Old 06-23-2011, 12:44 PM   #1
CYBER69
NEMESIS (NEMI-"SS")
CYBER69's Avatar
Drives: 2011 2SS-LS3, BLACK W/CYBER STRIPES
Clutch Slip / Malfunction question...?
Guys,
Just got the car back from the perf shop... lots of things done. (Kook's, Cam, Tune) Went down a back road, lined up for a good pull, dumped the clutch (thought for a second I was spinning the tires) but relized it was the clutch. The pedal only came back about 1/2-3/4 while in 1st, grabbed 2nd and 3rd and the pedal came all the way back... Has this happened to you guys before? My immediate thought was I had torqued engine and the linkage got caught.. ( thought mabey the xtra 100HP was the root cause) but reading the threads here and others it may be this Fluid return problem? car only has 5200 miles so the clutch should not be burned up... I do not race it, and did not get another chance to test it yesterday...I drive pretty normal, catch 2nd every once and a while, generally a week end cruiser... any help or ideas would be great!
Thanks in Advance / Ken
1969 RS/SS Lemans Blue 396-350HP Convertible - Orig. Owner and 2011 RS/SS Black/Black Coupe - PFADT Stage-II, CAI, Richmond 4:33's, Barton Flat Stick-Short Throw, KOOK's ceramic LT's, Comp Stage II Cam, QuickTime cut-outs, Ryne Cunningham Custom Tune, Flowmaster, Heritage Grille, Eric Vaughn "widened" wheels w/ 315 Dunlops, MPD1 R.Spoiler & Dave Kahn "Buried" Cyber Grey Metallic Stripes.... 593HP / 517RWHP.
[SIGPIC][/SIGPIC]
CYBER69 is offline   Reply With Quote
Old 06-23-2011, 01:27 PM   #2
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Sounds like the contaminated fluid problem to me. Have you seen the threads? Search for the "Ranger Protocol".
-Mark.
Old 06-23-2011, 02:32 PM   #3
Chris@SPMC
Drives: '99 H/C FRC Corvette and '07 TBSS
A factory clutch generally can't hold more than 10% more power than stock especially when driven hard and you have far exceeded that. I'd recommend a Level 2 Monster Clutch to be able to harness the new found power! Feel free to give me a call if you have any questions.
Chris@SPMC is offline   Reply With Quote
Old 06-23-2011, 04:46 PM   #4
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
maybe a lpe clutch return spring?
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 06-23-2011, 08:58 PM   #5
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
See this post here for the Ranger Protocol clutch care - Clutch care
Then read through this post about the GTO clutch reservoir Install -
GTO Clutch Reservoir Install
I have ordered all of the parts needed for this remote reservoir from the guys on this forum for less than $50 total + the cost of replacement brake fluid and my time which make this a very worthy upgrade. Hope to install this weekend.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
Limited Slip Differential question jrcase V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 01-31-2010 06:03 PM
Clutch Question Mungo V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 12-14-2009 09:34 AM
Clutch Question francone13 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 11-26-2009 11:28 AM
Clutch question Chewy V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 11-03-2009 11:56 AM
