ModBargains
Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions
Old 06-19-2011, 09:30 PM   #1
epstein
epstein's Avatar
Drives: SS/RS
Send a message via AIM to epstein
MSD BAP Question
Has anyone installed their MSD Bap under the hood?...I ask because alot easier to run 2 wires to fpcm than a vacuum line the length of the car..... I purchased a used one from a member as was just thinking.... It was for his whipple and im putting it on my eforce....any install tips? Can I run the vacuum t off the d/s port where I get my vac for boost?
Thanks
Brian
2010 SS/RS LS3 M6.. Eforce,Janetty tune, JRE fuel upgrade, ZL 1 fuel Pump, ADM FPC , ID 850 injectors,Roto Fab CAI, MSD wires,JBA Long Tube 1 7/8 headers Borla S exhaust,MGW short throw shifter,PLX gauges Kenwood touch screen nav, Polk Audio Speakers, 2 1200 Amps, Fusion 12" subs, Complete Vehicle Dyna matted
epstein is offline   Reply With Quote
Old 06-19-2011, 09:44 PM   #2
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Thanks
Brian
Too Far from the battery and fuel pump control module, under the rear seat or on the trunk is best.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 06-19-2011, 10:27 PM   #3
epstein
epstein's Avatar
Drives: SS/RS
Thanks Ted..... always a gentleman
Old 06-19-2011, 11:05 PM   #4
forplay
forplay's Avatar
Drives: 2011 2SS/RS LS3
I put mine in the trunk by the spare tire as does most Ive seen on here...it is only a shot run of wire to the fuel pump control module and the batt. I also ran my boost line from the back of the maggie to the drivers side firewall where there is access to get in in the cockpit of the car... then back to the trunk...should be about bullet proof like that...
2011 SS/RS M6 Synergy green 559RWHP...530RWTQ
Mods: Maggie supercharger...LS9X Twin disk clutch..85lb Fast inj..ZL1 Fuel pump..,MSD BAP..Roto-Fab cold air..Hotchkis max chassis brace, strut brace,, sway bars front and rear ,HD end links.adj toe link,lower control arm,,trailing arm,, Norris catch can..XS Power 1 7/8 ss lt headers..3" cat delete..3"X pipe..XS 3" mufflers. Hurst shifter.. Lowering springs..22" Foose wheels. Boost/vac ..Fuel pressure gauge..GPS stereo Head unit, all speakers and amp 4 10" subs..Ram air hood.heat extractors .Custom leather interior.Escort 9500ci..
forplay is offline   Reply With Quote
Old 06-20-2011, 05:24 PM   #5
oachalon
Drives: 2010 Camaro 1SS
the vacuum line is easy to run. As forplay said go right through the drives side firewall. I think i had my vacuum line installed and all panels back in within 45min to 1 hour.
oachalon is offline   Reply With Quote
Old 06-20-2011, 05:45 PM   #6
DietCoke
Drives: 2011 1SS
Send a message via AIM to DietCoke
Are you guys using hard plastic line for the vacuum run?
DietCoke is offline   Reply With Quote
Old 06-20-2011, 06:29 PM   #7
forplay
forplay's Avatar
yep .. I think it was 1/4" hard plastic line I got at my local parts store..I got about 15ft of it and had some left over...better safe than sorry...I also got a T fitting to use for my boost/vacuum gauge off the same line...Im not sure if you have used this type line before but if not make sure your cuts are straight and remember tight is tight..
Old 06-24-2011, 06:17 PM   #8
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
If you buy the MSD BAP from Vortech, you don't need to run a vacuum line.
They don't use the vacuum portion, just electrical, and it's already programmed.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 06-25-2011, 08:03 AM   #9
JANNETTYRACING
I can also program them to run with no vacuum line but I prefer to only have it work hard under boost.
I believe this will make it last longer, as it only acts as a voltage stabilizer until it goes in to boost then it jacks the voltage up to 17.5 at 8 psi.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 06-25-2011, 05:17 PM   #10
bilydean
bilydean's Avatar
Drives: One of the rare ABM camaros
What kind of lag time is there transitioning from Vacuum to Boost if you run a line from the front of the car to the back?
Dean
2000 5/23
3000 5/27
3400 6/20 TPW of 6/29
3800 7/3
4D00 7/8 interned at QC
4B00 7/16 Released from QC
4200 7/20
8/5 We picked up the car
bilydean is offline   Reply With Quote
Old 06-25-2011, 07:06 PM   #11
HaddadMotorsports
HaddadMotorsports's Avatar
Drives: Camaro
Dean
Not enough to be concerned
I don't see a reason you couldn't run the BAP under the hood, although i would step up the gauge of the line considerably due to the long run.
For those of you running long runs of vacuum line please be very meticulous in how you do so. If that line fails for whatever reason, you effectively have no BAP. and can very well hurt your motor. I've seen it happen
Lately I've been pushing everybody on twin pumps, I know its a lot more money, but its the right way to do it.
Your One Stop Shop For All Your Camaro Needs!
HaddadMotorsports is offline   Reply With Quote
MSD BAP question victoryred1ss Forced Induction - V8 6 10-26-2010 08:04 PM
MSD coils question Kwik Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 08-23-2010 08:14 PM
Question about tire sizes Jram1588 Wheels and Tires Talk Sponsored by The Tire Rack 9 07-17-2010 07:27 AM
Custom wheel offset question ... Bowtie Junkman Wheels and Tires Talk Sponsored by The Tire Rack 4 04-23-2010 05:16 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 06:53 AM
