Tom Henry Racing
Cosmetics and Lighting Modification Discussions External and Internal cosmetics modifications.
Old 03-12-2009, 09:03 AM   #1
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
Paint Codes
Does anyone know (or have access to) the paint codes for the 2010 Camaro?
I would like to have my GFX painted before the car comes in, and then return them to the dealer for installation.... dealer says they will likely be shipped to them via fed-ex before the car is delivered.
My car will be black....the "order code" for black is "GBA".... I am pretty sure that this is not the "paint code".
I did a search, but fell shy of finding an answer.....
Bell040 is offline   Reply With Quote
Old 03-12-2009, 09:56 AM   #2
King Mouse
King Mouse's Avatar
Drives: EXT
Your dealer should know the paint code. If you know your color is on another car that GM makes, most collision/body shops or paint stores will have the code.
Black is usually black unless it has some metal flake or pearl in it which the Camaro doesn't.
Hope this helps
King Mouse is offline   Reply With Quote
Old 03-12-2009, 10:21 AM   #3
Txturbo
Keeper of the Faith
Txturbo's Avatar
Drives: 2001 Z28 Agressively
Hope this helps
There are a lot of different Black paint codes. Any automotive paint suppliers will have the codes already and any body shop will be able to get them already. I recently inquired about Rally yellow and was able to get the info from my paint supplier.
2010 Camaro SS R6P
2001 Camaro Z28
1969 Camaro SS clone
Txturbo is offline   Reply With Quote
Old 03-12-2009, 11:06 AM   #4
Bell040
Bell040's Avatar
well the dealer thinks.....
"Until you asked what the paint code is, I had not even looked, but when I did, I found that they have changed all paint codes for the 2010 Camaros over to a new system that uses a 3-alpha character system. The particular one for the Camaro you are getting is GBA. However, I have been unable to find anyone who can tell me if that is the same actual paint color as one of the old codes, or if it is an entirely new formulation."
My friend that works at a GMC body shop says that he would bet anything that the paint code is "WA 8555". GM has supposedly used 8555 since the 80's.
…….. he went to his workstation, where they mix up the paint, and GBA did not pull any results.
Old 03-12-2009, 12:39 PM   #5
Hebe4
Hebe4's Avatar
Drives: 2010 Black 2SS/RS M6
2009 GM/Chev color chart.
Hebe4 is offline   Reply With Quote
Old 03-12-2009, 12:40 PM   #6
Bell040
Bell040's Avatar
Well...
It turns out that GBA is the paint code. Sherwin Williams site recognizes it.
sherwin williams # is the 33756
.......yours still says WA8555 ...... hmmmm
maybe they are just renaming the colors and the color codes?
I think I will be safe having the GFX painted the WA 8555 color
Where did you get those???
Old 03-12-2009, 12:55 PM   #7
Hebe4
Hebe4's Avatar
You were almost there.
http://www.sherwin-automotive.com/sh..._ColorBook.pdf
Old 03-13-2009, 12:43 AM   #8
BLUEMARO
A Classical Greek
BLUEMARO's Avatar
Drives: DTS, Bonneville and an SS !
Silver Ice Metallic WA-636R
Imperial Blue Metallic WA-403P
Black WA-8555
Aqua Blue Metallic WA-638R
Cyber Gray Metallic WA-637R
Victory Red WA-9260
Rally Yellow WA-9414
Inferno Orange Metallic WA-502Q
BLUEMARO is offline   Reply With Quote
Old 03-19-2009, 01:22 PM   #9
kingkitse
kingkitse's Avatar
Drives: GMC Sierra K1500 & '69 Camaro
Does anyone know if there is or will be a white version available?
There were rumours on this....
2SSRSinWHITE.....wow
Biertje?!
kingkitse is offline   Reply With Quote
Old 03-20-2009, 12:50 PM   #10
VenomZ302
Live to Win, Dare to Fail
VenomZ302's Avatar
If I understand your question correctly, white is supposed to be available this summer (someone can correct me if I'm wrong on when it's available, but I thought it was summer).
3/13/09 - Ordered Aqua Blue Metallic 2SS/RS M6!
7/13/09 - Built!
8/11/09 - Delivered!
2G1FT1EW2A9124579
Paint your own stripes? blackZbandit Cosmetics and Lighting Modification Discussions 44 09-18-2011 09:22 AM
Crappy paint job Milk 1027 1st & 2nd Generation Camaros 35 02-07-2010 11:54 AM
Factory paint condition jhitson Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 44 04-18-2009 09:11 AM
The Official Thread about Custom Paint! pinkcamaro10 Cosmetics and Lighting Modification Discussions 30 03-28-2009 07:17 PM
