Elite Engineering
Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions
Old 06-12-2011, 10:18 AM   #1
shaner74
Drives: 2010 camaro 2SS/RS
Just installed whipple, but dumb problem...
My AM/FM radio reception now sucks. A lot of static plus I can hear the engine revving through the speakers. I've checked and re-checked all my grounds and wiring - all seems fine. Any ideas what the problem could be? I'm posting in the FI section only because it's related to my SC install. Thanks.
shaner74 is offline   Reply With Quote
Old 06-12-2011, 10:51 AM   #2
usmcjlp
Drives: 2SS/RS LS3 RJT
I have a very similar problem. My radio reception sucks compared to before the install. I can't pick up local stations without static. Static gets worse with higher rpm. I do not have the revving problem. All my other sources work fine. I haven't had time to mess with it. I'm currently stationed away from home.
usmcjlp is offline   Reply With Quote
Old 06-12-2011, 11:02 AM   #3
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
I can't pick up a station to save my life after my Maggie install, unless I am within 20-30 miles of it.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 11psi 11.20 @ 126mph
TVS2300 , Twin Carbon Street Slayer Clutch & 1000HP Axles,JRE cam & tune,LPE Fuel, Super Chiller,Nitto555R
Turbo99 is offline   Reply With Quote
Old 06-12-2011, 12:10 PM   #4
vart
vart's Avatar
Drives: 2010 2SS
Is it just local stations? Do any of you have XM radio, and is it screwed up too?
Got: Volant CAI. Stealth splash guards. Stainless Works 1-7/8" long tube headers and cat back exhaust. Pfadt coilovers, sway bars, rear trailing arms, street differential mounts and solid subframe bushings. Custom tuned by Davenport Motorsports.
Want: Everything else!!!
<img src=http://www.camaro5.com/forums/image.php?type=sigpic&userid=34547&dateline=1309150494 border=0 alt= />
vart is offline   Reply With Quote
Old 06-12-2011, 12:15 PM   #5
Turbo99
Turbo99's Avatar
My IPOD works fine, haven't tried XM I didn't subscribe and locals anywhere won't come in unless I am on top of them
Old 06-12-2011, 12:25 PM   #6
94guy
94guy's Avatar
Drives: 99 Camaro; 2010 Camaro 2SS/RS
with my whipple i have the same problem. static. i'm wondering if it's the sparkplugs that come with the whipple?
94guy is offline   Reply With Quote
Old 06-12-2011, 12:25 PM   #7
shaner74
Wow I didn't expect others to be having the same problem.
Must have something to do with replacing a plastic intake with
a metal one or possible static electricity from the spinning gears of
the SC?? Just surprised nobody posted this problem before.
Old 06-12-2011, 12:28 PM   #8
shaner74
94guy, I thought maybe the plugs too but I don't see anything different about them except they don't have the factory dialectric grease on them. I used dielectric grease from autozone.
Old 06-12-2011, 12:28 PM   #9
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
I do not have this problem with my maggie. Radio works the same as before.
Old 06-12-2011, 12:30 PM   #10
mst504
Caffeine Injected
mst504's Avatar
Drives: 2010 Orange SS L99 HPE Supercharged
Hmm, didn't give it much thought, but my radio sucks with my Maggie too. Didn't affect XM though, but I don't use XM, just plug up my Zune when I want some music.
mst504 is online now   Reply With Quote
Old 06-12-2011, 12:34 PM   #11
BUMBLEB
IN GOD WE THRUST
BUMBLEB's Avatar
Drives: 2010 RY 2SS RS M6 TVS2300
+1
BUMBLEB is offline   Reply With Quote
Old 06-12-2011, 01:44 PM   #12
Synner
Drives: 2011 2SS/RS M6
RFI interference typically comes from
1) non-RFI insulated plug wires
2) Power/signal cables run next to your radio cables
3) Ignition systems
Not sure what got relocated to cause the issue but the blower itself isn't the cause.
Synner is online now   Reply With Quote
Old 06-12-2011, 01:48 PM   #13
shaner74
Just did some detective work. It's the msd boost-a-pump. When it's energized radio interference spikes. Now I just need to figure out how to fix it.
Old 06-12-2011, 01:54 PM   #14
mst504
Caffeine Injected
mst504's Avatar
Is it drawing power away from the radio and other components (such as lights dimming), or is it causing some sort of interference?
I don't think that is the case for myself since I do not currently have a BAP.
