SDTW Custom Wheels & Tires
Old 06-01-2011, 07:08 AM   #1
Junkman2008
"Detailing Devil Dog"
Junkman2008's Avatar
Drives: 2001 Corvette Coupe
Sooo... I Wrecked My Corvette...
( A bunch of folks here have been following this thread over on another forum so I thought that I would just post it here also. Quite an adventure it was... )
... and it wasn't pretty either.
I went all NASCAR and taped it up so that I could drive in home.
This is why I couldn't pursue the guilty party.
Here's what happened. It was 0-dark thirty at night and I was rolling at around 80 through the mountains of Chattanooga, TN. I was coming down a bridge when this semi threw a retread. I had a concrete barrier on my left and right and was going to fast to swerve so I grabbed the steering wheel with both hands just in time for the impact. The car shimmied and I immediately pulled over. I knew it was bad, I just wasn't really wanting to see how bad.
I got out of the car and looked at it and just stood there in disbelief. Semi was long gone and there I was in a little shock.
The insurance company wanted to put the car back to stock and raise my rates but I wasn't going to have any of that. So I told them to go screw themselves and I went shopping for a new provider. In the mean time, I'm fixing the car myself and this thread will chronicle the experience.
I have already started ordering the parts I need thus far. A new Tiger Shark fascia from Starcraft (by way of J.W. Motoring), a new fender and a new wheel housing. That was over $2000 for those three parts alone.
We're just getting started.
Okay, here are some updates!
Since the inner fender housing was damaged beyond repair, it had to come off the car. This was not a fun time as the inner fender is glued to the frame.
You can see how it is glued in this picture.
The horns were all finagled and bent every which way. I straightened one out. Check out what is left of my fog light.
Test fitting the new inner fender.
Prepping the new bumper.
Test fitting the fender and bumper:
What's left of my fog light...
I finally got into the hood and found out that the fiberglass wasn't cracked, thank God. It was just the paint that was damaged so I got that knocked out. I also got my alignment all together so all of my seams look great.
Finally got the inner fender in place and glued to the frame. That is an adventure unto itself. I don't wish that on nobody. :(
It appears that my skids were slightly bent and I darn near crapped on myself trying to pull them straight. I finally unfangled my horns too. I am going to replace my turn signal sockets while the bumper is off and redo my fog light wiring. I'm also going to replace my high beam 4300 HID's with 5000's. I'll probably do away with that 197 bulb. I don't like how it matches with all my HID stuff. The 197 bulb is the one that is illuminating the inside of my high beams in this picture.
Tomorrow, I go get my paint. I should have it primmered and ready to paint by this weekend but I have to do a detail clinic in Texas so I'll wait until next week. I'm going to have to do a lot of clean up after all this is done. My hands will probably be worn out after all the buffing I'll have to do too. I want to make sure that every drop of orange peel is out of the paint so there will be a lot of wet sanding and clear shooting in order to match the undamaged paint on the car.
I am going to paint the entire dog house and blend into both doors. I am not going to chance having any unmatched paint lines.
I finally got all the body work completed and laid my primer and paint.
Halfway decent for a "brutha' in his friend's garage production" (my friend has the air compressor I needed)!
Now comes the fun of wet sanding all the orange peel away. This is as much fun as claying, another arm burning activity. I'm starting with 2500 and working my way through 3000. I'll then re-clear everything and go back again with 3000. I'll then re-clear again and it will be slick as snot, with plenty of clear on the car.
My first clear, wet sanding and buffing...
In progress...
And the saga continues...
Well, I finally got all the headlight wiring figured out and repaired. Everything is nice and bright again. First, my halos or "angel eyes".
Then the high beams, which I changed over to HID's...
And the low beams...
Now here's something that you have to consider if you are a C5 Corvette owner and decide to goo all HID's with your high's and low beams. When switching from low to high, the high beams need a few seconds to reach their correct brightness. That means that when you first switch over, you'll practically be driving in the dark!
This of course is not good. Thus, I needed to make sure that my low beams stayed on whenever I switched over to my high beams. This can be done by what is known and the "4 on or high four" mod. It can easily be done by changing the circuit design in the following manner.
Now I have enough light output to land a 747!
Next, I installed the brake cooling ducts...
Then came the fun part. Installing the bumper was an adventure to itself because you had to keep the fog lights and brake ducts in place as you did the install. This was a PITA! I must have spent 3 hours trying to get that darn thing back on!
After getting the bumper on, I kid you not that I spent about 6 hours trying to get the alignment perfect. There's obviously a trick to it at the factory and trust me, I don't know the trick. Thus, I had the fun experience of learning it. I have it presentable right now, but I know I'll spend a couple more hours messing with it again. At least it's straight.
Next, the lights went back into the car...
I still need to enclosed the headlights with their shrouds and add the covers but hey, that was 18 hours worth of work that you just looked at! :eek:
Well folks, the "Junkmobile" is rolling again! I want to thank all the well wishers in this thread and all those who jumped in just to have a look. I must say that I am very happy about the way it turned out, much better than any dealership could have done. My alignment of the body panels is better than it was at any point. I still want to tweak it a bit but hey, I'm always trying to go for perfection.
