sjm autoprod
Old 03-09-2009, 07:48 PM   #1
Justin
Camaro5's Cell Phone Geek
Drives: '02 V6 Camaro. 5 speed manual.
Engine ticking
Alright, I'm pretty baffled on this one. I wouldn't say my knowledge of cars is great, but it's not terrible either. I've got an '02 Camaro with the 3.8 and the 5 speed.
When I turn the car on, sometimes, and only sometimes (more frequently as of late), there is a loud ticking sound that increases in frequency with the revs of the engine, and a fairly noticeable loss of power (especially noticeable from 3.5k revs and up). As soon as the engine gets up to around 210 degrees, it stops and the power comes back, and the car runs beautifully.
My first thought was maybe something with the intake and it pulling in from the exhaust when warming up. At first the problem only happened when it was damp and cool, but it happened again today, and it was beautiful out. I'm kinda puzzled.
As far as codes: the other day my check engine light came on and blinked evenly at about a walking pace. Today it came on after about 10 minutes or so, and stayed on until the car got to temp.
Ideas?
Justin is offline   Reply With Quote
Old 03-09-2009, 07:59 PM   #2
pag1164
One Happy Driver
pag1164's Avatar
Drives: 2010 2SS/RS L99
You might have already thought of this, but have you checked your oil?
It sounds as if you could be either low on oil or have dirty oil.
I'd get it to a mechanic as soon as possible to have it checked. Don't mess with that check engine light when it's accompanied by a ticking sound and loss of power.
2SS/RS, IBM, white hood/hockey stripes, ground effects, beige leather
1100 2-26-09
2000 4-10-09
3000 4-14-09
3800 5-20-09 VIN 11019
4000 5-20-09
4B00 5-20-09
4200 6-1-09
6000 6-8-09 Hooray!!
pag1164 is offline   Reply With Quote
Old 03-09-2009, 08:51 PM   #3
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
the ticking is more than likely a lack of oil to your rockers. since once the motor warms up, it goes away. when was the last time you changed your oil? what weight oil are you using? what brand? and what filter?
as for the lack of power and the SES light till the car warms up... I want to say that it sounds like an oxygen sensor failing. more than likely the o2 sensor is not warming up as fast as it should and is triggering the code.
I piss excellence
and fart awesomeness
Old 03-09-2009, 09:49 PM   #4
fireresq157
fireresq157's Avatar
Drives: 1997 SS & 2010 2SS/RS
It may be the Oil, but there is a warning light for low Oil if thats not comming on it may be something else like a craked sparked plug wire or the boot has become loose . Get a code reader if it says missfire that may be posibility and it may narrow the wire down for you. Autozone used to lend you their code reader if you asked.
fireresq157 is offline   Reply With Quote
Old 03-09-2009, 10:05 PM   #5
CamaroSpike23
Truth Enforcer
if the oil is low... but if it is contaminated or the oil passages are plugged, the oil level sensor wont tell you that.
I piss excellence
Old 03-09-2009, 10:48 PM   #6
craigd853
Drives: 199 SS Camaro
What's wrong with everyone? He said there is a check engine light on, the first thing you do is find out what this is and go from there. This could most likely be the main problem, you'll never know unless you find out first.
craigd853 is offline   Reply With Quote
Old 03-11-2009, 05:39 PM   #7
fireresq157
I said get the engine scaned
Old 03-11-2009, 09:02 PM   #8
craigd853
Sorry about that, must have had one to many that night.
Old 03-11-2009, 09:13 PM   #9
Camaro_Corvette
36.833283,-76.021958
Camaro_Corvette's Avatar
Drives: Team 1LE
LOL, drunk post!
Hows it going Justin?
Old 03-11-2009, 11:52 PM   #10
fireresq157
Thats ok, Keyboards and alcohol don't mix.
Old 03-12-2009, 10:27 AM   #11
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Maybe it's time for an engine flush. We used this stuff at the dealership all the time but I don't know if it ever helped anything. I think we used BG brand. Perhaps looking at some Lucas engine treatment or Seafoam is worthwhile too. I've used seafoam inside and out of the engine and it's always done me right.
Another idea is could it be the fuel injectors? Those babies will tick pretty good; I imagine they could contribute to driveability problems too. Seafoam can work here too as they claim it cleans the top-end of the engine too, when you pour it into the gas tank.
Maybe check your plug wires too. I've hear ticking problems with my LT1 after routing the wires too close to my headers and found a burnt wire; when I replaced it, the ticking was gone.
Like 'Spike said - 02 sensors are heated and will throw a code if the computer detects they are getting lazy and not up to the correct temperature fast enough. My 02s would get a little crazy sometimes with my LTs so my tuner tuned them out.
Getting the codes scanned and determining what the codes mean should be a high priority though. You should be able to referrence a MIL chart/diagram to narrow down the problem.
That's when I do my best work
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 03-13-2009, 11:42 PM   #12
Justin
Some more details: The tapping stops at a VERY specific 210 degrees. Literally, within 10 seconds of the temperature dial hitting 210 it goes from full on tapping to normal, and ALWAYS at 210.
As far as the oil change: it was seafoamed on the last batch of oil, then I put full synthetic in (moved from synthetic blend, and before that standard). I'm not sure of the brand, but it was done by Meineke if that helps.
As far as getting a code reader, I'm at school in the middle of nowhere and I wouldn't really know the first place to find one or what the hell to do with it.
Edit: Only put the seafoam in the crankcase.
Old 03-14-2009, 12:36 AM   #13
CamaroSpike23
Truth Enforcer
and you only did the half can right? how many miles did you run with it before getting it changed? can you contact the Meineke and ask them what kind/weight of oil they used? also what kind of filter?
I piss excellence
Old 03-14-2009, 12:18 PM   #14
Justin
Little bit less than half of the can, about 100-150 miles.
I'll give them a call later.
BMEP-Or why you only need 1 camshaft rayhawk Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 12-03-2008 01:28 AM
LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue 13F20 5th Gen Camaro SS LS LT General Discussions 15 09-22-2008 05:35 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
GM moves closer to HCCI engine production Scotsman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-16-2008 07:16 PM
Axial Vector Engine Mr. Wyndham General Automotive + Other Cars Discussion 6 06-20-2007 05:00 PM
