do the work, and they still say no.
I'll get started on the stuff I can try tomorrow night. Then Friday take it to a shop. Just been busy as hell. I got my catch can and breather in yesterday. I'm not sure if I should wait to install it, or do it now. The PCV thing you said is interesting. Maybe I'll just do the oil breather cap first.
Old 06-01-2011, 11:41 AM   #55
anthonyj9h
"First There"
anthonyj9h's Avatar
so your dealer is turning down free labor? wow id run that up warranty or not its still a gm car and dont know if legally they can turn you away from that ill ask jeff
it is written......
Old 06-01-2011, 11:41 AM   #56
PQ
Booooosted.
PQ's Avatar
Ok, headed to work. Had to get an oil change this morning. Gonna stop and get some seafoam and try it in the gas tank. Maybe a fouled injector. Can't hurt.
No, Jessika, I won't run it through the blower.
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ AutoAgenda Exterior Parts & Accessories 14 02-06-2013 08:43 PM
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 04:34 AM
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 08:26 PM
Cold Air Intakes 2010 Camaro Blowout! K&N | AIRAID | SLP | Best Price Guaranteed! PM AutoAgenda V8 Bolt-Ons & Tunes 47 01-12-2011 12:35 PM
