Old 03-14-2009, 05:54 PM   #1
texas06c6
Drives: 2000 czamaro Z-28 convertible
comparing 2000 LS-1 305 HP to the 2010 V-6
I have a 2000 Z-28- which was rated then at 305 hp. The V-6 is rated almost the same. What difference would I see in responsiveness, feel, etc. if I went with the V-6. Not an issue of money or insurance for me (I'm an old guy with near perfect driving record). Just wondering.
BTW, my Z-28 is a convertible which just turned 138,000 miles today, original clutch, original brake rotors, near original throughout, which parks every nite next to a 2006 DSOM Corvette Coupe (but I am still a Camaro man anyway!)
Thanks for comments
texas06c6 is offline   Reply With Quote
Old 03-14-2009, 06:11 PM   #2
Mythic
Mythic's Avatar
Drives: '03 Monte Carlo SS
LS1 more torque
'10 more weight
the 2000 has a better lb/hp ratio
the '10 will almost surely handle better in the corners get the FE2 suspension unless you plan to mod after buy
Mythic is offline   Reply With Quote
Old 03-14-2009, 08:17 PM   #3
ZeeTwentyFour
Does not have a Camaro
ZeeTwentyFour's Avatar
Drives: 99 silverado Z71/66 Chevelle SS
Send a message via AIM to ZeeTwentyFour
I agree with Mythic. The LS1 is a V8, no two ways around it. It's got more torque and less weight from what I can find. Believe it or not it's also got about the same fuel economy! I'm not sure what axle ratio you have but it will probably be similar to the V6 in either the automatic or manual. Overall I'd say you will notice less pickup when compared to your current camaro but better handling and interior quality with the 5th gen V6. Also the lack of a drop top
ZeeTwentyFour is offline   Reply With Quote
Old 03-15-2009, 02:18 AM   #4
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
From what I can tell, you'll probably feel very similar when in first gear because of the amazingly aggressive gearing in the V6 camaro, but after you hit 40 and have to shift, that will change fast.
I've never driven it, but based on the numbers and based on what those who have driven it have said, that's how it seems it will be. The LS1 will definitely be faster, but even though the 2010 is slower you'll still feel the power when you get on it. Kind of like romping on the gas in a truck. You go nowhere (relatively) but you can still feel the pull.
- Xanthos
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 03-17-2009, 06:31 PM   #5
fastball
White 'n Nerdy
Drives: 2017 Camaro 2SS 6MT
Don't forget, to get the most out of the SIDI VVT 3.6 you will have to change your driving style.
Spend alot of time in the higher RPMs and you will be rewarded. This engine is at it's best over 3500 RPM.
Take it to red line in each gear and you will be thoroughly impressed..... just don't tell that Cadillac dealer how I know
fastball is offline   Reply With Quote
Old 03-20-2009, 06:45 PM   #6
texas06c6
Originally Posted by Mythic View Post
LS1 more torque
'10 more weight
However, since I have the 2000 convertible, it is heavier than the coupe was in 2000. The vert came in at about 3700 lbs I believe. Might make the 2010 V-6 much more comparable and similar to the 2000 LS-1 in the vert.
Old 03-20-2009, 10:09 PM   #7
Xanthos
PWA Relapse
Xanthos's Avatar
Well, the coupe was rated at 13.6 I think from motortrend, and it looks like the vert was about 13.9 or so. Meaning a bit faster than the V6 still.
- Xanthos
Old 03-21-2009, 01:56 AM   #8
THE EVIL TW1N
Banned
Drives: 2003 Cobra Convertible
your 2000 z28 was also making closer to 340 ish hp too, in stock form, btw.
You really can't compare the two, the v6 MIGHT handle SLIGHTLY better, but will still most likely lose in ANY sort of race.
THE EVIL TW1N is offline   Reply With Quote
Old 03-21-2009, 02:02 AM   #9
Xanthos
PWA Relapse
Xanthos's Avatar
Stock, yes.
But slightly modded and I think it will outrun the 4th gens around a road course. Not on a drag strip, but it'll make up for it in the turns.
- Xanthos
P.S. - Not to mention how much sexier it is.
CAMARO WIKI Tran Wiki 55 03-28-2017 01:04 PM
2010 Stang vs Camaro (seems unbiased) MerF 5th Gen Camaro SS LS LT General Discussions 17 02-09-2009 11:11 AM
Edmunds: 2010 Ford Mustang First Look Scotsman General Automotive + Other Cars Discussion 32 11-23-2008 10:55 PM
Motortrend: 2010 V6 vs 1967 350 SS christianjax Camaro Photos | Spyshots | Video | Media Gallery 18 09-19-2008 06:25 PM