Old 06-12-2011, 02:07 PM   #15
BrainleSS
427 LSX w/ IPS 👇 SOON!!!
BrainleSS's Avatar
Drives: '10 ABM 2SS/RS M6
It probably is the ground on the BAP it was a problem with my whipple install!
BrainleSS is offline   Reply With Quote
Old 06-12-2011, 02:27 PM   #16
Turbo99
Turbo99's Avatar
Not my issue I have twin pumps
Old 06-12-2011, 03:15 PM   #17
shaner74
Grounds are good. I'll buy a noise filter and put it inline with the BAP and see if that helps.
Old 06-12-2011, 11:05 PM   #18
Caliman93230
Caliman93230's Avatar
Drives: LS3S/C
i could be a bap issue, however my radio sounds awesome no change in before or after instal, dont know if the grounding has any thing to do with it but it may be an amplifier issue.
MODS whipple 2.9L s/c, ADM race scoop, 600 rwhp 550 wrtq, .
Caliman93230 is offline   Reply With Quote
Old 06-12-2011, 11:15 PM   #19
boostedyards86
boostedyards86's Avatar
Drives: Cummins 3500
no problems here.
2010 Camaro SS-758rwhp, 664rwtq STOCK BOTTOM END!!! 10.52@134mph 1.63 sixty foot.... 93OCTANE!
06 Cummins- 466whp 940wtq EFI LIVe
boostedyards86 is offline   Reply With Quote
Old 06-12-2011, 11:43 PM   #20
usmcjlp
Shaner74,
If you find a solution please post it. I was planning on troubleshooting this as soon as I get home. Stating that you don't have the problem, isn't really helping. I'm glad you don't. Now if you have an idea what might be causing our problem, please let everybody know. Read the original post.
Old 06-13-2011, 12:05 AM   #21
bluetorp
bluetorp's Avatar
Drives: 2010 2SS/RS IOM M6
People actually listen to the radio?
Those of you that are having interference issues and are also running the MSD BAP- where/what are you using as a ground point for it?
bluetorp is offline   Reply With Quote
Old 06-13-2011, 02:01 AM   #22
Inferno LS3
Mayhem Style
Inferno LS3's Avatar
Drives: 2011 2SS/RS Black/Carbon Fiber
Haven't noticed any problems with my Whipple. Radio and XM is fine. I do have twin pumps and no BAP.
Inferno LS3 is offline   Reply With Quote
Old 06-13-2011, 05:20 AM   #23
GMRULZ
GMRULZ's Avatar
Drives: 2010 SS & 2008 C6
No change here as far as I can tell but I hardly use the radio the CD`s and Ipod work much better. I`ve never had the car in for the supposed stereo fix that gets rid of all of your bass...Lol..
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s!
Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list..
GMRULZ is offline   Reply With Quote
Old 06-13-2011, 10:32 AM   #24
carguy
Carguy
Drives: 57Chevy,67,80,2@10's camaro's,04SSR
I haven't turned my radio on, after installing Cogged Drive on my Maggies...That my friends, is music to my ears !
But to stay on Topic....No Radio interference on either of my Maggied camaro's.
One has duel Fuel pumps the other has stock pump (Working overtime)
One has JL audio amp and Subs
( what a waste of money, should have bought the cogged drive first) and not a hint of noise even amped to the max.
2010 SS/RS LS3, 21" Rims, SLP lowering Kit & sway bars, TVS2300, Hennesy CAI, Kooks LT Headrers & Cats, Corsa Exhaust, RIP Shift ST shifter, SLP Hood & Spoiler, Slp Black out package - Grill SS & Rear SS Emblems, ADM Dual Fuel Pump , 3.6 upper Pulley, 10% overdriven Innovators West Crank Pulley& Pin Kit.
carguy is offline   Reply With Quote
Old 06-13-2011, 10:44 AM   #25
Turbo99
Turbo99's Avatar
I have dual pumps no BAP and after market amps, all is good on everything except radio station clarity.
Whipple Superchargers from the Largest Volume Install shop in The USA - TORQ! Erik@Torq Forced Induction 25 08-07-2012 03:01 PM
Whipple Superchargers In The House!!! HP Addicts Forced Induction - V8 1 04-27-2011 08:26 PM
Whipple SC installation compared to Maggie installation Fiftydriver Forced Induction - V8 8 02-12-2011 11:56 AM
Top Mount Decision- TVS2300, KB, Whipple thekid96 Forced Induction - V8 106 03-03-2010 10:37 AM
Consolidated Toyota Recall/Safety thread Rallysport General Automotive + Other Cars Discussion 382 03-01-2010 05:42 PM
