Old 06-20-2011, 04:25 PM   #1
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
pirelli 315/25/22
anyone running this size, have really bad wear problem on rear inside tread area...both rear tires,...only have about 2500 miles...car was aligned and was perfect b4 and still is...my tire guys say they have seen this more than once with this size tire only...2 on bmw,s and can,t remember what other was...but exact same wear problem...pirelli does not want to do anything...any suggestions..also mech mentioned they like to blow out from inside tread area when they get worn down
mikepage0007 is offline   Reply With Quote
Old 06-20-2011, 06:38 PM   #2
TaylorRyanSS
COTW: 12/13/10
TaylorRyanSS's Avatar
Drives: 1969 Camaro
Thats what I have. No problems here though. I have had mine on for about 10K miles.
Old 06-20-2011, 07:10 PM   #3
seddon
seddon's Avatar
Drives: 2017 ZL1
That's what I have with about 6k miles on the no wear issues, but rob at wretched motorsport ( pedders) did my alignment.
seddon is offline   Reply With Quote
Old 06-20-2011, 07:20 PM   #4
mikepage0007
Drives: 2010 camaro
thanks , that is what i was looking for..i also am dropped with pedders , so something is afoul...will post in susp and maybe i can get someone from pedders to give me some info
Old 06-20-2011, 07:47 PM   #5
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
No problems here. pedders Xas.
Had my car aligned by a local tire shop that put the wheels/tires on.
Old 06-20-2011, 07:55 PM   #6
mikepage0007
Drives: 2010 camaro
how many miles , and do you get on it once in awhile..
Old 06-21-2011, 10:39 AM   #7
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
What alignment specs are you using? If they are anything other than OEM, such as "performance street" etc. type settings recommended by suspension brands, they will wear out on the backside due to the added camber.
Fquick.com/NineBall
Old 06-21-2011, 11:58 AM   #8
Rudy@Tirerack
Rudy@Tirerack's Avatar
Drives: 1-800-428-8355 X4664
A good alignment shop should be able to give you a print out of your alignment specs. What are Camber and Toe in the rear?
When ordering online please reference "Rudy/Camaro5" as your previous contact. Please click on the link in the sticky thread at the top of wheel and tire forum so the forum gets credit for the sale.
Rudy@Tirerack is offline   Reply With Quote
Old 06-21-2011, 03:47 PM   #9
copper3000
(aka) Troy & Maria
copper3000's Avatar
Drives: 2SS/RS 6M CGM/Black Stripes w GE
What is your tire pressure? I found running 40 psi all around has given me much better wear. Too low of pressure causes it to ride on the outer edges, making them wear much sooner. I've got over 23,000 miles on my original P-Zeros and they still look great. Nice even wear across the tread.
copper3000 is offline   Reply With Quote
Old 06-21-2011, 08:15 PM   #10
mikepage0007
Drives: 2010 camaro
tire pressure is 37...and rear tires only wearing inside..camber was -1, before we pulled rear....talked to pete@ pedders and he is helping me out...car has rear out right now and 9inch will be in tomorrow and we will try to get as much posive camber as it allows..appears that there may be no more room for getting it per mechanic..but we will see.. i wilol get print out when done..
Old 06-21-2011, 08:45 PM   #11
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
I'm getting ready to hit 14k miles on the car, about 9k on the tires. I get on it once in a while. Took it down the track and on the road course at camaro5festII.
JUST ARRIVED!! IN STOCK! 22" FOOSE SPEED WITH PIRELLI TIRES FOR ONLY $2725 SHIPPED!!! BestWheelDeals Wheels / Tires 13 04-13-2012 04:38 PM
>>> SWEET DEAL... MHT SPEED BLACK 22" + PIRELLI 315/25, 265/30 $2665.00 REG- $3308.. BestWheelDeals Wheels / Tires 41 08-15-2011 10:59 AM
22" Vossen VVS-CV1 staggered wheels and 315/25/22 Pirelli tires - Deep Concave Speed Depot Wheels / Tires 10 09-14-2010 10:04 PM
Pirelli PZero 315/25/22 instock??? SSMagna Wheels and Tires Talk Sponsored by The Tire Rack 4 02-23-2010 09:20 PM
