BeckyD@RodgersChevrolet
Old 03-11-2009, 05:10 PM   #1
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
horsepower vs torque
i just found a really good explanation of the relationship between the two and which really wins races.
http://ls1tech.com/forums/general-ls...hp-torque.html
that page also has a link to a 1/4 mile time estimator (it puts the 5th gen LS3 @ 12.9)
http://www.fantasycars.com/derek/qua...it=Get+Results
*Warning: Technical Post*
In basic terms, torque is a force at a distance (pounds are force, feet are distance, lbs x ft = torque). So, the more force you apply the faster you accelerate (Acceleration=Force/mass). Alternatively, when expresed linearly the units of torque are equivelent to lifting 1 lb of weight 1 foot off the ground.
Horsepower is torque/time. So, the faster you can exert the same torque the more power you have. In the case of cars, speed is revolutions per minute (rpm's). Hp=(torque*revolutions)/(minutes*5252), or more simply Hp=torque*rpm/5252. Transmissions are based on this equation. They trade revolutions for more torque. But the power remains the same (minus frictional losses).
Now, lets get back to torque vs hp. Before we begin, these numbers are purely for illustrative purposes, I basically made them up as I went. Lets say you were repairing your roof. You've got 3 buddies to help you bring supplies up to the roof 20 ft off the ground. Bob can bring up loads of 100 lbs in about 2 minutes. Joe is weaker, but quick. He can only manage 50 lbs at a time but he does it twice as fast a Bob. Your third buddy is Frank. Like Bob he can bring up 100 lbs at a time but like Joe he does it in only 1 minute.
. Bob . . . . . . . . Joe . . . . . . . . Frank
100lb*20ft/2min . 50lb*20ft/1min . 100lb*20ft/1min
0.1904 hp. . . . .0.1904 hp. . . . .0.3808 hp
So, Bob and Joe are equally powerful but they are half as powerful as Frank. Another way to look at it is given the same power you can be strong and slow or weak and fast. Never both. To get both, you need more power. You need a Frank.
this is all well and good for comparing 1 particular hp value against another and would lead one to believe that 300 hp is the same no matter what. That is both correct and wrong at the same time. More torque gives you more power at lower speeds. Which means that when cruising down the highway at 1500 rpm the 4.6L v8 in the mustang would give much better acceleration than the 3.6L V6 from the Camaro, if they were in the same car and the same transmission. Since the mustang is lighter than the Camaro it is no contest. The two will only have similar performance when they are both at their peak RPM.
Hp vs torque, I take hp. RPM vs hp, I take hp. Torque vs RPM, I take torque.
What's the advantage of High revs with the same power?
http://craig.backfire.ca/pages/autos/horsepower
http://www.vettenet.org/torquehp.html
Old 03-11-2009, 06:17 PM   #2
MRK III Z28
SoCal C5 Family Member
MRK III Z28's Avatar
Drives: 1968 Mustang
Send a message via AIM to MRK III Z28
Thanks Zebra that was a good read
MRK III Z28 is offline   Reply With Quote
Old 03-11-2009, 08:58 PM   #3
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
I wrote a 'beginners guide' a while ago (same title, but oddly a slightly different topic . . .)
and before that, I created this thread: Whats the advantage of high revs with the same power?
Just a bit more supplementary info for those who are interested.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 03-11-2009, 09:03 PM   #4
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
OOOH, good read
Old 03-11-2009, 09:29 PM   #5
zebra
zebra's Avatar
i understood that, but afterwards, my head
Old 03-11-2009, 09:30 PM   #6
Camaro_Corvette
36.58625, -121.7568
Drives: Team 1LE
ROTFLMAO
Old 03-13-2009, 09:41 AM   #7
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
YYYYEEEEESSSSSS!!!!!! Tech' talk
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 03-13-2009, 09:59 AM   #8
garagelogic
Drives: 2010 Shelby GT500
Thanks for sharing. It's always a good idea to help educate the masses on things that are commonly misunderstood.
BTW, did you include the weight of the driver along with the curb weight of the car when you arrived at that 12.9 number? I used the 3860 curb weight listed for the manual SS (426hp) and a driver weighing 140lbs (4000 total weight) and arrived at a 13.065
Using the same calculator, a GT500 (500hp) with a curb weight 3920 of plus the same 140lb driver (4060 total weight) gave me a 12.448
While there have been GT500's in stock form run those numbers, it is not the norm. I would hazard to say if the calculator is worth anything at all, very few SS Camaro's will be running 13-flat in stock form. Time will tell, I guess.
garagelogic is offline   Reply With Quote
Old 03-14-2009, 01:00 AM   #9
zebra
zebra's Avatar
good point! i just used curb weight. by the way, does curb weight include a tank of gas?
and that calculator is definitely just an approximator. get a good tail wind & a nice cool temp and you might could pull off high 12s
Old 03-14-2009, 02:05 AM   #10
Mythic
Mythic's Avatar
Drives: '03 Monte Carlo SS
Mythic is offline   Reply With Quote
Old 03-14-2009, 02:20 AM   #11
zebra
zebra's Avatar
Originally Posted by Mythic View Post
good link!
The car with the V8 will be named Redneck, and the car with the 4 cylinder will be named Ricer. The V8 can rev to 6000RPM and produce a ton of torque, while 4 cylinder can to rev way up to 9000RPM and produce a fair bit of torque.
Old 03-14-2009, 08:02 AM   #12
garagelogic
Yes, as I understand it, the official curb weight number is a reflection of what the car would weigh with all available options installed and a full tank of fuel.
I have no doubt we will see instances where SS's are getting into the 12's. I think we will see evidence of SS's running in the mid-to-high 13's, too, due to factors such as track conditions, temps, driver error, etc.
Old 03-14-2009, 03:44 PM   #13
zebra
zebra's Avatar
yeah. after driving slow cars all my life (with the exception of when i hit up used lots), i'm just happy with a 12-13 second car, period!
Old 03-14-2009, 04:00 PM   #14
Beamer
N00B
Beamer's Avatar
Drives: 07 Cobalt SS/SC-Toy | 97Cavalier-DD
Send a message via Yahoo to Beamer
very good read
Beamer is offline   Reply With Quote
1/4 mile, horsepower, torque
BMEP-Or why you only need 1 camshaft rayhawk Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 12-03-2008 12:28 AM
Challys 6-Speed Tranny only capable of 450 ft. lbs torque, what about the Camaro? Muscle Master General Automotive + Other Cars Discussion 9 10-18-2008 01:28 AM
Making Modern Horsepower the Old-Fashioned Way KILLER74Z28 General Automotive + Other Cars Discussion 14 02-02-2007 01:50 PM
GM Attempting to keep Camaro Buzz alive for 2 years rray200 5th Gen Camaro SS LS LT General Discussions 32 02-01-2007 04:44 PM
