Old 06-16-2011, 11:28 AM   #1
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
plugs or a new tire?
On the way back from Oshawa my TPMS starting whining about the left front. A great feeling when you don't have a spare. I was able to stop and put air in it and it held all the way home, but lost pressure again after sitting for a couple of days. I had to take it to the dealer for PDIM issues and had them also check the tire. Here's what they pulled out of the tire between the tread, between the center and inside edge, about the same distance apart as shown. They said they could only plug from the outside or maybe I should think about a new tire since they weren't sure about plugging a Z rated tire. Due to time issues I had them plug it. They didn't think a patch on the inside to cover both holes would have worked, and I would have had to take it elsewhere for that anyway.
Do you think it will be OK or should I get a new tire? (Keys are there for size ref LOL)
Smoked tail lights/ZL1-1LE 3rd brake
Rotofab cai
Old 06-16-2011, 12:05 PM   #2
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
Have the tire patched from the inside, and you will be fine. As long as the damage was not in the side wall.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 06-16-2011, 12:10 PM   #3
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2010 Camaro 2SS A6
Dealer clueless, take it to a tire store. The tire should be plugged and patched from the inside as well.
Rock-It Man is offline   Reply With Quote
NEW OEM GM tire pressure monitors availabe at GMPARTSHOUSE.COM patrickt Wheels / Tires 76 08-08-2012 10:35 PM
Tire pressure computer issue UT-Engineer Wheels and Tires Talk Sponsored by The Tire Rack 7 02-13-2012 07:18 PM
Reccomendation on Road coarse/Autocross Tires michael's maro Wheels and Tires Talk Sponsored by The Tire Rack 21 09-06-2010 06:52 PM
Exhaust bolt in tire = bad day GPD151 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 07-30-2010 12:56 AM
Are they rims or are they wheels?? topgun1 Off-topic Discussions 28 07-07-2010 12:02 AM
