Centerforce Clutches
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 06-16-2011, 10:50 PM   #1
Smoky10
Drives: 2010 Camaro 2SS
Drives different after cam install
I got my cam installed today. My car was also dyno tuned and setup for this cam. My question and reason for starting this thread is should the car drive slightly funny? Example I started the car and drove to a red light about 100 yards away and it died. Then I drove it home from the shop it was tuned at, and as going through the gears sometimes there was a little hesitation. I called the tuner after it died the first time and he said that the computer was just relearning itself. But she doesn't feel just right, shifting into the gears sometimes is very nice and smooth other times the motor kind of bucks. Just wanted to hear some opinions.
Thanks in advance,
Brandon
Smoky10 is offline   Reply With Quote
Old 06-16-2011, 11:02 PM   #2
Juiced1
JUICED MOTORSPORTS
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
Bad tune.
Get more Power per Dollar!!!! We carry all the hot new products for your 5th gen! CAI, Roto-Fab, Solo, Corsa, MBRP, ARH, Stainless Works, MRT, SLP, Procharger, Whipple, BMR, Diablosport, Superchips, Street Scene, VFN Fiberglass and much more. Contact us for your Camaro5 discount today!
Call us at 224-63-JUICE - 224-400-5793
Juiced1 is offline   Reply With Quote
Old 06-16-2011, 11:03 PM   #3
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
tune is wrong,, should not be any stalling or hesitation and the computer does not need any learn time after it has been tuned,, all the learning would have been done before you got the car back
Old 06-16-2011, 11:06 PM   #4
fourmz
Fourmz
fourmz's Avatar
Drives: 2010 2SS/RS 1968 Firebird 1994 Z28
Get it re-tuned
Black-in-Black/Blue out 2010 2SS/RS LS-3 -Magnacharger TVS2300,OD cog belt drive, Janetty smooth idle blower cam,ID-850 injectors,ZL1 fuel pump,MSD boost a pump, Janetty custom tune,Doug Thorley long tube headers,Borla S Axle back,C.A.I. Intake, Roto-Fab Big Gulp Scoop, Scoop,Eibach pro kit plus, BMR cradle/diff bushings, Barton Shifter, Boss 339 20" wheels,Painted heritage grille, Sparks Restoration Inverted blue/black SS emblems, Seibon BB carbon fiber hood, ZL1 front bumper conversion.
fourmz is offline   Reply With Quote
Old 06-16-2011, 11:13 PM   #5
mikeSS
mikeSS's Avatar
Drives: 2013 E92 M3
a tune problem,
any ways not to high jack the thread. but could somebody answer a quick question for me. after my cam install i notice my car would rev past stock limit. does the new cam shaft give me a little higher red line now ? again don't mean to jack thread.
Old 06-16-2011, 11:20 PM   #6
camaro1
camaro1's Avatar
Originally Posted by mikeSS View Post
a tune problem,
rev limiter is in the tune,, your tuner raised the rev limit,, you can raise the rev limiter with a stock engine and run it to 7000+ rpm but its not going to make any power at that rpm or last long
"RED LINE" has more to do with the total engine build more than just the camshaft,, a built engine that is balanced, better oil system, lighter valve train can rev higher and safer than a stock engine with just a cam
Old 06-16-2011, 11:26 PM   #7
mlee
www.Camaro5Fest.net
mlee's Avatar
Drives: Number Twenty-Three
What are the specs on your cam?
Old 06-16-2011, 11:35 PM   #8
mikeSS
mikeSS's Avatar
Drives: 2013 E92 M3
ok makes sense, just making sure. thanks
Old 06-16-2011, 11:36 PM   #9
Originally Posted by Juiced1 View Post
Bad tune.
+1
Old 06-16-2011, 11:45 PM   #10
Smoky10
Well guess I need to take it back and have it adjusted. Or something...thanks for ya'lls quick replies.
Old 06-17-2011, 12:13 AM   #11
mrh923
mrh923's Avatar
Drives: 2011 Camaro 1SS/M6 Cyber Gray Met.
Was this done by Jason? Hope you get it resolved soon man.
2011 1SS/LS3 M6--Vararam CAI-Corsa catback-Dynatech LTs-RX Catch Can-Vmax ported TB-Eibach Springs-Night Fury Camshaft- 486RWHP/458 TQ
mrh923 is offline   Reply With Quote
Old 06-17-2011, 02:20 AM   #12
Smoky10
No I did talk to Jason tonight though and I may take it to him, but I had it done by a shop in P'cola.
Old 06-17-2011, 03:33 AM   #13
hollandtwin27SS
Drives: 2011 Camaro SS VR/w pw stripes
Bad tune it should start right up and not die at all
ETMC Stage 3 with Stage 2 Blower cam,Valve Spring upgrade to Dual Valve Springs,lifters,pushrods, BFE 1 7/8 headers to 3" pipe non catted, Corsa Exhaust, PP Throttle Body,RotoFab CAI,Elite Engineering Catch Can,Pfadt springs, sways, lower control arms, Hotchkis Maxx Brace.474RWHP. Hendrix Twin Carbon Clutch Kit, One piece aluminum DriveShaft.
hollandtwin27SS is offline   Reply With Quote
Old 06-17-2011, 04:12 AM   #14
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Well if your tuner said it was fine and you can get it to Jason that would probably be a better deal for you.
A word of caution, if it is really acting up you may want to have it flat bedded to Jason to make sure you are not damaging you motor.
