Old 06-10-2011, 01:33 PM   #15
TOMS1SS
Drives: NA
Originally Posted by armysig View Post
Oyi....You might want to do some research on why Arizona has 91 octane fuel. I know the answer, but I want you to look it up. You'll get more out learning about it and why we have it here vs the east coast, south and some northern states.
Old CA would have us driving electric motorbikes if they had their way....
TOMS1SS is offline   Reply With Quote
Old 06-10-2011, 01:34 PM   #16
c_LoW29
Drives: 2011 2SS/RS, 2010 Mustang GT
Originally Posted by BATMANs View Post
I run 91 octance california gas from COSTCO in both my blown cars (see below). No issues or blown engines.
ofcourse not they are already blown.....
c_LoW29 is offline   Reply With Quote
Old 06-10-2011, 01:38 PM   #17
bhall82
Drives: 2011 SS/RS
Originally Posted by Supercharged SS View Post
Who buys an SS and then wants less performance out of it? If I wanted less than what I bought I would have bought the V6.
LMAO You have a point there!!
bhall82 is offline   Reply With Quote
Old 06-10-2011, 01:42 PM   #18
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
Originally Posted by SlingShot View Post
... Also it has been proven by the V6 guys, there is a slight performance gain using premium fuel although it may not be cost effective.
Yep, this has been well documented by Scrming. The LLT will keep advancing timing until it detects knock. It's been shown that when running with 87 octane, quite a bit of timing is pulled. Others have said their car runs smoother with higher octane. Personally, I've been using Shell Vpower and I don't have any complaints—car seems nice & happy.
Manual says "87 or higher". I opted for higher. It really amounts to only 3 or 4 bucks extra per fillup. We're already getting raped at the pumps, so an extra couple of bucks doesn't really worry me in the grand scheme of things
E.T. is offline   Reply With Quote
Old 06-10-2011, 01:44 PM   #19
sasquash1984
502 RWHP N/A
sasquash1984's Avatar
Drives: The yeti
I love seeing people fill their vettes with 87
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
sasquash1984 is offline   Reply With Quote
Old 06-10-2011, 01:47 PM   #20
HumanWiki
Drives: Car
Most everywhere I've been, there's usually only a ~.10 diff in 91 and 93. I always use 93, even before I got the blower and supporting mods.
I'm not going to cheap out on the fuel for car. 0.10/g for even a full tank is nothing compared to the amount of $$ in my car.
Plus, knock on a blower engine isn't something I want to play around with by using lower.
HumanWiki is offline   Reply With Quote
Old 06-10-2011, 01:48 PM   #21
Cbrenthus
Drives: 2011 VR 1SS
Around here there is a 30 cent difference between 87 and 93. I've never seen 30 cents between 91 and 93, but maybe its that way in Arizona.
While yes, the SS will run on 87, it will reduce performance significantly. Also note that when reducing performance, usually mpg suffers too. So, you can actually spend more money on 87 than on 93.
Putting anything other than the recommended fuel in the car is just stupid and a waste. Let's say you burn 20 gallons a week, at a 30 cent difference. That's $6 a week for the proper fuel. that's an extra $312 dollars a year. You figure most people have payments, and when you plug that into the overall yearly expense, these cars probably cost everyone at least $4K-$5K a year, whats an extra $312?
The bottom line is, premium is recommended, so that is what I run. And, that is what everyone should run, and if you are that worried about a few extra dollars a fill up, then you bought the wrong car.
Cbrenthus is offline   Reply With Quote
Old 06-10-2011, 01:51 PM   #22
TOMS1SS
Drives: NA
The 93 pumps are a rarity out here in Arizona. Every one I've encountered had at minimum a $.25 markup over 91.
Old 06-10-2011, 01:52 PM   #23
UT-Engineer
Just Cruisin'
UT-Engineer's Avatar
Drives: 2010 Synergy Camaro
2010 Synergy Green Camaro
25% Tint - CGM Painted GM GFX - 20" Niche M102 Wheels
UT-Engineer is offline   Reply With Quote
Old 06-10-2011, 01:53 PM   #24
BenningJ
BenningJ's Avatar
Drives: 2013 AGM 1SS/RS LS3
Originally Posted by CamaroKid300 View Post
89 is cheaper than 87?
Wut?
Yeah 89 is cheaper than 87 here, and 91/93 is usually only 20 cents more than the 89. Right now, 89 is $3.42, 87 is $3.49, and 91/93 is $3.73.
If I am not mistaken we get a break on using Ethanol blended fuels because it requires corn and that is the main crop that we farm here in Iowa.
