BeckyD @ James Martin Chevy
Old 06-10-2011, 11:40 AM   #1
camarocolin
Drives: 2010 camaro 2ss L99
373 gears question
has anyone put 373 gears in there camaro yet and if so how much did it pick up in the 1/4 mile time
camarocolin is offline   Reply With Quote
Old 06-10-2011, 11:51 AM   #2
PC HOTROD
PC HOTROD's Avatar
Drives: 2010 Camaro SS IOM 6M
Not worth the money, time and effort with running a non-modded car on street tires.
www.MotoDivaz.com
2010 Camaro SS IOM
PC HOTROD is offline   Reply With Quote
Old 06-11-2011, 01:40 AM   #3
Unobtainium
Fabricator
Unobtainium's Avatar
Drives: 2011 2SS Summit White
I think the change is too small. From 3.4 to 3.7 is not huge. 4.11's should be better.
The OP has an auto, so 3.73's will be a bigger change in his car, but I would still do 4.11's to maximize bang for your buck.
I would expect 2 mpg loss or so, but let's face it, we are not talking hybrids here anyway.
I did 4.56 gears in my '79 z/28, and it was like a whole new car.
Light to light monster with under 300 HP.
Roto-fab CAI
Unobtainium Welding Exhaust
ARH LT's
393whp L99
GPI VVT Turbo Cam-in
Twin Mini's...soon
Permagrin...Always
Unobtainium is offline   Reply With Quote
Old 06-11-2011, 03:21 AM   #4
JM10
Se habla espaņol
JM10's Avatar
Drives: 2010 Camaro SS/RS VR
I went with the 3.91 gears ...with a built differential from RPM...
Waiting to be installed, I will post my 1/4 times.
JM
2010 VR 2SS/RS
BMR Suspension Parts
Hendrix HD Axles
DSS Aluminum Shaft
RPM Diff / 3.91 Gears
LPE ZR1 Clutch
Edelbrock E-Force SC / JRE Fuel Upgrade
Livernois 1C cam 570 rwhp/559 rwtq SAE
Best 1/4 time: 11.43
JM10 is offline   Reply With Quote
Old 06-14-2011, 05:37 PM   #5
usmcjlp
Drives: 2SS/RS LS3 RJT
I have had both the 3.70 AAM and Richmond 4.11 gear sets. My camaro is supercharged and at 650+ rwhp. I did not feel the 3.70s were a huge difference. I am much happier with the 4.11s. Car feels much lighter and I barely have to tap the gas to pass or merge on the highway, which is what I wanted.
Traction was an issue with both gears. I am not a drag racer. Most of my launches are a rolling start because from a full stop 1st or 2nd are traction limited. I was much more concerned with accelerating from 40-100mph. To be honest, I think unless you switch to a wider, stickier tire, traction will prevent much lower times.
My new wheels with 275 and 315 nitto NT-05s are due next week. So I'll see what happens.
usmcjlp is offline   Reply With Quote
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 12:38 PM
Richmond Gear Camaro gears RichmondGear V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 85 01-19-2015 11:43 AM
Question on gears. v6sonoma V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 10-20-2010 03:34 AM
Lowering springs and rear gears V6 information macwest 5th Gen Camaro SS LS LT General Discussions 12 04-30-2010 11:58 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 07:53 AM