Scott@Bjorn3D is offline   Reply With Quote
Old 06-17-2011, 04:22 AM   #15
mrh923
mrh923's Avatar
Ahh okay xxx. I haven't had any issues with Jason tuning mine, so I hope he can fix you up. I'll see you at the grill and growl.
Old 06-17-2011, 07:45 AM   #16
camarohead
camarohead's Avatar
Drives: 2010 ss rs ls3 red-white rallys
wow, thats a long way to tsp...there's got to be a good tuner closer...
eps cam 226/234 lsa 113+2, bfe 1 7/8 headers, rotofab cai, katech oil pump, 444 rwhp, 411 rwtq, eps tune, Blanchard performance install
camarohead is offline   Reply With Quote
Old 06-17-2011, 08:02 AM   #17
Slowhawk
Drives: 1999 Trans Am
First of all we need to know what Cam is in it. Some cams will not run smooth in low rpm area's. If the bigger cams ran like stock then nobody would install the smaller cams.
I do agree that it should not stall and the throttle should have a smooth operation.
Call Phil on here that tunes out of Tampa. He is probly the best LSX tuner in Florida.
Slowhawk is offline   Reply With Quote
Old 06-17-2011, 08:20 AM   #18
Tampa Tuning
Like us on Facebook!
Tampa Tuning's Avatar
Drives: C5 corvette/ 2012Dodge hemi Charger
Each time I adjust the MAF in the drivability portion of my tune, I reset the fuel trims. Sometimes guys forget to do that.
With a cammed car, if they tuned the car when it was warmed up, it can have cold driving issues till it warms up.
If it still has the stalling issue , he may have to adjust the throttle cracker and idle timing slightly to help prevent it from stalling.
It does sound like it still needs a little fine tuning to make it drive better. The bigger the cam, the harder it is to tune on the low end of the RPM range
Tampa Tuning is offline   Reply With Quote
Old 06-17-2011, 08:43 AM   #19
Unreal
Drives: 2006 Z06
Like they said above, depending on the size of the cam the surging/bucking could be as good as it gets, or need more work. Large cams don't like low RPMS so you may have some surge below 2000rpm. Car should not be stalling though.
Nick
2006 Corvette Z06, LSX427 ECS Ysi
2012 Mustang GT
Old 06-17-2011, 09:05 AM   #20
xxlbeerz
xxlbeerz's Avatar
Drives: 2010 Black on Black
Mine would almost die and backfire a couple times on the first day, never completed died though. Still does it occasionally. I still don't know if it was the tune/cam, or me not being used to the difference. Scared the shit out of me though when pulling out into traffic and having the car almost die then spring back to life!
I do have to keep my RPM's a bit higher now for smooth take off. I think I need a retune as well though, so I may be a bad indicator.
xxlbeerz is offline   Reply With Quote
Old 06-17-2011, 09:47 AM   #21
camaro1
camaro1's Avatar
sounds like your tune needs some work also.
Old 06-17-2011, 10:28 AM   #22
qtr-camaro ss
qtr-camaro ss's Avatar
Drives: Orange CAMARO SS/RS
I have the same problem .. I don't know my cam space, the guy who build my car would not give it to me.
qtr-camaro ss is offline   Reply With Quote
Old 06-17-2011, 10:32 AM   #23
KMSRS2SS
I lurk
KMSRS2SS's Avatar
Drives: 2010 SS/RS
It should never stall...ever. Do you feel the hesitation during acceleration? The hesitation could be the computer adjusting to the new found power. You rarely notice the nannies kicking in on a stock car but it is very noticable in a cammed car. I wouldn't get on it too crazy until the car is tuned properly, but you could turn the nannies off if you are still driving it to see if the hesitation goes away.
460 at the wheel so far...
VMS Stage 2.5 Camshaft Kit- Comp cam LSA 114,227/239, .613 .623, RotoFab CAI, VMS ported intake manifold,Kooks 1 3/4" headers with HF cats, Corsa Catback, VMS custom dyno tune,TechAFX engine hose relocation kit, DSS 1400 hp axles, BMR toe rods and links, LS9 Clutch, Hurst short throw with roll out, Liberty Gear built tremec 6060.
KMSRS2SS is offline   Reply With Quote
Old 06-17-2011, 01:12 PM   #24
Smoky10
To those asking what cam it is. It's a 231/236 TSP cam.
Every time he ran the car and adjusted his tune he let the car cool off for about 30 or 40 minutes. I will also take it back to him and ask him to make some adjustments. Also someone has suggested that I should come see you. Would you mind hitting me up with a PM with your price to adjust me car?
I actually did turn all the nannies off, and left them on. I also made sure to keep the RPMs up. But was told that the car shouldn't buck or serve above 1600RPMs, but it still acts funny. Also taking off from a dead stop is the only time that I don't feel any problems.
Old 06-17-2011, 01:28 PM   #25
Smoky10
Tuners name is John Weaks, and he tuned using EFI live.
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 207 06-07-2013 11:09 PM
Lingenfelter GT11 Cam and header install mr_mcse2004 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 27 04-24-2013 11:46 AM
SNL Performance Cam Install Special Matt@SNLPerformance USA - Texas 1 02-07-2011 09:25 AM
cam install??? Cully Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 19 12-23-2010 01:30 PM
Tools for cam install Bee Kool Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 12-11-2010 02:21 PM
