JUICEDMOTORSPORTS
Old 06-14-2011, 10:34 AM   #1
Guzaku
Guzaku's Avatar
Drives: Black 2011 2LT/RS
Foam fun question
Does using a foam gun eliminate bucket washing for the most part? If so which do you prefer?
Guzaku is offline   Reply With Quote
Old 06-14-2011, 10:41 AM   #2
RanDMC
RanDMC's Avatar
Drives: 1LT/SS
The foam gun makes bucket washing easier on your paint since it loosens up the dirt before you start the actual wash. There is no substitue for a two bucket wash, but the foam gun is a good step to add between the rinse and the wash.
RanDMC is offline   Reply With Quote
Old 06-14-2011, 10:47 AM   #3
Tecca
Tecca's Avatar
Drives: ...
No, you will still need to bucket wash with the 2x2 or 2x4 method. The foam gun helps loosen up and soften contaminates before you through you mitt on the car helping to prevent any added imperfections. It also helps with getting soap into those hard to reach areas like the wheel well.
Tecca is offline   Reply With Quote
Old 06-14-2011, 11:52 AM   #4
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
No!! You still need buckets and grit guards to wash appropriately... the foam gun is simply a way to deliver lots of soap to the paint easily, but it does not replace your buckets/grit guards.
Old 06-14-2011, 09:19 PM   #5
Guzaku
Guzaku's Avatar
Thanks for the response guys! Big help
Manual or Auto?--resale value question armando416 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 33 01-17-2012 09:06 PM
Physics Question on 2SS Performance 2SS 5th Gen Camaro SS LS LT General Discussions 33 07-14-2011 06:10 PM
question about the foam gun shad2009 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 5 02-24-2010 04:13 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 07:53 AM
Bored so Ill ask a speculation question :) BLACK SUNSHINE Camaro Price | Ordering | Tracking | Dealers Discussions 13 02-12-2009 12:16 PM
