Jason 98 TA
Old 06-16-2011, 06:46 PM   #1
STEALTH_MODE
I have a V6, so what?
STEALTH_MODE's Avatar
Drives: Top Secret
Life expectancy of a turbo camaro
Any educated guesses of how long a v6 camaro will last with aftermarket turbo?
saying your not over doing it with boost
MODS:BBK longtube headers, DynoMax Ultra Flo axle back, K&N Aircharger CAI, H&R Springs, Custom Trifecta tune (Torq) and a whole lot of black!
STEALTH_MODE is offline   Reply With Quote
Old 06-16-2011, 06:56 PM   #2
ARMYRockyMtn
ARMYRockyMtn's Avatar
Drives: 2010 Camaro V6 Red Jewel Tintcoat
Honestly, the "bad" parts come to surface when pushed but if you're not too aggressive with Boost, there is no reason why it shouldn't be an everyday driver.
ARMYRockyMtn is offline   Reply With Quote
Old 06-16-2011, 07:37 PM   #3
Pt_killa
Pt_killa's Avatar
Drives: Black 2010 Camaro V6
7000 daily miles and running!
Pt_killa is offline   Reply With Quote
Old 06-16-2011, 07:39 PM   #4
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
If its done right there should be no problems at all. You do know that some cars come with turbos from the factory.
SUX2BU is offline   Reply With Quote
Old 06-16-2011, 09:06 PM   #5
STEALTH_MODE
Drives: Top Secret
Yah I know theres a lot of turboed cars from factory but since it's it will be aftermarket, the engine isn't built around turbo but I'm sure these engines are great
Old 06-16-2011, 10:10 PM   #6
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
A lot of those cars don't have any different internals than the LLT. Just don't get to radical and it should last. Like PT said he's put 7K on his. I've put 3K on mine and who knows how much Z_Madness and Jim505 have put on theirs. Change your oil more frequently and use good synthetics and you will probably have no more issues than a modded NA car. Try to push it too far for just a few more HP and then you'll have problems.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 06-17-2011, 01:24 AM   #7
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
As GGG mentioned above, properly built and maintained, there is no reason for the V-6 with an aftermarket turbo to not last a long long time...
All mechanical things have a duty cycle... The harder you push something, the shorter time it will last.... having said that, with proper care, and a good well planned build, you should have years of fun driving from this set-up...Change the oil frequently, and use good quality oil and fuels at all times...
First and foremost, find a good reputable builder... talk to them and listen to the answers... Try to find one that will listen to you and discuss the build rather than preach to you what you need...
Have fun if you decide to go this route... I'm having an absolute ball with mine.... though I have two extra cylinders... the principles are the same...
Old 06-18-2011, 03:31 AM   #8
8cd03gro
Drives: 2005 STi corn fed
Like everyone else said - properly maintained you'll be fine. A few things to keep in mind though.
-Change your oil more often, ~3,500 mi
-Shell out the extra cash for a reputable tuner
-Specifically tell your tuner this is your daily driver. You want a safe, reliable tune, don't go chasing numbers on the dyno.
-Don't tune for 93 if you can't get it everywhere around you.
-Learn to monitor any gauges you may have. Oil pressure, EGT, wideband O2, boost, etc. all can indicate a problem before it becomes catastrophic. A cracked ringland or blown ring alone is better than spun bearings and bent valves along with them.
Most importantly, if you can't afford to rebuild, don't do it. Some will tell you that you won't have a problem, but you MIGHT be that unlucky soul. The chances aren't high, but you don't want to end up with a blown motor and no warranty, so make sure you will be financially able to rebuild just in case you have to.
8cd03gro is offline   Reply With Quote
Old 06-18-2011, 05:34 AM   #9
CC Performance
Drives: 99 Camaro SS, 79 z28, 70 GTX
GM wont do it is all I will say. Engines built for boost use different internals and tolerances .... Can you get away with it... yes some do.. how long will it last ? no one can truthfully say.....
CC Performance is offline   Reply With Quote
Old 06-18-2011, 09:49 AM   #10
GretchenGotGrowl
But they used the same setup as other FI cars on these. They have high silicon pistons, forged rods and cranks, etc... This is the same setup the Mazda Speed 3s and Cobalt TCs have. It will take some boost without issue. Just don't over do it.
Old 06-18-2011, 10:50 AM   #11
Beauwulf
Beauwulf's Avatar
Drives: '10 LT RS A6 & '04 Acura RSX Type S
GM did do it! Ask Jay Leno...
Beauwulf is offline   Reply With Quote
Old 06-18-2011, 10:59 AM   #12
CC Performance
Honestly I'm not sure why people mod the v6 anyway... its there to save gas mileage is my thought, why mess with that. Get the v8 if you want more power
Old 06-18-2011, 11:05 AM   #13
Beauwulf
Beauwulf's Avatar
You might as well go back to the V8 forums... that attitude isn't welcome here!
Old 06-18-2011, 11:54 AM   #14
GretchenGotGrowl
Tell that to the guys these cars!
http://www.carsession.com/car-news/1...n-r35-gtr.html
http://www.mx6.com/forums/australia-...ze-gemini.html
There is nothing magical about the number of cylinders. If more was always better then we'd all have V16s. It's about displacement (natural and effective) and efficiency. The LLT is more efficient that either L99 or LS3 and with FI can have larger effective displacement. Hopefully that clears it up a little for you.
