BORLA
Old 02-12-2012, 07:06 PM   #29
Strider044
Strider044's Avatar
Drives: 2015 2ss/rs Commemorative edition
If you use the gray wire... what if you just want the footwell lights on and the dome off?
2015 2ss/rs Commemorative Edition - DynoSteve Tune, NPP, Hotchkis sport springs 19110, Zl1/1LE rear swaybar, VR-DRX CAI, VaraRam VRX-93, Z28 spoiler
Strider044 is offline   Reply With Quote
Old 02-14-2012, 07:00 PM   #30
bigwayne3000
Drives: 2011 Camaro LS
There are dozens of wires under there where the grey connector is. I'm sure you can go thru this forum here and figure out which is a 12v source and just t tap that when you t tap the grey wire than you'd need to run another t tap to the power wire from the light or you may be able to just double up on the wires there. Not sure, I'm not an electrician nor do I know much about wiring. Just figured youd be able to t tap the 12v too.
bigwayne3000 is offline   Reply With Quote
Old 03-28-2012, 06:31 PM   #31
baup5f
baup5f's Avatar
Drives: 2010 2SS/RS Coupe
Referring this thread to a member, so it gets a nice bump
2010 CGM 2SS/RS
baup5f is offline   Reply With Quote
Old 07-23-2012, 04:49 AM   #32
redleader
redleader
Drives: 2010
What rating of Fuse are you using for your Fuse Tap? 20 amp? 5 amp?
What LED strips did you buy?
How many LEDS on each ?
Thank you,
redleader is offline   Reply With Quote
Old 12-06-2012, 03:50 PM   #33
Jalberdi99
Jalberdi99's Avatar
Drives: 2014 Summit White 2SS/RS M6
theres only one grey wire under the stirring wheel? i dont want to tap on the wrong wire and cause some trouble.
Jalberdi99 is offline   Reply With Quote
Old 12-14-2012, 10:23 AM   #34
Culb
Drives: 2012 2LS
It's the grey wire coming out of the grey box, which is next to the pink box (sorry, not technical so I don't know what the "box" is called). I installed the footwells last night and it went without a hitch. I do want to do the switch idea soon though. Seems better so that you can have the footwells on without the domes, or vice versa.
Culb is offline   Reply With Quote
Old 01-07-2013, 05:54 PM   #35
Jalberdi99
Jalberdi99's Avatar
will this switch work for what you did? is a on/off switch, if off, it should work with the dome light right?(once i tap into the dome wire) and when on, it works with the 12v connection right? im not sure if the pic will show up, if it doesn't t i will try again
Old 01-07-2013, 05:59 PM   #36
Jalberdi99
Jalberdi99's Avatar
here
Old 01-10-2013, 11:23 PM   #37
Asian Zero
Asian Zero's Avatar
Drives: 2010 IBM Camaro 1LT RS
i dont think you can use that switch.... it only has 2 positions not 3. the one you posted is on-off. the one OP is using is on-off-on. if youre wondering why it has 3 terminals on the bottom its because you need a ground on the LED in the switch.
Asian Zero is offline   Reply With Quote
Old 01-11-2013, 01:04 AM   #38
kbeery
Drives: 2011 Camaro SS
Awesome post. Plan on doing this in a couple weeks
kbeery is offline   Reply With Quote
Old 01-11-2013, 12:07 PM   #39
Strider044
Strider044's Avatar
I use an on off on. I have mine powered off the dome light and turn on when the car is running. It's simple If I could do it.
Old 01-14-2013, 03:21 PM   #40
Asian Zero
Asian Zero's Avatar
just finished mine up this weekend. I love how it works. with it set to the dome light it comes on like OEM but then you have the option to turn it on whenever. good write up OP
Old 01-14-2013, 10:44 PM   #41
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
Just completed mine, minus the 3 position switch. Thanks for the DIY install, made it very easy especially identifying the ground.
BigBlock69RS is offline   Reply With Quote
Old 01-29-2013, 07:52 AM   #42
colingordon
Her Name is Mila
colingordon's Avatar
Drives: 2012 Camaro 1LT A6, 2014 Camaro 1LS
Where did you buy your LEDs?
Thank you
Colin Gordon
colingordon is offline   Reply With Quote
DIY Noweeds exhaust diverter installation CanadianCamaro Camaro DIY & HOW-TO instructions & discussions 42 08-15-2016 11:11 AM
Push Start button? CG'sSS Camaro DIY & HOW-TO instructions & discussions 158 06-06-2012 07:27 PM
Anyone have the Footwell Lighting Kit Installed? wildthing001967 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 12 07-03-2011 05:00 PM
footwell neon lighting. How to wire to have it come on the other ambient lighting? Jakefeb3 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 6 11-22-2009 09:32 PM
