JUICEDMOTORSPORTS
Old 03-08-2009, 11:56 AM   #1
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Found this on COMP Cams
Hi found this on GM High Tech Performance site.
COMP Cams - LS3/L92 Rocker Arms / L92 Camshaft / F.A.S.T. LSX-R Intake Manifold
Comp Cams always comes out with some unique performance items, and this year was no disappointment. The LS3/L92 owners will be happy to know that there is an adjustable 1.7 ratio rocker arm to replace the factory cast offset rocker arms. The L92 camshaft kit was designed to work with the variable valve timing system found in those engines. This same VVT technology will also be found in the automatic transmission equipped 2010 Camaro SS. The biggest news from Comp Cams is the F.A.S.T. LSX-R composite intake manifold, designed to work with a 102mm throttle body for LS3 and L92 engines. This intake manifold is a modular design, with removable individual runners that can be altered or shortened by engine builders to custom tailor them to the engines they are feeding.
COMP Performance Group, 3406 Democrat Rd., Memphis, TN 38118; (800) 999-0853; www.compcams.com
Old 03-08-2009, 12:00 PM   #2
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
read about that in the GMHTP mag
good stuff
I piss excellence
and fart awesomeness
Old 03-08-2009, 12:26 PM   #3
2SSRS@Gen5diy
That is how i found it, All so found this today for info on how the cam phasing works
http://www.gmhightechperformance.com...all/index.html
good stuff
Old 03-08-2009, 02:37 PM   #4
CamaroSpike23
Truth Enforcer
Awesomeness
I piss excellence
Old 03-09-2009, 01:06 PM   #5
1_2Many
1_2Many's Avatar
Drives: 2008 Suzuki SX4
I like that intake...I was thinking about this last night...they say after putting on CNC'd heads and cams the only thing holding the LSX back is the stock intake manifold. And it looks like Comp is addressing that, but they have these "tunable" runners...well why doesn't someone just make an old TPI LT1 style intake that has "on the fly" adjustable runners? I just picture the large manifold being able to raise and lower and having the runners shorten or lengthen by telescoping...get my drift?
We are the early orderers...we are GM's voluntary guinea pigs and their free source of feedback. How will we be thanked?
1_2Many is offline   Reply With Quote
Old 03-09-2009, 04:08 PM   #6
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
I wish I knew half the stuff you guys do about mechanics. I'm usually as lost as Elton John in a strip club when it comes to motors and stuff. :(
Old 03-09-2009, 05:44 PM   #7
Chewy
My boredom isn't safe
Chewy's Avatar
Drives: 2010 SS Camaro
Send a message via AIM to Chewy Send a message via MSN to Chewy
LOL
personally i've only learned from either A. fixing it when it broke or B. modifying it.
if i havn't done either of those i don't know too much about it lol.
Chewy is offline   Reply With Quote
Old 03-09-2009, 06:05 PM   #8
CamaroSpike23
Truth Enforcer
not a bad idea, but I would imagine that the intake would need its own tune to change the runner length depending on the powerband of the motor. not to mention it would need to have pliable mounts for the runners to mount to the heads to adjust for the angle of the runner as the intake plenum was raised or lowered. now if you were to do an individual runner setup, that might be easier to run adjustable (on the fly) runner lengths.
dunno... ill look into it tho.
wow.... thats awesome...
I piss excellence
Old 03-09-2009, 06:49 PM   #9
spd98
Drives: had a goat
none of this is new. They are simply listing parts that have been available for a bit together.
spd98 is offline   Reply With Quote
Old 03-09-2009, 06:59 PM   #10
1_2Many
1_2Many's Avatar
Yeah let me know if you see any potential in this. There are many cars that use variable length intakes right now, even the GM LZ9 3900 V6.
Old 03-09-2009, 09:21 PM   #11
CamaroSpike23
Truth Enforcer
well aren't you just ants at a picnic.
I piss excellence
Old 03-09-2009, 09:24 PM   #12
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
Originally Posted by Chewy View Post
LOL
I'm kind of in the same boat cept for a little twist ... "I've only learned from eaither, A. fixing it after I broke it... or B. modifying it to the point it breaks.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 03-09-2009, 10:26 PM   #13
Chewy
Chewy's Avatar
haha, nice.
"If its not working right, force it....if it breaks, it needed replacing anyways"
Old 03-10-2009, 12:02 AM   #14
toehead93
Drives: 2014 2SS/1LE
2 classic quotes right there.
So I really want to see a cam only comparison between the LS3 and L99. Does the G8 GXP A6 have VVT/AFM? I'd like to see a real comparison between an equivalent cam on an LS3 (non-VVT) and an L99 to see the difference in HP/torque,
toehead93 is offline   Reply With Quote
I found Lou! Is it destiny? VJCamaro 5th Gen Camaro SS LS LT General Discussions 6 02-21-2009 10:37 AM
For the L99 Hesh Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 38 01-11-2009 12:44 PM
MSRP or Below dealer in Cali found Mindz USA - California 13 10-13-2008 11:05 PM
thinking about getting a lt1 here is what i found lil_red_v6 4th Generation Camaros 1 06-03-2008 01:16 AM
Camarospike23: found your twin KILLER74Z28 4th Generation Camaros 16 03-01-2008 10:54 PM
