BORLA
Old 06-15-2011, 11:51 AM   #1
Slow2011SS
Drives: 2011 Camaro 1SS
Clutch noise when engaged/disengaged
Alright,
So like many of you out there who have this issue I got my dealership to open a TAC with Chevy.
Check out the image.
This is just informational for the rest of you out there. I still don't like the noise or the answer provided but if it breaks at least a case is out there.
Slow2011SS is offline   Reply With Quote
Old 06-15-2011, 12:15 PM   #2
Russell James
Russell James's Avatar
Drives: Camaros
Is this noise while the car is sitting still? Or moving? Turning slow?
Most of them are quite clunky if clutching while rolling slow, especially if turning slow. Driveline clearances and torque suddenly released can make everything clunk. Especially with an LS diff, the clutches will be dragging a bit on slow turns and you can get a clunk/pop when everything releases. Changing the diff lube and 10 slow figure 8s can help with that.
Old 06-15-2011, 12:18 PM   #3
Ronn
Ronn's Avatar
Drives: 2010 Camaro
Mine does the same thing
1SS / RS / M6 / IOM / Black rally stripes / Polished wheels
It's a high school prom, it's a Springsteen song, it's a ride in a Chevrolet...
Ronn is offline   Reply With Quote
Old 06-15-2011, 12:30 PM   #4
Slow2011SS
It happens when you are in motion. Slow speeds first and second gear. Sounds like the exhaust is rattling however it is not. I did some research and there are a few posts about it however they got the run around. This is simply information for those who have doubts that its normal. When it breaks we can all utilize the case number listed to have it updated with Chevy.
Old 06-15-2011, 12:47 PM   #5
Russell James
Drives: Camaros
I thought it was strange too on the first M6 performance car I bought. Having owned many since in the past couple decades - they all do it. It's exactly what the dealer told you, driveline clearances clunking when torque is released from the driveline. Those clearances have to be there for the trans and diff to work right.
You can sometimes hear similar clunking by shutting the engine off while the clutch is out with the trans in nuetral. Also - normal.
Old 06-15-2011, 01:14 PM   #6
nancygrl
銀幽霊
nancygrl's Avatar
Drives: '17 Z71 Truck
+1....Yes, it's annoying, but every 6spd I've ever had before has been this way from day one also.
Previous rides: '17 ZL1 M6,'16 2SS/A8, '15 1SS/1LE/M6, '13 Hotwheels RS, '11 2SS/M6
nancygrl is offline   Reply With Quote
Old 06-15-2011, 01:20 PM   #7
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Collective driveline slack? Mine does this too from day one with 6 miles on it. IRS and 2 piece driveshaft could all be contributing.
Old 06-15-2011, 01:37 PM   #8
DarkObsession
Drives: 2011 Camaro SS2/LS3
Mine does this too and does it even when stopped. You can also very faintly feel the vibration in the shifter when it happens.
I am going to visit my parents very soon and my dad is the service manager of a Chevy dealer (and previous to that, master, ASE certified mechanic). He is going to check it out for me and obviously, he's going to be wanting to err on the side of fixing it for me
I will let you all know what he finds when he checks it out.
2011 Chevrolet Camaro SS2/LS3 - Pretty much bone stock (SLP SkipShift Eliminator, GTO clutch fluid reservoir mod) - 13.025 @ 110.492 MPH (12s?? )
1998 Pontiac Grand Prix GTP (retired) - Cam, exhaust, CAI, 12 PSI, tune - 13.465 @ 101.04 MPH
DarkObsession is offline   Reply With Quote
Old 06-27-2011, 08:24 PM   #9
DarkObsession
Update from my visit here: http://www.camaro5.com/forums/showthread.php?t=155282
Old 01-07-2012, 03:56 PM   #10
stlrammer
stlrammer's Avatar
Drives: 2017 2LT/RS Yellow
Mine has done it too since day one. Always in low speed with torque on tranny (going up steep hill slow and pressing in clutch reproduces it almost 100% of the time.
stlrammer is offline   Reply With Quote
Old 01-07-2012, 04:08 PM   #11
scythezo6
Virologist in the making
scythezo6's Avatar
Drives: 2010 VR SS/RS LS3
I've had this since day one. Its super annoying you just have to adapt and learn to shift to avoid it. I slip sometimes and have that paddle sound at low speeds in 1st and 2nd but if you let off the clutch slower it avoids it. Even when stopped. Roll the windows down and put the car in neutral and press/depress the clutch pedal quickly and you hear it.Super annoying though.
Old 01-07-2012, 08:31 PM   #12
jtvst4
Drives: 2010 Camaro 2SS / RS
mine does it too....when coasting down a hill very slowly in 1st and then pressing in the cluth. Seems as if it only doesit when there is "drag" on the tranny, such as going slowly up a hill, or coating down a hill slowly.
jtvst4 is offline   Reply With Quote
Old 01-07-2012, 08:32 PM   #13
Mud
In Mud We Trust
Mud's Avatar
Drives: 2010 Camaro 2SS/RS LS3
One of those quirks of this particular transmission.
Years from now, it will be affectionally mentioned on Mecum auto auctions.
2010 2SS/RS, LS3
-Hurst Shifter
-American Racing Torq Thrust/Anthracite
-CAI Intake
Mud is offline   Reply With Quote
Old 01-07-2012, 11:29 PM   #14
bajamoon
bajamoon's Avatar
Drives: 2014 Subaru WRX
Same here. Researched when I first got it and found it to be normal.
bajamoon is offline   Reply With Quote
Front End Knocking Noise Dave Sparkes Camaro Price | Ordering | Tracking | Dealers Discussions 4 04-14-2011 08:06 AM
Clank noise when I enguage clutch. fearless Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 23 12-10-2010 07:10 AM
Clutch Problem phenixdragon Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 20 08-22-2010 11:51 AM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
