Old 06-19-2011, 07:54 PM   #1
ddavis
boostalicious
ddavis's Avatar
Drives: Blown Ls3
question about halfshaft swapping
Im swapping over my stock halfshafts to some gforce ones and noticed the stockers have some extra hardware on both ends where they mount to the pumpkin & also the spindle. Looks like siver lips that might aid sealing them in. Are you guys swapping any old hardware off the stockers to the race set when your doing your upgrade? No install instructions, just double checking. Thanks
*Powered by Maggie**553rwhp 541rwtq*
ddavis is offline   Reply With Quote
Old 06-19-2011, 08:03 PM   #2
Huggerorange73
Banned
Drives: The REAL C5
Send a message via AIM to Huggerorange73
They are a direct swap....just make sure you lube up the splined end that's going into the pumpkin.
Huggerorange73 is offline   Reply With Quote
Old 06-19-2011, 08:52 PM   #3
GFORCE1320
Drives: 05 GTO
Yep, a direct swap. Nothing special needed. Take care not to damage the inner seals when sliding the inner stubs in.
Thanks
Chris
GFORCE1320 is offline   Reply With Quote
Old 06-20-2011, 12:16 AM   #4
ddavis
boostalicious
ddavis's Avatar
Drives: Blown Ls3
thx guys, got it all back in ok. I took it for a spin and it seems like when the clutch engages/disengages now im hearing a little more noise. Like maybe more slack in the drivetrain. Im going to drive it for a bit some more and see how it does. Is there any difference you notice after the swap or does it feel the same usually? I might just be a little paranoid and paying more attention then usual though.
Old 06-20-2011, 11:56 AM   #5
ddavis
boostalicious
ddavis's Avatar
Drives: Blown Ls3
Also wanted to ask if you have to stab it in a certain way. I just greased the end and pushed it in hard until it stopped. I pulled on it afterwards and it seemed to not be moving so i moved forward. Does it matter if the clip faces a certain way or will in click in no matter how its pushed in?
Old 06-20-2011, 12:43 PM   #6
GFORCE1320
Drives: 05 GTO
Doesnt matter on the clip, it will snap into the groove when you push the stub in.
Sounds like you did everything correctly.
Thanks
Chris
stereo question bigted83 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 2 04-07-2011 05:56 PM
Question about tire sizes Jram1588 Wheels and Tires Talk Sponsored by The Tire Rack 9 07-17-2010 08:27 AM
Custom wheel offset question ... Bowtie Junkman Wheels and Tires Talk Sponsored by The Tire Rack 4 04-23-2010 06:16 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 07:53 AM
Question re: c.i. displacement and hp Arli 5th Gen Camaro SS LS LT General Discussions 6 03-24-2009 02:20 PM
