Old 06-14-2011, 06:54 PM   #1
sgseward
sgseward's Avatar
Drives: 2010 IOM 2SS
Tire size for Hurst Performance wheels
We've been looking at replacing our stock wheels on the 2SS and after looking at just about everything, we're leaning toward the Hurst Performance wheels. These are at the top end of my price range and given that, I'd like to be able to move over the stock P-Zero's (the only have 3k on them) to keep the costs down.
The Hurst wheels are 20x10 vs 20x9 in the rear and 20x9 vs 20x8 in the front. So, the question is will the stock 245s/275s work on these rims? I realize that most tires fit a range, but I just wanted some input....and there's never a shortage of that here!
Steve
sgseward is offline   Reply With Quote
Old 06-14-2011, 06:59 PM   #2
bob vogel
Drives: 2010 rs ss
sell your tires. someone will by them on here.
bob vogel is offline   Reply With Quote
Old 06-14-2011, 07:00 PM   #3
Synner
Drives: not stock
Move the rear 275 to the front and buy a new tire for the rear.
Synner is online now   Reply With Quote
Old 06-14-2011, 08:25 PM   #4
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
Yes, they will fit just fine. I have my 275's on 10" rears and my 245's on 8-1/2" fronts. BTW, I love those Hurst Wheels....wish I could afford them!!! You're car will look wicked!!!
blazzin1 is online now   Reply With Quote
Old 06-14-2011, 11:46 PM   #5
subzero05
Drives: 2010 tbd
that is actually not correct.. The REARS on the Hurst wheels are 20x11 for the Camaro only!
subzero05 is offline   Reply With Quote
Old 06-15-2011, 07:13 AM   #6
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
I wish someone had the exact specs on the Hurst 20x9 and 20x11 wheels. The offsets I've seen reported especially for the rears are way too aggressive to fit 305 or 315 tires without hanging out past the fender. I find it hard to believe Hurst designed these wheels to fit stock tires as the 11" rear is way too wide for a 275 tire.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 06-15-2011, 07:21 AM   #7
kook
kook's Avatar
Drives: 2010 2SS Yellow
I saw the Hurst booth at the Hot Rod Power Tour and both cars had 305 on the rear. They did stick out a bit to far for my liking and I'm guessing if you lower your car much you will have rubbing issues.
Edelbrock E-Force
Stainless Works Lts
Roto Fab CAI
Magnaflow Street Cat-Back
DOD Delete
Forgestar F-14's and Pedders XA + PKG
Custom grind cam from Cincy Speed
ADM dual fuel pump
ADM AF/Boost gauges
FTI 3200 convertor
Hurst shifter
Cincy Speed Build and Tune 540rwhp
kook is offline   Reply With Quote
Old 06-15-2011, 10:32 AM   #8
subzero05
Drives: 2010 tbd
offset bolt pattern center bore
Camaro front 20" x 9" 32 mm 5 x 120 mm 70.6 mm
Camaro rear 20" x 11" 40 mm 5 x 120 mm 70.6 mm
ask as you shall receive!.. They will fit almost flush with the car lowered on an Eibach Coilover kit.. KENJI can give you additional details, pics etc and no they are not designed to fit stock tires, especially the rears
Old 06-15-2011, 03:35 PM   #9
flht99b
flht99b's Avatar
Unfortunately +40mm offset on the 20x11 is 5mm too little. You need +45mm or more offset on a 20x11 for a 305/35/20 or 315/35/20 tire to tuck inside the fender and for the tire not to hit the fender in a bump, especially a lowered car. The same issue with the BBS CH-R wheels exists, their 20x10.5 has a +34mm offset and it too needs 5mm or more positive offset to tuck the 305 or 315 tire under the fender well. Real shame as both the Hurst and BBS CH-R wheels are beautiful but not at the correct offset. Plus they are available and of impeccable quality.
Ed M.
Old 06-16-2011, 11:19 AM   #10
Kenji
Kenji's Avatar
Drives: 2SS/RS M6 SW
No problems with the Hurst wheels here. The car is lowered on Eibach coil-overs (about 1" to 1.5" in the rear at the moment and in the photos). The fenders were not modified and there are more than our fair share of bumps and potholes in the LA area. Never had any rubbing . I'm running Michelin Pilot Sport PS2 Tires 305/35ZR20/XL on the rear (255/40ZR20/XL front) and don't think they look like they stick out too much... but judge for yourself:
Kenji is offline   Reply With Quote
Old 06-23-2011, 01:19 AM   #11
autoguy
autoguy's Avatar
Drives: 80Z, 99 SS,10,11 SS Pace, 13 ZL1
I have a set of these Hurst Wheels for my Camaro and they are 20 x 9 and 20 x 11. I will be running 275/40 front and 315/35 rears with a special surprise. I should have the tires in about two weeks. My Hurst Shifter came in today, and I have the Hurst Equipped Badge to go along with it and the wheels.
autoguy is offline   Reply With Quote
Old 06-23-2011, 01:24 AM   #12
autoguy
autoguy's Avatar
Subzero, what is it I hear Hurst is getting a Festival Pace Car from indy? One of only four that had the LS3/6 Speed combo. I hear.
Old 08-15-2011, 07:09 PM   #13
Toyaholic
It's a sickness!
Toyaholic's Avatar
Drives: '69 442 Vert
Well.... did the 315's work on the Hurst wheels? What offsets did you get?
Toyaholic is offline   Reply With Quote
Old 08-15-2011, 11:03 PM   #14
autoguy
autoguy's Avatar
Fikse Wheels the leader in custom fit wheels 6061-T-6 Aircraft Grade Billet Aluminum Xplosive Performance Wheels / Tires 8 07-09-2011 09:52 AM
Wheel and Tire optimization for lowered vehicles PfadtRacing Wheels and Tires Talk Sponsored by The Tire Rack 12 06-28-2011 12:31 PM
Tire Size for winter tire homer2004 Wheels and Tires Talk Sponsored by The Tire Rack 12 11-09-2010 07:00 PM
Need some help in drag wheels size jo0oker Wheels and Tires Talk Sponsored by The Tire Rack 0 09-15-2010 01:12 PM
Tire chain/cable solution for the 20" wheels? Jakefeb3 Wheels and Tires Talk Sponsored by The Tire Rack 17 12-16-2009 01:37 AM
