Cold Air Inductions
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 03-13-2009, 11:37 AM   #1
1986Z28
Drives: 1986 Camaro Z28
Question TH350 Swap in a 1986 Z28. Help?
I have gotten the transmission installed in the Camaro already with custom bracketry but i do not have a driveshaft. Any suggestions on the types of drivshafts that will work with this setup and is possible to change out the yolk and run the stock driveshaft? i know the driveshaft will need to be longer.
1986Z28 is offline   Reply With Quote
Old 03-13-2009, 12:32 PM   #2
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
is it a 6" tailshaft or a 9" tailshaft on the TH350?
if its a 9" tailshaft, you should be able to use the stock d/s or one from a 4th gen. but if its a 6" tailshaft, you need to get a custom length drive shaft
I piss excellence
and fart awesomeness
Old 03-13-2009, 01:45 PM   #3
1986Z28
ill measure the tailshaft and find out how long it is. i also thought about using a driveshaft out of a 1983 camaro with the 3 speed tranny. thanks though
Old 03-13-2009, 01:49 PM   #4
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
Why would you want to put a TH350 in her? You are going to lose a gear and you'll be cursing the car on the highway.
Hylton is offline   Reply With Quote
Old 03-13-2009, 04:10 PM   #5
CamaroSpike23
Truth Enforcer
its not that bad. I'm more than likely going to be putting a TH350 or 400 in the 94Z. I dont drive it far enough to worry about the overdrive.
I piss excellence
Old 03-13-2009, 09:32 PM   #6
1986Z28
i probably wont be driving it to much and the overdrive takes way more power to turn it. i dont have to outrageous gears in it they are only 3.27:1 and i dont expect a Camaro to get to good gas mileage anyways lol
I specially ordered a Z28! (unlike all of you) 496BIGBLOCK Camaro ZL1 Forum - ZL1 Specific Topics 70 01-02-2011 02:44 PM
Possible new option packages changes wanted for '11 '12 model years PYROLYSIS 5th Gen Camaro SS LS LT General Discussions 91 09-15-2010 06:15 PM
1977 Z28 engine swap camarokidz28 1st & 2nd Generation Camaros 6 12-26-2008 04:32 PM
Z28 - Please try and understand..... GTAHVIT Camaro ZL1 Forum - ZL1 Specific Topics 73 07-24-2008 01:30 PM
