| Cosmetics and Lighting Modification Discussions External and Internal cosmetics modifications. |
Thread Tools |
#76 |
So is price $179 for all? Do these ship from the US? Do you have fogs in stock?
You say we dont need to use the universal mounts for the Camaro but then how do you install these? I did not see bolt threads on the back of these light?
#77 |
no sir that was a intro prices which is no longer foglight assist is in stock
#78 |
![]() Drives: 2011 Camaro 2LT Cyber Gray Join Date: Apr 2011
If you are unsure if these will fit a Camaro, especially a 5th gen, then why do you post them up on a 5th gen Camaro website? I would suggest making a custom bracket for 5th gens or a complete bolt on replacement set.
2011 Chevy Camaro 2LT RS Cyber Gray Modified Camaro's Unite! Share your Camaro at ModifiedCamaro.com |
#79 |
because we know they will work why wouldnt they
#80 |
I have the ACS T3 ports and they use this bracket to hold the lights. So this is the same 3 hole pattern the stock Camaro has too. So how would your light mount on this when it have no rear holes????
#81 |
i understand you question loud and clear All of the 70 mm modules were designed in a way to allow easy custom integration into model cars as well as to easily replace current factory 70 mm (or approx.) fog lights. These lights have very shallow install depth of only 55 mm!
we are willing to do whatever we have to do |
#82 |
But how do you screw the light through the OEM holes?? Your holes on the light are on the side for the bracket and you have no holes in the rear to mount to the OEM plastic holes or the ACS port bracket. Ideally you would make a specific Camaro bracket the goes from the 2 side holes of your light to the 3 OEM holes of the DRL port.
| Thread Tools | |
| Introducing...THE ANTI-BLING, Dub.1 Wheels | J@Wheelsboutique | Wheels / Tires | 2 | 03-24-2011 12:46 PM |
| Introducing the Uber Wool Wash Mitt V2 | DetailersDomain | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 0 | 02-02-2011 03:25 PM |
| Introducing the 3 plus 1/ Bulk Section at DD | DetailersDomain | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 0 | 01-11-2011 12:13 PM |
| Introducing AKATA WHEEL SPACERS!!! | vossen wheels | Suspension / Chassis / Brakes | 1 | 09-03-2010 02:34 PM |
| Introducing AKATA WHEEL SPACERS!!! | vossen wheels | Sponsor Announcements / Giveaways / Contests | 0 | 09-03-2010 02:05 PM |
