Caryle Racing
Old 06-22-2011, 10:52 AM   #1
Irreverent
Banned
Drives: 2010 SS/RS M6 Inferno Orangle
Is the DSS driveshaft really stronger?
A buddy has an aluminum DSS 1 piece drive shaft in his Camaro and I saw that there are only 4 relatively small bolts connecting their aluminum pinion yolk adapter to the drive shaft. That seems like a seriuos weak point.
Anyone bust one yet?
Irreverent is offline   Reply With Quote
Old 06-22-2011, 11:39 AM   #2
flyby
Drives: 2010 Silver SS
650 rwhp, and I hammer in it, no problem with my aluminum one piece dss. Great company to work with. If you get one you will not be sorry.
flyby is offline   Reply With Quote
Old 06-22-2011, 01:01 PM   #3
Irreverent
Banned
Have you taken it to the track with slicks or drag radials?
Old 06-22-2011, 03:06 PM   #4
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
If you read the description closely you will see that they use Grade 12.9 bolts!
"The shaft only weighs 17lbs and come with special 12.9 uber strength hardware "
In some cases, size does NOT matter....
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 06-22-2011, 03:11 PM   #5
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
what does the stock shaft setup weigh?
94guy is offline   Reply With Quote
Old 06-22-2011, 03:29 PM   #6
hypurone
hypurone's Avatar
IIRC, 27 lbs, the DSS 1-piece AL unit inc the billet adapter ends is 24...
But the bigger bonus is losing the center yoke and slip-joint setup of the stocker...
Old 06-22-2011, 08:42 PM   #7
Merc
In The Circle
Merc's Avatar
I have had mine out to the track with slicks on, no problem. The problem with the stock shaft are those stupid rubber joints. I bent 3 set's of bolts in my stock driveshaft before I switched to the DSS shaft. No more worries about that now.
Old 06-22-2011, 09:13 PM   #8
Supercharged SS
Drives: 2010 Camaro
Plus with the stock rubber isolators you loose energy. The DSS shaft is a direct link. I've used it with drag radials and slicks, with 1.4 60's and the piece is awesome. So happy I got it and they aren't expensive.
Old 06-23-2011, 06:15 AM   #9
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
We have more than a few cars running from 7seconds up running this type of set up, for years we have used this same style part on the 93+ Supras-Dodge SRT8's and many other cars. yes they are extremely strong and the plates are machined on center to with the 16mm pin that comes off both the trans and diff to ensure a
perfect alignment between them both.
p.s. we also have about 25 Honda-Pro cars running 8 second passes and almost every one has a small 4x100 bolt pattern, say what you want about them but a 26" tall tire doing 1.3 60ft times and a 8 second pass would ensure a smaller 4 bolt pattern is quite strong, not to mention the driveshaft is on the easy side of the Diff to turn.
Driveshaftshop is offline   Reply With Quote
Old 06-23-2011, 06:22 AM   #10
Driveshaftshop
If you would like several names and phone numbers of people that use the billet plate
and 4 bolt flanges on real fast cars we would be happy to give them to you, send a PM
Driveshaft Shop axles, The real reason they work so well.... Driveshaftshop V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 52 03-11-2014 01:01 PM
Driveshaft Shop 9inch conversion in LPE650 2010 BADSS V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 84 09-22-2011 10:48 AM
Our first DSS 9 Inch Conversion and Detailed review. 55Designs V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 04-15-2011 09:24 AM
DSS Aluminum Driveshaft, New Design complete, brand New. 55Designs Transmission / Driveline 6 04-04-2011 06:23 PM
BMR Fabrication Launches New Product - 2010 Camaro Driveshaft Tunnel Brace (DTB004) BMR Suspension Suspension / Chassis / Brakes 30 10-12-2009 08:15 AM
