Old 09-17-2011, 05:57 PM   #43
TexasCamaro5
Bayou City Muscle Cars
Drives: 2010 Camaro 2LT/RS
Finally got my car dyno'd again after the long-tubes and cat-back were installed.
First is the baseline numbers from October of last year when my camaro was bone stock running 87 octane:
Date: 10/16/2010
Shop: A.R.D.
Dyno: Dynojet (Can't remember which model number it is but I do know it has a history of low readings)
Gear Pulled In: 4th
Pressure: 30.28 in-Hg
Humidity: 23%
Temperature: 89 *F
STD: 1.01
Peak RW Horsepower: 219.73 hp
Peak RW Torque: 197.35 ft-lb
Now with my upgrades this year:
Upgrades: Cold Air Inductions,Inc. Cold Air Intake
VMax Motorsports CNC Ported Throttle Body
ADM Air Scoop
Roto-fab Window Washer Bottle Kit (to get the stock one of the way of the CAI)
Stainless Works Silver Ceramic Coated 1-5/8" Stainless Steel Long-tube Exhaust Headers with High-Flow Cats
Solo Mach X-LLT Cat-back Exhaust with J-pipes
Trifecta Engine and Transmission Tune
93 Octane Fuel
Date: 9/17/2011
Shop: A.R.D.
Dyno: Same one as before
Gear Pulled In: 4th
Pressure: 30.24 in-Hg
Humidity: 39%
Temperature: 89.63 *F
STD: 1.02
Peak RW Horsepower: 249.28 hp
Peak RW Torque: 242.92 ft-lb
Not as much horsepower as I was hoping for, but compared to the stock numbers it is a good increase. The increase is about 30 hp and 45 ft-lb of torque at the rear wheels. Not sure exactly how to figure out what I'm making at the crank, but since my transmission and drivetrain is still stock as before, then if I take into account what the SAE rating is at the crank, then the efficiency of the driveline is 70.5% for horsepower and 71.22% for torque. Dividing my new numbers at the wheels by that, I should be getting about 353.2 hp and 341.3 ft-lb at the crank. Someone can correct me if I'm off on that.
The next thing I'm going to look at doing on this car is upgrading the torque converter and swapping out the open differential for a limited-slip and 3.73 gears before considering nitrous. I'll be able to get 1/4 mile times at the Texas Camaro Nationals in Sealy,Tx that's coming up in 2 weeks.
TexasCamaro5 is offline   Reply With Quote
Old 09-17-2011, 06:00 PM   #44
TexasCamaro5
Almost forgot, it's a 2010 2LT/RS A6 with stock 20-inch wheels and Pirelli P-Zero Summer Tires.
Old 09-18-2011, 06:17 PM   #45
bmorecam
If I remember correctly I think our member rolnslo dynoed at ARD a while back which use 248x and got the same low stock result around 225-230rwhp, but I think yours is the lowest I've ever seen a stock camaro dyno but what matter here the most is how much you have gained and the gain look really good Do you happen to have the graph from both of the runs so we can see how much gain there is off peak.
Old 09-18-2011, 06:31 PM   #46
TexasCamaro5
Yeah I took photos of the dyno sheets, but for some reason I can't figure out how to embed those images in a post. So I'll just link back to a post I did on the H-Town Camaro Club website:
http://www.h-towncamaroclub.com/showthread.php?1695-Finally-got-my-dyno-numbers!
For some reason Camaro5 asks for a URL link for photos and I don't use Flicker or Photobucket.
Old 09-18-2011, 07:15 PM   #47
KMPrenger
KMPrenger's Avatar
TexasCamaro, I think you can be happy with those numbers. Yeah they are not the best "for show" numbers because they seem low, but its obvious it is a low reading dyno. On a different dynojet you should be in the 270s or higher forsure with those mods.
35 - 40 HP gain with those mods would have been nicer, but 30 is still a good gain. I'd suspect your gain in the mid to mid-upper RPM range is higher than that.
