R1 Concepts
Old 06-03-2011, 12:31 AM   #29
Inferno LSX
Supercharged LSX
Inferno LSX's Avatar
Drives: 2011 2SS/RS Black/Carbon Fiber
Originally Posted by Blitzman View Post
I made 715 at 12psi...and 670ish at 9psi. Cant really compare the two as one was done in winter and the other during 95*+ weather.
Both are very impressive.
Inferno LSX is offline   Reply With Quote
Old 06-03-2011, 12:35 AM   #30
Inferno LSX
Supercharged LSX
Caliman, what size pulley are you running?
Old 06-03-2011, 01:07 AM   #31
Supercharged SS
Drives: 2010 Camaro
Originally Posted by Brad7294 View Post
Yes,only change inside was blower cam.
Oh, that makes sense. Your post didn't mention that!
Old 06-03-2011, 01:55 AM   #32
Caliman93230
Caliman93230's Avatar
Drives: LS3S/C
as far as I know is the stock that came with the whipple kit
MODS whipple 2.9L s/c, ADM race scoop, 600 rwhp 550 wrtq, .
Caliman93230 is offline   Reply With Quote
Old 06-03-2011, 02:06 AM   #33
alssiri
alssiri's Avatar
Drives: 2012 ZL1 A6
My car made 595rwhp@7psi on Mustang dyno with LMR TwistedSlayer package ,now @10psi with ported heads 1:1 cog & JRE smooth idle cam car made 604rwhp only
Ahmad
2012 ZL1 A6
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Corsa Sport Catback, ADM 102mm Snout, CAI, LS7 TB, ID850, AGP Dual Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
2015 Rear Fascia Conversion, Z/28 Side Skirts, Flares, Spoiler & Diffuser , ACS Quarter Ports, ShowStopper's Side Marker's, LightWurkz Halo's.
Sosche With KenWood, SLP pod with PLX guage, DashLogic .
alssiri is offline   Reply With Quote
Old 06-03-2011, 02:54 AM   #34
Caliman93230
Drives: LS3S/C
Ahmad
do you have Long tube headers also who ported your heads, i saw texas speed with long tubes and ported heads and a cam made around 690 hp, also the tune is very important what type of fuel are you using that affects numbers too.
Old 06-03-2011, 03:29 AM   #35
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
My numbers are below, and that's on a conservative tune, and 12 lbs of boost. With my turbo kit and the cubic inches, I'm making over 600 ft lbs at around around 2000 rpm, peak torque around 4500 and peak hp at around 5600. I don't have my dyno sheet to look at right now...so that's the closest I can tell you..
A properly designed turbo system will spool plenty quick enough to make the torque you want, and it doesn't care how much you grow the cubes within a given block...
Old 06-03-2011, 04:37 AM   #36
alssiri
alssiri's Avatar
Drives: 2012 ZL1 A6
CBM ported heads with larger exhaust valves & ARE lt's 3" exhaust , FastLane dual fuel pump + BAB & using 93 octane.
Ahmad
2012 ZL1 A6
Old 06-03-2011, 05:47 AM   #37
Inferno LSX
Supercharged LSX
Yah I think I heard that it normally comes with the 4" pulley. Well if the 3.75" one works sweet on mine then you got a choice to swap out pulleys. I believe it says on the pulley what size it is.
Old 06-03-2011, 05:55 AM   #38
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
inferno, you putting the 3.750?
94guy is offline   Reply With Quote
Old 06-03-2011, 05:57 AM   #39
Inferno LSX
Supercharged LSX
Yah.
Old 06-03-2011, 09:51 AM   #40
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
Keep in mind when you install a cam it changes the boost number and its hard to get a fair comparison.I have a stock ls3 with a 2300 ,stock airbox longtubes and at 9lbs it makes 572 through a 9 inch with 22s,this is with our 102 tb which helps quite a bit,,
Hendrix-Engineering is offline   Reply With Quote
Old 06-03-2011, 01:11 PM   #41
HumanWiki
Drives: Car
9 PSI w/ TVS 2300 1:1 Pulley
Doug Thorley LTs and MagnaFlo Cats
SLP LM 2 axle-back
NGK Plugs / MSD Wires
Cold Air Inductions CAI
RX Catch Can
PFDAT Trailing Arms
PFADT Solid Subframe Mounts
Secondary Fuel System
Stock everything else
560RWHP / 520RWTQ
HumanWiki is offline   Reply With Quote
Old 06-03-2011, 01:54 PM   #42
Inferno LSX
Supercharged LSX
Ok, well I'm not gonna be running the 3.75" and gonna try the 4" and 3.875" pulleys instead.
psi, rwhp, rwtq, supercharged, turbo
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 256 11-18-2016 07:50 PM
LSX 376 what kind of power Blown90Z Tuning / Diagnostics -- engine and transmission 6 03-18-2011 06:33 PM
STS Twin Turbos SupremacyCustoms Forced Induction - V8 0 02-16-2010 01:35 PM
Well sunroof question answered (PIC) Black5thgen 5th Gen Camaro SS LS LT General Discussions 152 08-29-2009 10:23 PM
GM only making 40K Camaros ? liquidfire350 5th Gen Camaro SS LS LT General Discussions 81 07-22-2009 10:40 AM
