| V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters |
Thread Tools |
L99 suggested rev limiter and shift points
I was wondering if some tuner could offer advice. I took my car to track last week and everytime my tranny would shift from 2nd to 3rd it would hit the rev limiter. Which cause me to loose a few tenths I know. Oh by the way its an automatic with an agrressive tranny tune I presume. My buddy has HP Tuners says my shift points are 6200 rpm's and max rev limiter is 6700 rpm's. In my head I don't see how I'm hitting limiter any insight would help! Thanks!
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS (2ss/rs, auto, SW/IOstripe) Join Date: Jan 2010
on my other camaro ( I haven't taken my new one to the track yet)...if I left it in Sport shift (shifter all the way back, but don't hit the paddles), my car would do the same on the 2-3 shift. IMO, leave it in drive. Paddle shifting it may slow you down because of the delay on the action.
-John S.
2010 Camaro 2ss/rs-a few cosmetic things, Pfadt stage 2 plus rear arm package, LG chassis brace, Vortech, ADM fpcm/ZL1 pump, Lingenfelter 3.70 gears, JBA catless, ProTorque 3200, 18" TSW N'rings for drag duty, 20" Forgestar F14s for street. Thanks to: Jannetty Racing, dv8motoring, Gwatney Chevrolet/GPI Jacksonville AR, TCAudio in Benton AR 2012 4Runner -daily driver |
What's sad is I do leave it in drive. It must be on my tune!
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Camaro 1ss LS3 (THE KRAKEN) Join Date: Feb 2011
From my experience, S mode full auto shifts just before redline, the difference between tap shifting and full auto is about 1/10 th of a second slower. Fells like it is due to less line pressure with button shifting vs full auto, not sure. However take off in full auto vs. tap shift, tap shift is way more aggresive.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
I would drop your shift points down a bit. That should correct this issue.
#7 |
![]() Drives: 2011 1SS RS Camaro, 1995 LSX 240SX Join Date: Mar 2011
#8 |
![]() Drives: '99 H/C FRC Corvette and '07 TBSS Join Date: Jan 2011
Curious if this was with stock size wheels and tires?
Tech Advisor for SNL Performance and Monster Clutch Co. - Call me for any questions you have on Monster Clutches, or, if you want your Gen5 to perform better! SNL Performance is a full service performance shop set on making your modding experience a pleasant one! :flag2:
Chris, 817-750-2000 |
#9 |
Like us on Facebook!
![]() Drives: C5 corvette/ 2012Dodge hemi Charger Join Date: Oct 2010
Stock shift points in RPMs are about 5800-6000 depending which gear is shifting. A good rule of thumb is for each MPH you add to your WOT shift, that will add 150 -200 RPMs, but on your scanner you have to look to be sure.
Like stated earlier, you can have perfect shift points at 6000 RPMs, then go to a smaller tire for the track, that could make you hit the rev limiter. If you have HP tuner, you can change your tire size in the tune and command it to automaticly change your shift points. |
#10 |
Just noticed y'all had more responses for me! But yes when I hit the rev limiter I had my 18" drag radials on my car! They are the 305/45/18's which I thought were close to factory tire size???
#11 |
Fabricator
Drives: 2011 2SS Summit White Join Date: Jun 2011
Will the VVT and DOD stuff safely rev to 6700?
Seems like a lot higher than stock.
Roto-fab CAI
Unobtainium Exhaust AR lt's 330whp L99 |
#12 |
I have the L99 to LS3 conversion with all the goodies that make it soo pricey!
#13 |
![]() ![]() Drives: 2011 2SS/RS Join Date: May 2011
just raise the rev limiter? lol. That way you wont hit it
| Thread Tools | |
| Raptor Performance Dual / Single Mode Shift Lights Now Available At APEX Motorsports! | Apex Chase | Transmission / Driveline | 22 | 10-30-2012 10:38 PM |
| Super Sale on Raptor Shift Lights @ KY SPEED | FRCBobby | Audio / Visual / Electronics/ Gauges / Nav | 44 | 11-25-2011 10:34 AM |
| Raptor Peformance Dual / Single Mode Shift Lights Now Available At APEX Motorsports!! | Apex Chase | Interior Parts & Accessories | 144 | 07-03-2011 09:14 PM |
| Stock rev limiter, holding it back! | Bad70supreme | Dragstrip, Tracking, Autocrossing, Driving Techniques Discussions | 32 | 04-11-2011 05:46 PM |
| REV Limiter Stinks. | attymf | 5th Gen Camaro SS LS LT General Discussions | 79 | 03-19-2010 09:20 PM |
