HURST
Old 06-08-2011, 10:28 AM   #1
rayjgreen
Drives: Camaro SS 2 RS
Touch up paint question(s)...
Wasn't sure if this goes in cosmetics as that says maintenance and this isn't a maintenance question, but if so I'll delete and repost there. Sorry.
A few days in and the inevitable happened, someone scuffed the paint while it was parked. Luckily no dings. Called dealership and they said they have a spray and brush on touch up paint and I'm thinking I need the brush on.
Question is, from reading around, it says if the underlying surface is exposed, which it is, primer is needed. I've also read about clear coat needing to be applied after. Given the small scuff/issue, do I need to apply primer, and since it is from GM directly, do I need clear coat (or for this size)? Any other helpful hints on applying this so I don't make the issue worse? It's on the door, right below the crease in the door. Any help appreciated - have no experience in painting at all, let alone on a car, but everything I've read says a layman can do it.
Pic, with enormous glare I couldn't get around from any angle:
rayjgreen is offline   Reply With Quote
Old 06-08-2011, 10:46 AM   #2
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
I had a few nicks in the paint that I fixed with a kit from Dr. Colorchip:
http://www.drcolorchip.com/
It's not 100% perfect, but it's not too bad.
E.T. is offline   Reply With Quote
Old 06-08-2011, 08:58 PM   #3
rayjgreen
Thanks E.T. Ended up taking it to a paint shop (Tommy's in Denton, TX) and they were kind enough to touch it up for free. Awesome people. Doesn't look new, but hardly noticeable. Good enough for the break in process.
Old 06-08-2011, 09:49 PM   #4
E.T.
E.T.'s Avatar
Cool. Always good to let the pros handle it, especially when it's free
A few questions about custom paint jobs. nardox Cosmetics and Lighting Modification Discussions 11 02-21-2011 09:34 AM
Removing Swirl Marks using a Flex and Meguiars M105/M205 Angelo@Autopia Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 5 05-22-2010 11:36 PM
IOM Paint either touch up or can? SSTony Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 3 01-04-2010 10:59 AM
Rally Yellow Touch up paint GM drtwo Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 13 10-31-2009 07:31 PM
How Bumpers are made, Paint Matched and Questions for FbodFather rays Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 43 06-15-2009 02:01 PM
