Old 06-12-2011, 07:44 PM   #1
jlugo
Drives: 2014 1LE 'Summit White'
Exclamation 20's in the Front & 22's Rear...
Has anyone done this?...Will it Work?
jlugo is offline   Reply With Quote
Old 06-12-2011, 08:01 PM   #2
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: Longest things on Earth
in the august 2011 issue of chevy high performance mag CGS Motorsports put 405/25r24 on 24x15 wheels on the rear and 265/30r22 on 22x8.5 on the front with some major modifacation to the rear. looks killer!
its a syn is offline   Reply With Quote
Old 06-12-2011, 08:03 PM   #3
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
A better question is "why?" You would want more sidewall on the rear for traction. The 22" wheels would have narrower sidewalls.
I've seen some guys go with 18s in the back and 20s on the front.
Old 06-12-2011, 09:36 PM   #4
jlugo
Why they put '18-inch front & 19-inch rear' on the Vette?
I think the Camaro with that "Big behind" would look good with bigger wheels in the rear.
Old 06-13-2011, 09:37 AM   #5
Darth_Emma
Darth_Emma's Avatar
I guess it depends on what you want to get out of your car. If performance is more important than a certain look, then smaller diameter wheels with more sidewall should go on the back. (The total wheel diameter, including the tire, should be about the same all around because the difference is made up with the sidewall on the tire.)
I have 22s all around on my car and I wish I'd gone with 20s or even 18s since I've added horsepower. I lost at least 20 rwhp when I put the 22s on.
Old 06-13-2011, 10:30 AM   #6
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Bad example. Corvette also uses two different height tires front and rear, and also has two different sized fender/quarter openings to match those tires. Corvette uses 26" tall front tires, 27" tall rear tires. So, the 18/19 combo maintains a similar sidewall height, and similar fender gaps. The Camaro uses 29" tall tires front and rear, and the ABS/Traction Control, Stabilitrak etc all need similar height tires to function properly.
Fquick.com/NineBall
Old 06-13-2011, 10:50 AM   #7
Darth_Emma
Darth_Emma's Avatar
^^^ What he said.
Old 06-13-2011, 05:28 PM   #8
jlugo
I have 22s all around on my car and I wish I'd gone with 20s or even 18s since I've added horsepower. "I lost at least 20 rwhp when I put the 22s on".
"Wow"...that's no good.:(
I want both, Performance and the Look.
I was thinking in getting a set of 18's wrapped with Nitto NT05 for when I go to the track..
Old 06-13-2011, 05:45 PM   #9
Darth_Emma
Darth_Emma's Avatar
Yeah, I want both too. That means either 2 sets of rear wheels (like you said), or a compromise of putting 20s on all around.
I do love the look of the 22s though.
Good luck with your choices!
Forgestar Wheels at DV8 Motoring - 18s, 19s, 20s, 22s! Nine Ball Wheels / Tires 688 11-01-2013 10:38 AM
2010 Camaro SS V8 in Syracuse NY-FREE TRAVEL TO PICKUP Mitsubishi in Syracuse Camaro Price | Ordering | Tracking | Dealers Discussions 0 12-10-2009 04:23 PM
Steering response.... CGM2SSRS Wheels and Tires Talk Sponsored by The Tire Rack 130 10-21-2009 05:04 PM
1LS standard equipment and options Tran Wiki 0 10-18-2008 08:13 PM