The first thing I needed to do was get her back into the garage and put a 2-bucket wash on her.
After that, I took her out for the post-wreck cruise.
Now I have a lot of detailing to do to the paint and engine compartment but hey, that's what I do. At least I can take advantage of the summer weather now. Total cost for the repair was around $3100 with me providing the labor and food for my buddies. It's the small things that nickle and dime you to death. I am not looking forward to ever having to do this again!
The Junkman
"Marines - Making the other guy die for his country for over 200 years."
Junkman2008 is offline   Reply With Quote
Old 06-01-2011, 08:24 AM   #2
Stex
Drives: 67 goat, 69 goat ram air III
Glad to hear your ride is back in shape. Looks great and that is a lot of work to do it right. I know of two small, two guy etc., body shops that do high end repairs. They may have got it to your level of satisfaction BUT you would have blown by $3,100 so fast you would still be spinning like a top.
Enjoy your good work and may no more may-pop retreads find you...
Stex is offline   Reply With Quote
Old 06-01-2011, 08:32 AM   #3
Junkman2008
Originally Posted by Stex View Post
...They may have got it to your level of satisfaction BUT you would have blown by $3,100 so fast you would still be spinning like a top.
You ain't never lying! I painted the bumper and the other fender twice because I wasn't happy with it. I could have spent a fortune if I had a shop do everything I did.
Old 06-01-2011, 09:14 AM   #4
Dr Jkel
and MR. HYDE
Dr Jkel's Avatar
Drives: 2010 2SS RJT/BLK 6Spd Man
The good thing about it is that you were knowledgable and skilled enough to do it yourself. It looks Great.
Now I know where to go when I have issues
MUSTANG...Like Bringing a Hot Dog to a Steak Dinner....There is no comparison.
Dr Jkel is offline   Reply With Quote
Old 06-01-2011, 09:22 AM   #5
Junkman2008
Get away from me John.
Old 06-01-2011, 09:29 AM   #6
Dr Jkel
and MR. HYDE
Dr Jkel's Avatar
I have mapquest and GPS so you are kinda stuck Knock Knock....
Old 06-01-2011, 09:31 AM   #7
Junkman2008
Check Google Earth. There's a moving van in my driveway!
Old 06-01-2011, 09:33 AM   #8
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Glad to see you got her back on the road. How many man hours did that take?
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 06-01-2011, 09:58 AM   #9
Dr Jkel
and MR. HYDE
Dr Jkel's Avatar
You can run but you can't hide
In all seriousness I am glad you got your baby fixed up.
Old 06-01-2011, 10:03 AM   #10
toesuf94
toesuf94's Avatar
Drives: THR #11 E-force supercharged
Send a message via MSN to toesuf94
You da Junk Man!
Great work!
Cars and women are both going to give you problems...but you can pay somebody else to fix your car!
toesuf94 is offline   Reply With Quote
Old 06-01-2011, 10:15 AM   #11
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
Seriously I cant believe no one has said this yet, especially having watched the Junkman's videos, that will buff out!!!!! Some fine machine polish and swirl/haze remover you are goo to go!!!!!
I crack myself up!
I am glad you are ok JM and I am glad your wheels are back in one piece.
That was a very impressive write up.
Cheers
K
Moriartii is offline   Reply With Quote
Old 06-01-2011, 10:18 AM   #12
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
Damn!!!! That's a pretty good fix with just a Flex and PC!
Old 06-01-2011, 10:38 AM   #13
CamaroKid300
ace5.org
CamaroKid300's Avatar
Drives: 2012 2SS/RS LS3
:troll:
NightOwl RGB Halo Kit V2, Kooks 1-7/8 LT Headers, Cam Motion Cam, CAI Intake, Catless Midpipes, Borla ATAK Catback, 35% Tint, Vinyl Gill Blackouts, RX Catch Can, Devil Tail Side Stripes, Front Lip Blackout, Dual Color Bowties, Ghosted Sidemarkers,
Exhaust Video (Manifolds) Exhaust Video (Headers) White Lightning
A.C.E.5.
xxx RWHP/xxx RWTQ
CamaroKid300 is offline   Reply With Quote
Old 06-01-2011, 10:49 AM   #14
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
Damn man that was some impressive work! Your car looks great!
My question is, if your insurance was being unreasonable about this incident, why not let them fix the car, then drop them for someone else? Then you can take all those stock parts and sell them to recoup costs from fixing everything!
DarkneSS is offline   Reply With Quote
New Corvette Commercial FenwickHockey65 General Automotive + Other Cars Discussion 91 09-30-2010 01:48 AM
Since when is a 300+ hp muscle car considered settling? Thrillz Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 130 09-28-2010 08:13 PM
The Camaro SS or Corvette 1lt? Mr CLuTcH 5th Gen Camaro SS LS LT General Discussions 62 06-26-2010 11:39 AM
2007 Chevrolet Corvette Z06 Ron Fellows Championship Edition KILLER74Z28 General Automotive + Other Cars Discussion 14 04-10-2007 10:29 AM
