JDP Motorsports
Old 06-18-2011, 02:25 AM   #1
8cd03gro
Drives: 2005 STi corn fed
e85 f/i 6?
Have any of you guys run ethanol in a forced induction 6 yet? I searched around and couldn't find any. Is the direct injection's hpfp limiting, or have you not seen those limits yet? Just interested in what kind of numbers you guys might see on e85 with any of the turbo setups available.
8cd03gro is offline   Reply With Quote
Old 06-18-2011, 08:51 AM   #2
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Just got the first tune for E85. We run out of fuel with gas in FI setups, so E85 won't be an viable option for us until we get that issue resolved.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 06-18-2011, 09:03 AM   #3
bmorecam
How much more fuel is needed with the turbo setup gretchen??
Old 06-18-2011, 09:13 AM   #4
GretchenGotGrowl
At 6 psi I've maxed out the HPFP. I don't have my logs here (at work) so I'll have to look up what the exact number is. Rough guess would be 60-65% more than a stock car.
Old 06-18-2011, 09:30 AM   #5
bmorecam
wow!! never realized it needed that much more fuel. Can't belive no one come out with aftermarket injectors yet.
Old 06-18-2011, 11:00 AM   #6
GretchenGotGrowl
Just a guess, but let me check my logs. I don't think we've hit the limit on the injectors, yet, but that may be right around the corner. We've got to just tackle one thing at a time so we know what the limit of each piece is.
Old 06-20-2011, 12:46 PM   #7
8cd03gro
e85 requires 30% more fuel for the same amount of energy, but the heat dissipating properties and resistance to knock allow waayyy more timing and more boost safely. Gretch, is it the hpfp that's maxing out, or are the injectors simply too small?
Old 06-20-2011, 07:16 PM   #8
GretchenGotGrowl
Looks like the HPFP. Should know for sure in a couple of weeks.
Old 06-21-2011, 04:47 PM   #9
bmorecam
I think its the fuel pump.. even at 30-40% more fuel with my e85 my fuel pressure is already almost maxing out. Not quite there yet but I can imagine for your turbo setup.
Old 06-21-2011, 04:50 PM   #10
Gxproadster
It's just a barbie car
Gxproadster's Avatar
Drives: Solstice gxp
I feel gretchens pain but my fuelpump dosnt need 60 percent more it can handle it till about 130-140mph then it runs out :-( some cobalts don't have the problem at all and go to 160
Trifecta e85 tune 331whp 400wtq :-D
Gxproadster is offline   Reply With Quote
Old 07-21-2011, 07:31 PM   #11
8cd03gro
Old thread, but have you guys tried running a more gasoline heavy blend? I have seen almost all of the benefit of e85 on an e47 blend, but it requires less fuel. You won't have quite the effective octane rating, but the cooling characteristics will still be great and you will still be able to bump the timing way beyond gasoline tables. Something to think and talk to your tuners about. . .
Old 07-21-2011, 08:25 PM   #12
dthomp2366
Drives: 2008 Chevrolet Cobalt SS Turbo
Us cobalt guys hit this wall with bigger turbos and one manufacturer made a secondary fuel rail to help.
2008 SS/TC Black w/ Black Int. - LNF FTW
Bad-Mab Downpipe | K&N SRI | Trifecta Tune @23psi | Treadstone TR-8 Intercooler | TTR Engine Mount | Shorty Antenna | Debadged Rear and Dash w/ Tinted Tails / Plasti Dip Rims
Pioneer 6 3/4 - 6x9 components - Pioneer Center Channel Speaker - Polyfilled Stock Sub Box
dthomp2366 is offline   Reply With Quote
Old 07-22-2011, 11:17 AM   #13
bmorecam
I know alot of folks who have gone that route usually around e50-e60 and still get great result requiring less extra overall percentage of fuel needed to run from the usual 30-40%. You can then def turn up the boost and dont have to worry about knocking something I noticed you turbo guys been going through.
Colorado members check in here 2010 SS RS USA - Rockies / Midwest 8828 08-27-2017 08:48 AM
E85 TUNE RESULT!! bmorecam Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 327 10-13-2011 06:22 PM
Finally, E85 tune is in!!! bmorecam Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 206 06-15-2011 07:25 PM
E85 and SCT Tune Stealth 2010 2SS/RS Tuning / Diagnostics -- engine and transmission 15 01-11-2011 04:05 PM
