| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
![]() ![]() ![]() ![]() Drives: Camaro Join Date: Apr 2009
Engine Dyno Testing The VMaxx Throttle Body FINALLY!
Sorry for the delay getting you guys data on the throttle body testing, I was making a change to the rocker pedestal designs that slowed down my testing just a little bit.
Thanks to SC2150 for loaning us a Throttle body to test. It was a great looking part no doubt! I really wish I had a good way of testing part throttle throttle response, I bet this thing does well for adding a little extra low end with some of the throttle body bump removed. Here's the procedures we went through to test the T.B. 1-1 1/2 minute cool down in between pulls Baseline Stock TB (2 Pulls) Install VMaxx (2 Pulls) Remove VMaxx (2 Pulls) ![]()
looks like a gain of about 8 hp, and 12 tq
my youtube
my facebook www.myspace.com/1djchampagne www.twitter.com/1djchampagne mods: borla long tube headers, borla atak catback, lingenfelter gt-9 cam, ported heads, ecs base kit running 11 psi on top end, 1" bmr drop spring, aam 3.70 gears, ported throttle body, 160* thermorstat, lethal racing tune 750/641 rwhp/rwtq |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2001 Camaro SS Join Date: Dec 2009
Thanks for the test Jason.
This is on an engine dyno so a chassis dyno showing the power at the wheels will be slightly less. Again, the key to the power gain is breaking the surface tension with the CNC pattern. |
![]() Drives: 2012 ZL1 Join Date: Mar 2011
I love to see numbers that show the facts!! I just put my VMAX on and I could tell the difference instantly........throttle response and low end pull for sure! I know some say they notice no change, but I know I am not imagining it!
Thanks for doing this test!! |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
I'm trying to understand the graphs.
At the top is Day 1 graph, correct? The bottom graph is Day 2 graph, correct? So day 1 graph has the before (without Vmax) and after (with Vmax) numbers on it?
#6 |
Only drives on Sundays
Drives: 11 2SS/RS, Black/Inferno, L99 A6 Join Date: Feb 2011
Wait... wut?
Padre |
#7 |
![]() Drives: 2010 Camaro - BIW Join Date: Mar 2010
![]() That's the graph to pay attention to. The bottom line (blue) is the baseline with the stock TB. The red is the VMaxx TB, hp and torque (sorry they're a bit difficult to distinguish which is which.) The graph is RPM (left to right) vs hp/torque (bottom to top.) Hope that helps! |
#8 |
I'm having a real hard time reading the graph on my laptop. It would be nice if the peak rwhp and peak tq numbers were posted (before and after). So exactly how much peak rwhp and torque did the Vmax make?
3.4 ft. lbs and 3.2 rwhp?
#9 |
Was this on a fully stock car??
#10 |
Not if it's making over 500 HP.
![]() Padre |
#11 |
Pretty sure it is the built motor alone on an engine dyno (correct me if I'm mistaken).
They are also testing it shortly with a ported intake manifold to see how it reacts to the improved flow. |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
Looks like it performs well, where we daily drive.
She is only memory now. |
#13 |
That's correct, it is on the engine dyno so that we can eliminate many more of the variables in the combo, climate, coolant temperature, etc!
#14 |
![]() Drives: 2011 CAMARO SS Join Date: Oct 2010
So on a 580 hp engine there was a gain of about 3 hp then?
2011 CAMARO SS
#15 |
Camaro Owner Since 1987
Drives: 2011 2SS/RS L99 RJT Join Date: Jun 2006
Numbers look good.
Bill ![]() ![]()
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop Rx Catch Can;Rx Breather;Roto-Fab Washer Container VMax Ported RJT Throttle Body XSPower Headers and XSPower 3" Exhaust System Elite Engineering Tunnel Brace, Gorilla Wheel Lock System; Tinted Windows 35%;EFILive Tune ![]() |
#16 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
A highly modified engine on the engine dyno showed a peak Tq increase of 2.5-3.4 ft/lbs and peak HP increase of 2.8-3.2. If one were to translate this onto a stock engine and shown to the wheels, it would be next to nothing.
Halltech Yellowjacket fed Kooks LT's/ Dynomax VT Pfadted (springs/sways) JRE tuned Aint nobody got time for that |
#17 | |
Yes, it was save a lot of confusion if the results (peak RWHP and Peak TQ -before and after) were clearly posted (not in graph form) in the 1st (original post). Many seem confused by the charts and think the results show impressive HP numbers. I believe they are comparing chart 1 (day 1) with chart 2 (day 2). They think chart 1 is without the Vmax and Chart 2 is with the Vmax. When if fact, chart 1 has both before and after results.
#18 | |
Padre |
#19 | |
I never thought a simple dyno test could be so confusing.
#20 | |
So for further clearing up. Day one (top chart), showed a peak 2.5 Tq, and 2.8hp increase, while day two (bottom chart) showed a increase of 3.4 and 3.2 (respectively). Day two graph is with 0.3 more compression. The middle chart shows ONLY the change, from both days, over stock. Stock being "0". It is confusing and took me a short while to grasp the way they displayed the information. I hope this is right and clears up the confusion. At least for me.
#21 | |
Or at least I think so. ![]() ![]() Padre |
#22 | |
Fixed my previous post to mention the compression increase.
#23 | |
![]() ![]() ![]() ![]() Drives: 2012 5.0 Mustang, Brembo Track Pack Join Date: Jan 2011
2012 Ford Mustang 5.0. Brembo, 3:73s Sold
2012 Challenger 392 auto 12:40s 112 stock Sold 2010 1SS, LS3, Cammed, LTs, NT05R,12:20s Sold |
#24 |
![]() Drives: 2010 Camaro 2SS/RS - IOM/IOM Join Date: Mar 2009
Even still, $150 bucks for 3 HP and better throttle response is a great mod. You could spend that money in a lot of worse ways. I'm happy with my VMAX.
L99 with Kooks 1 7/8 headers, Corsa Catback, R2C CAI, 366 RWHP / 380 RWTQ ---- 2010 MY #7539
Justin works as Vice President of Sales at Dealer HD an automotive SEO agency in the Chicago area specializing in automotive marketing and dealer websites. |
#25 | |
| Thread Tools | |
| Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ | AutoAgenda | Exterior Parts & Accessories | 14 | 02-06-2013 08:43 PM |
| Roto-Fab | Cold Air Intakes | Engine Covers | Washer Reservoir Relocation Kit | Fuse+ | AutoAgenda | V8 Bolt-Ons & Tunes | 7 | 07-11-2011 06:50 PM |
| Vararam CAI Testing on Dyno at England Green Racing (Pix, Vids, RESULTS!!!) | TAG UR IT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 113 | 01-05-2011 03:32 PM |
| Camaro ls3 news...true or false? | Dark Knight | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 74 | 06-05-2008 05:29 PM |
