BeckyD @ James Martin Chevy
Old 06-18-2011, 10:12 PM   #1
JHL88
JHL88's Avatar
Drives: 02 z06
adams paint correction
when you guys do the 3 step paint correction do you wipe-off the previous polish before applying the next or do you cover it after it flashes? it looked like adam layered all 3 then wiped it down after the FMP. but couldn't tell if they just cut that part out of the video.
1997 RS wrecked
1998 Z28 sold
10 SS sold
2002 torch redc5z06 - sold :(
'13 z71 4x4 - DD
www.fquick.com/JHL88
JHL88 is offline   Reply With Quote
Old 06-18-2011, 10:17 PM   #2
FL1CK
Switchin' n Twitchin'
FL1CK's Avatar
Drives: 2011 Camaro
From some of the posts I've read, they only wipe if off after the FMP like you said. but I could be wrong... (I usually am! HAHA!!)
FL1CK is offline   Reply With Quote
Old 06-18-2011, 10:32 PM   #3
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
You can do either/or. I think you wipe the product to see if you like the result of your labor before you move to other parts of the car. If you are happy with your technique, then you can choose to just layer products over the other if you'd like.
Old 06-18-2011, 10:38 PM   #4
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Just go right on top. You don't have to wipe it off til you're done with FMP.
[B]
Old 06-19-2011, 01:52 AM   #5
Junkman2008
"Detailing Devil Dog"
Junkman2008's Avatar
Drives: 2001 Corvette Coupe
It depends on who's technique you are using.
I ALWAYS wipe the polish off after each pass so that I can inspect my work. My logic is, how do you know if your technique is good and whether or not you need to continue with the same polish unless you wipe it off and inspect the area? That's why I do it the way I do and that's what makes sense to me. That's MY technique, not to be confused with anyone elses.
"Marines - Making the other guy die for his country for over 200 years."
Junkman2008 is offline   Reply With Quote
Old 06-19-2011, 03:23 AM   #6
FL1CK
FL1CK's Avatar
Drives: 2011 Camaro
So I'm guessing neither is wrong?
Old 06-19-2011, 03:26 AM   #7
Junkman2008
No technique is wrong if it gives you the results you seek. My advice is just be able to explain to whomever may be watching, why you do it the way you do. Have a method to your madness, a rhyme or reason.
If it doesn't make sense to you, then why would you do it the way you do?
Old 06-19-2011, 03:30 AM   #8
FL1CK
FL1CK's Avatar
Drives: 2011 Camaro
Totally understand!
Old 06-19-2011, 09:31 AM   #9
JHL88
JHL88's Avatar
Drives: 02 z06
maybe i was being too technical. i never layered with meguiars consumer line, and i got decent results but i switched over to adams and am using their products. i almost jumped to mirror glaze but it seems as if adams is easier to use. just wanted to make sure i wasn't going to do anything wrong.
1997 RS wrecked
1998 Z28 sold
10 SS sold
'13 z71 4x4 - DD
Paint correction detail (Sort of) Part 1 thorn Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 12 04-25-2011 12:04 AM
Group Buy on Adam's Polishes New Essentials Kit DetailersDomain Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 7 04-02-2011 04:40 PM
Has anyone have their front end replaced and/or repainted??? Paint issue inside... marcao 5th Gen Camaro SS LS LT General Discussions 42 07-20-2010 05:57 AM
Removing Swirl Marks using a Flex and Meguiars M105/M205 Angelo@Autopia Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 5 05-22-2010 10:36 PM
Adam's Polish & Car care Products Charlie@STILLEN Wash/Wax/Detailing and Cosmetic Maintenance Parts 50 04-01-2010 03:28 PM