Old 09-18-2011, 07:30 PM   #48
TexasCamaro5
Yeah I'm not really worried about. Definitely will be looking at upgrading the drive train next (torque converter, differential, gears and maybe drive shaft) and maybe a lighter set of wheels.
Old 10-02-2011, 09:36 AM   #49
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
2WD 450DS Dynamometer capable of graphing up to 1200 HP (as per their website)
2-22-2011 12:51 PM 35.1 °F 72% 30.09 in
pulls:
1. 4th
2. 3rd
3. 3rd
waiting for cooler weather before putting back on the dyno since loading vince's tune. will update with new dyno soon.
hapisok is offline   Reply With Quote
Old 10-02-2011, 10:02 AM   #50
bmorecam
NIce numbers hapisok. What was your exact mods so when I update the list I can know for sure.
Old 10-02-2011, 03:54 PM   #51
av3206
Drives: Camaro
i am confused how come GM tells me i have 323 HP before upgrades i am new to all this...
av3206 is offline   Reply With Quote
Old 10-02-2011, 04:29 PM   #52
Beauwulf
Beauwulf's Avatar
Drives: '10 LT RS A6 & '04 Acura RSX Type S
GM quotes numbers for the engine at the crank shaft. Dyno numbers are taken at the wheels. All the stuff in between absorbs power so the wheel HP is always less.
Also, different dynos read different HP ratings even on the same engine... even from day to day. You can only compare readings taken from the same dyno to check if your mods actually gained HP.
Beauwulf is offline   Reply With Quote
Old 10-02-2011, 06:03 PM   #53
hapisok
hapisok's Avatar
thanks bmore. my mods at the time: auto tyranny, injen cai, bbk lt's w/hi flow cats, ark n type II exhaust. still need to get on there since the tune, im really interested to see how much that pulls things together. i'll keep you posted.
Old 10-02-2011, 06:05 PM   #54
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
My first pull "Stock" in Dec. 2010
Manual or Auto:Manual
Mileage at the time of dyno:300
3rd/4th gear pull:3rd
Type of dyno and Model:DynoJet
Date/Time/Temp: 46*
Modification at the time of dyno:Stock
Dyno result:257.4 RWHP / 240.2 RWTQ
My second pull July 2011
Mileage at the time of dyno:4300
Date/Time/Temp:98* / 85% Humidity
Modification at the time of dyno:VR intake / MRT V1
Dyno result:246.3 RWHP / 230.3 RWTQ
It was a very hot day out and I had drove 75 miles to Vengeance Racing and the car was heat sunk. The crew at Vengeance was pleased with the performance seen with the high temps and the VR intake and how it still performed. Plus no fan was used during the runs. I was upset with the results at first but then realized it was some good pulls. Can't wait till the winter to do some more runs like my first pulls. I know I'll see way better number then! Can someone correct my numbers to see how it would of ran in the same temps as my first run?
Can't_C_Me is offline   Reply With Quote
Old 10-02-2011, 10:35 PM   #55
bmorecam
Can't C me, if those numbers are not ASE corrected already you can look at the instruction I posted on how to calculate ASE numbers on the beginning of the page and see how it differs from stock run vs your latest run with VR since there's a huge temp difference.
You are the 2nd one that dynoed in lower with VR installed so I guess VR is just not dynoable because it surely does perform well on the street.
Old 10-02-2011, 10:42 PM   #56
KMPrenger
KMPrenger's Avatar
Sure doesn't seem like VR dynos well....but it sure feels good out on the road.
Roto-fab CAI dyno results Roto-fab 1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 102 07-30-2016 08:21 PM
Dyno numbers are in after heads,Maggie install papabearcamaro Forced Induction - V8 17 05-14-2011 09:36 PM
Some L99 Dyno Numbers JLBIII Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 02-20-2011 02:34 AM
ls3 mustang dyno numbers 8secpumpgas Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 06-16-2010 01:38 AM
dyno numbers for my build are in (cam + nitrous) mark_p Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 09-10-2009 11:22 AM
