Old 03-09-2009, 02:08 PM   #1
almodovarjose
almodovarjose's Avatar
Drives: 2000 Camaro z28/ss
Running Rough
Hello All
I have a 2000 Camaro SS and lately when I come to a stop the car feels like it wants to stall. I have change the spark plugs, Wires, and still the same. I took it to the nearest GM certify shop and after running a diagnose I was told it need it Injector #2 and #7 changed. So I told the dealer to order the parts and put them on. Two days later I get a call that they have already done the job but that the car remain the same and suggested I put another two injectors. I agreed since I want my car running. This time they said that i should also put injectors #1 and #6. As per the shop all four were put and I should come by and pick my car up. I went to pick up the car and the problem remains. Now the dealer refuses to fix it or give me my money back. I have also driven the car with the Mass flow sensor off but it still rides the same. Can someone give me advise on this. Is it possible that 8 injectors all go bad at once? :bangdesk::bangdesk::bangdesk::bangdesk::bangdesk:
almodovarjose is offline   Reply With Quote
Old 03-09-2009, 07:57 PM   #2
MrCool
MrCool's Avatar
Drives: '95 Z28
Maby it's somewhere in the ignition? Something that comes before the wires? (IDK what kind of ignition system the LS1 camaro has?). (Coil, opti,...?) IDK...
BTW...do you have any mods on it? (For future posts...)
Me randomly spitting out parts and stuff that come to my head:
fuel pump/filter
check for misfire - is the gap and stuff right?
found something similar here, check post #64
MrCool is offline   Reply With Quote
Old 03-09-2009, 08:00 PM   #3
justmeron
justmeron's Avatar
Drives: 2010 camaro
Send a message via AIM to justmeron
My car, not a camaro, did that once and it was the 02 censor. But I would think something this simple would have been found by the repair shop. Not a mechanic, wish I could help.
2010 2011 Chevrolet Camaro Faded Black Side Vent Highlight Decal Kit
Life is not like a box of chocolates, its more like eating a whole jar of jalapenos.... what you do today may burn your ass tomorrow!!!!
justmeron is offline   Reply With Quote
Old 03-10-2009, 07:19 AM   #4
almodovarjose
Thanks guys for the oppinions, I will check every hose and also re do the plugs. Only mods I got is cat back, Flowmaster (american thunder). I have been to atleast 7 different shops and most of them don't want to guess cuz there is no check engine light on. People tell me I should get on GMs back and try to get my 962.00 dollars back. Anyways broken or not I love my ride. Black SS convertible with red trimming. I will post some pictures. Is there anyone in the DC metro area that knows of any gatherings for this spring and summer? Let me know and I will meet with you guys. Chick Fil A over in Sterling VA host every Fridays and Saturdays starting in late march all the sport cars meet there and is very cool to see all the cars there. Same goes on in Charles Town West Virginia where I m from weekend meetings as well but a bit boring. Can't wait to go on my first cruise........Alex Chevrolet in Charles Town>>>>>
Old 03-10-2009, 09:07 AM   #5
Mr Twisty
Mr Twisty's Avatar
Ask the shop why they diagnosed it as bad injectors, what tests did they run? Might be able to eliminate some stuff baed on their tests.
-- Benjamin Franklin
Old 03-10-2009, 01:30 PM   #6
almodovarjose
At first he showed me some small computer attached under the hood and pointed out injectors 7 and 2. He told me that he did get some codes and thats how he knew it was the injectors. But he is being a pain in the behind and refusing to help. Now check this out, he originally said injectors 7 and 2 then he told me I should replace 1 and 6 also. But when I told him to write down which ones he changed so that I can later on put the other four. On the invoice he shows changing 1,4,5 and 7. So it looks like he never changed #2 or #6. What made him change his mind. I am so going to court over this s----.
Old 03-10-2009, 01:41 PM   #7
Vash
Drives: 00 Blazer
Check for vac leaks too. It can screw up your mixture if air get's in.
Old 03-10-2009, 02:52 PM   #8
7CAMARO7
7CAMARO7's Avatar
Drives: Slow 4th gen
may be coils or o2s sense you've done everything else. did you clean your maf?
I'd get on that shops ass for a bullshit diagnosis too...
7CAMARO7 is offline   Reply With Quote
Old 03-10-2009, 02:56 PM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
They shouldn't charge you for something they didn't fix. I'd look toward some sort of agency in your state that regulates the auto' repair industry. Here in California, we have the Bureau of Automotive Repair. They hold all repair shops to high standards and are always seemingly willing to assist customer complaints and help get them squared away. I'd check to make sure your plugs and wires are tip-top. Are you getting any back-firing or anything?
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 03-10-2009, 06:17 PM   #10
Super83Z
Super83Z's Avatar
Drives: 1999 Z28 1983 Z28
Check the hose coming off the passenger side of the throttle body that the PCV valve connects to. They commonly develop holes. Also whats your fuel pressure at? Seems like he was all over skipping around the injectors. Maybe its a dying fuel pump and he misdiagnosed it as injectors.
Current cars:
99 Z28
06 Silverado
14 Silverado
Super83Z is offline   Reply With Quote
Old 03-10-2009, 06:32 PM   #11
almodovarjose
Hello Guys
I am doing everything you guys are telling me to do or check. So far I did find a small hole in one of the PCV hoses and replace with a non original until i get to the auto part store. It is still running the same but i will keep checking for other holes. I will clean the MAF tomorrow as well. I originally taught it was the plugs but they told me they checked that twice and that the job was well done. SORRY guys I did forget to mention that it is kind of backfiring. thank you all for the different ideas,, it sure does help.....
Old 03-11-2009, 05:04 PM   #12
7CAMARO7
7CAMARO7's Avatar
also make sure your spark plug wires are plugged up tightly, 2 clicks on the coils and 1 on the plugs
Old 03-11-2009, 05:32 PM   #13
Super83Z
Super83Z's Avatar
Are you getting any codes? How many miles?
Current cars:
99 Z28
06 Silverado
14 Silverado
Old 03-12-2009, 11:43 AM   #14
almodovarjose
No Check engine light on and no codes per some of the mechanics I took it to. As per Alex Chevrolet there were codes but I believe they just don't know whats really wrong with it. I think they were just guessing when they told me it was two injectors. My car has now 104K it is my daily driver and I commute 90 miles round trip 5 days a week.
My 69 is Running Strong RichieFlorida 1st & 2nd Generation Camaros 24 04-05-2009 09:20 PM
LED tails, running lights mondain Cosmetics and Lighting Modification Discussions 13 02-16-2009 03:39 PM
SS IVER still running around the streets of Australia rolnslo Camaro Photos | Spyshots | Video | Media Gallery 12 10-29-2008 05:42 PM
Vid of V6/RS Running! fbird777 Camaro Photos | Spyshots | Video | Media Gallery 11 09-22-2008 11:17 PM
