Old 06-20-2011, 10:40 PM   #1
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
what tires to buy
Hello, almost time for new tires... Not sure what to get or to stick with the OEM ones again... Any recommendations also should I change sizes of tires but keep them 20".
Thanks...
MARINE1991 is offline   Reply With Quote
Old 06-20-2011, 11:09 PM   #2
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
I went with toyo's on my stock wheels. Then I upgraded to forgestar f14's with continental 275 fronts 315 rears.
If you don't need an all season tire look at the nitto invos.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 06-20-2011, 11:37 PM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
What kind of driving do you do? If this is your DD and you're wanting to get a good high performance tire that has great tread wear, you can't go wrong with the Continental EC DWS's. They are listed as a ultra high performance tire that has a 540 tread wear rating. The OEM PZ's are 220.
I'd look into buying tires that are a size or two bigger. Not rim size, tire size. The stock 275's will fit the OEM front rim and 295's will fit the OEM rears.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 06-20-2011, 11:48 PM   #4
MARINE1991
MARINE1991's Avatar
Thanks...will keep that in mind.. my car is 1" lowered thow..
Old 06-20-2011, 11:55 PM   #5
lexlueger
lexlueger's Avatar
No worries! . I am also lowered.
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 06-21-2011, 01:24 AM   #6
axis
Search Ninja
axis's Avatar
Running wider tires is all about the offset. Since you're running the stock tires, that's not a problem. I've seen people run 305's on the rear OEM rim AND lowered without an issue. That's going a little too big IMO, but it can be done. I think 295's look great on the OEM rim and they're only a few $$ more than the 275's.
Halltech CF 102 fed
Old 06-21-2011, 02:08 AM   #7
usmcjlp
Drives: 2SS/RS LS3 RJT
What mods do you have? Do you care more about tread life or traction? I chose Nitto NT-05s for traction in a 275/315 combo. I personally would go with as sticky a tire as you can afford.
usmcjlp is offline   Reply With Quote
Old 06-21-2011, 01:05 PM   #8
Rudy@Tirerack
Rudy@Tirerack's Avatar
Drives: 1-800-428-8355 X4664
We have the orginal Pirellis in stock at a very competitive price. These are a very well balanced tire. I have other options also let me know if I can help.
When ordering online please reference "Rudy/Camaro5" as your previous contact. Please click on the link in the sticky thread at the top of wheel and tire forum so the forum gets credit for the sale.
Rudy@Tirerack is offline   Reply With Quote
Old 06-21-2011, 09:31 PM   #9
MARINE1991
MARINE1991's Avatar
I am wanting a the nero's and somthing a little wider and better for tracktions.. My car is lowered 1" with the OEM tires.. I called a tire shop and they were like you can not get anything wider... not sure what to get... I have full BMR suspension and bushings.. I am really confused now..
Stainless Works Factory Authorized Group Buy From APEX Motorsports! 15% OFF Retail!!! Apex Motorsports V8 Bolt-Ons & Tunes 23 11-09-2010 12:17 PM
Where to buy winter rims and tires? Stang_Eater_2010SS Canada 12 09-17-2010 06:29 PM
Best place to buy Nitto tires caverman Wheels and Tires Talk Sponsored by The Tire Rack 5 06-10-2010 02:11 PM
Any Body Want to Buy Me A Set of Rear Tires for 2SS? Scott@Bjorn3D Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 38 08-15-2009 09:07 AM