EDIT: Fixed fuel prices. Double-checked and I was a little off.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts
BenningJ is offline   Reply With Quote
Old 06-10-2011, 01:56 PM   #25
14pilot
Original Bumblebee Owner
14pilot's Avatar
Drives: 265hp ZX-14, 500hp Silverado, V-ROD
Just love all the opinions vs. facts on fuel octane.
I most enjoy when someone posts that they can feel the seat of the pants difference between 91 and 93 octance fuel. Very amusing stuff right there...
To the uninformed that believe all the octane hype, more octane does not equal more power. It depends on a number of factors as to whether or not more octane helps or not. For instance, my ZX-14 Ninja made its highest dyno numbers on 87 octane fuel. Its an N/A motor. If you are boosted, or have raised stock compression, more octane really helps you run more ignition timing for more power.
Higher octane means that more knock retardant chemicals have been added to the fuel. These chemicals reduce knock and they can reduce power since for each gallon of gas, the retardants replace a certain volume of the gas. This lowers the amount of BTUs (heat energy) that can now come from the gas. You can make up for this and get ahead of this if you are tuned to take advantage of higher octane. If you are not tuned, then you lose power and decrease fuel mileage.
In Arizona, we only get 91 octane since all our fuel is surplus from the nearby California fuel market and they only get 91 due to their smog laws.
So are the ignition tables in a stock, non-tuned Camaro going to be able to use the 2 extra octane in 93 vs. 91, to run more timing and result in more power?
Can a dyno measure a difference between 91 and 93 on a stock engine and tune?
Stock engine/Stock tune mentioned here, so all you blown/turbo'd/Nitrous guys with tunes don't have to jump in here to explain how higher octane is a must for your applications.
#5 - 2010 2SS/RS MN6 ABM #142-Silver Rallys-GFX / Med Titanium
My previous Camaros:
#4 - 1994 Z/28 6M Black over Arctic White / Graphite-Red Inserts - traded
#3 - 1981 Z/28 Bright Blue Metallic / Black - sold
#2 - 1970.5 RS Mulsanne Blue / Blue - endo crashed it and parted it out
#1 - 1967 RS Butternut Yellow w/ Black Bumblebee Stripe-RPO D91 / Parchment-Black - sold
14pilot is offline   Reply With Quote
Old 06-10-2011, 01:56 PM   #26
KILLER74Z28
MOD SQUAD
KILLER74Z28's Avatar
Drives: 2G1FT1EW9A9100666
X2
.30 between mid grade and premium……..ummm are you sure?
In my performance cars and trucks I’ll run 93 because it proven to run better and give you more HP/MPG. But in my daily driver I have no problem running 87…
Who cares about the Blue Oval crowd and their little Ponys? We're getting our Camaro back-and it'll be Supercharged!-MDAII
Team LS3
KILLER74Z28 is offline   Reply With Quote
Old 06-10-2011, 01:59 PM   #27
CamaroKid300
ace5.org
CamaroKid300's Avatar
Drives: 2012 2SS/RS LS3
I know for a fact, because I just filled up yesterday, that 87 here was $3.59, 91 was $3.79, and 93 was $3.99
Seems they went from the .10 between grades to .20 between them here. Those prices were from a shell station.
NightOwl RGB Halo Kit V2, Kooks 1-7/8 LT Headers, Cam Motion Cam, CAI Intake, Catless Midpipes, Borla ATAK Catback, 35% Tint, Vinyl Gill Blackouts, RX Catch Can, Devil Tail Side Stripes, Front Lip Blackout, Dual Color Bowties, Ghosted Sidemarkers,
Exhaust Video (Manifolds) Exhaust Video (Headers) White Lightning
A.C.E.5.
xxx RWHP/xxx RWTQ
CamaroKid300 is offline   Reply With Quote
Old 06-10-2011, 02:02 PM   #28
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '112SS/RS'12CruzECO'11CruzeLTZ,Mini
" For best performance, use premium unleaded gasoline with a posted octane rating of 93." Guess it's a good thing we only have 93.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X,Monster Triple,Alky Control Meth Inj Feb12th Install.
SSBUSDRVR is offline   Reply With Quote
Fuel: getting it right the first time S-eatin-grin Forced Induction - V8 45 08-30-2012 02:22 PM
MPG for the Z28 OPP Camaro ZL1 Forum - ZL1 Specific Topics 71 12-08-2010 04:00 PM
Lethal Performance/ Fore Precision Fuel Hats- CHECK THIS THING OUT Jared@Lethal Forced Induction 3 08-12-2010 12:30 PM
Generation V V8 Engines Update!!! Mr. Wyndham General Automotive + Other Cars Discussion 29 07-08-2010 04:05 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
