SDTW Custom Wheels & Tires
Old 03-14-2009, 06:42 PM   #1
PD123
PD123's Avatar
Drives: Honda Civic EX '96
Would a twin-turbo respond well in the V6?
I plan on putting on aftermarket junk when my warranty is expired. (or close to it)
Ordered Black 2LT/RS.
PD123 is offline   Reply With Quote
Old 03-14-2009, 08:07 PM   #2
ZeeTwentyFour
Does not have a Camaro
ZeeTwentyFour's Avatar
Drives: 99 silverado Z71/66 Chevelle SS
Send a message via AIM to ZeeTwentyFour
I suppose anything is possible with time and money. I imagine any kind of boost, be it single, double, or super charged will make this engine even more of a beast. The 2.0 turbo 4 cylinder is DI. Hopefully by the time your warranty is expired the ECU will be cracked. This means a turbo will be much easier to mate to the engine and tune. I wouldn't throw just any junk on this world class motor however
ZeeTwentyFour is offline   Reply With Quote
Old 03-14-2009, 08:10 PM   #3
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
the trick is dealing with the high compression ratio that this motor has. altho the fact that it is DI, I would imagine it would take a lot of boost without issue.
I piss excellence
and fart awesomeness
Old 03-14-2009, 08:33 PM   #4
ZeeTwentyFour
yea, the DI thing is a tricky issue, but just look at the cobalts and sky/soltice motors. I pulled this from a GM spec sheet
"The turbocharger generates maximum boost of 20 psi. Because direct injection cools the intake process compared to port injection, it allows the 2.0L Turbo to safely operate at higher boost and higher compression (9.2:1) than a conventional turbo engine, increasing both output and efficiency."
It's only rated at 87 octane, so that gives you more room to utilize higher octane if necessary, like when using boost. I'd say just look around on forums like cobaltss.net or sky/soltice forums and we can get an idea of what we need to boost the LLT.
Old 03-14-2009, 08:37 PM   #5
CamaroSpike23
Truth Enforcer
what is the cr on the cobalts/sky/solstice motors that are fi tho?
I piss excellence
Old 03-14-2009, 09:03 PM   #6
ZeeTwentyFour
most older non-DI Ecotec engines are 9.5:1, but the 2.4 in the solstice/sky is 10.4:1. The new 2.2 is 10:1. The next 2.4 DI that will hit the market will be 11.4:1.
Old 03-14-2009, 09:07 PM   #7
CamaroSpike23
Truth Enforcer
normally you want a lower cr with FI. but with it being DI, I think it will be safe running boost. hell, ive seen diesels with 35:1 cr. but they are designed to run by detonating...
guess we'll have to wait and see
I piss excellence
Old 03-14-2009, 09:22 PM   #8
justmeron
justmeron's Avatar
Drives: 2010 camaro
Send a message via AIM to justmeron
I am not a mechanic but could the auto tranny handle it? Or would that also have to be upgraded?
2010 2011 Chevrolet Camaro Faded Black Side Vent Highlight Decal Kit
Life is not like a box of chocolates, its more like eating a whole jar of jalapenos.... what you do today may burn your ass tomorrow!!!!
justmeron is offline   Reply With Quote
Old 03-14-2009, 11:06 PM   #9
fazm
Drives: ex-500hp v6 mustang
time will tell
fazm is offline   Reply With Quote
Old 03-14-2009, 11:27 PM   #10
Mr Twisty
Mr Twisty's Avatar
The compression ratio is 11.3:1 already, that's pretty high.
-- Benjamin Franklin
Old 03-14-2009, 11:35 PM   #11
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
if you're gonna be putting out a bunch more power (400+), you'll most likely wanna go with the 6L80 (if it'll mate up). i don't know the torque rating on the 6L50, but i'd say it's a bit less than what a TT LLT would be making
Old 03-15-2009, 12:31 AM   #12
CamaroSpike23
Truth Enforcer
it'll hold 500ft/lbs
I piss excellence
Old 03-15-2009, 05:12 PM   #13
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
But with Direct Injection, that issue becomes somewhat less important that it usually is...
Old 03-15-2009, 05:23 PM   #14
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
Yes. I'd say that if the LNF can hold 20 lbs of boost at 9.5:1, we should be able to do 5-7 at 11.3:1 without issue.
Although, I have to say that my setup will probably be 10:1 at 7 psi.
- Xanthos
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Would you Twin Turbo for the right price? peteypab2133 5th Gen Camaro SS LS LT General Discussions 79 11-09-2009 06:57 PM
2011 mustang possible Twin turbo V6 Devil-eyes General Automotive + Other Cars Discussion 40 03-19-2009 04:00 PM
Ford GT Twin Turbo Aptom General Automotive + Other Cars Discussion 44 09-20-2007 10:39 PM
