Emblempros
Old 06-27-2011, 06:32 AM   #1
b20
Drives: 2013 1LE RS 1SS
Nitrous plate system
I was hoping for more but
It made 489 hp and 535 tq on 100 shot
And 535 hp and 595 tq on 150 shot
Na with nitrous tune it made 389 hp and 385
Na tune makes 397 and 395 tq
Had to pull 4-7 degrees of timing for both shots
A/f was in the high 10's so it is safe
All I have is a airaid cai and cat delete pipes
b20 is offline   Reply With Quote
Old 06-27-2011, 06:52 AM   #2
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
You're WAY rich on your AFR. Being that rich is costing you power, and it isn't more "safe" then running a PROPER afr.
DietCoke is offline   Reply With Quote
Old 06-27-2011, 08:36 AM   #3
Graham@N
Drives: Pontiac Firebird
I agree with the above. Also you picked up right where the shot size was set, what numbers were you looking for? If you go off of the plugs and get that thing in the mid 11's will be just as safe and putting down a cleaner number.
Graham@N is offline   Reply With Quote
Old 06-27-2011, 06:18 PM   #4
trans665
trans665's Avatar
Drives: 2010 2ss
i thought you could put a 100 shot saftly with no tune??
trans665 is offline   Reply With Quote
Old 06-27-2011, 10:33 PM   #5
Brian@LGMAC
Drives: a slow 2010
rich is everything but safe
Brian@LGMAC is offline   Reply With Quote
Old 06-28-2011, 01:21 AM   #6
b20
Tried to go leaner and richer
Bogged when richer and made less power
Leaner made same power but got a little knock
I looked the plugs over good after each run
I might try a colder plug and lean it out more
Old 06-28-2011, 08:59 AM   #7
Graham@N
No ECM tuning. To get all the power out of it, there still might need to be some jet changes.
What plugs?
No need for any nitrous car to have AFR in the 10's (as long as the plugs agree that what it is.
Also how are you going about getting a read on the spark plugs?
Old 06-28-2011, 09:50 AM   #8
b20
A plug flash light (old school)
Then was told a drill and hack saw blade trick also
Maybe the wide band is off but the car likes where it is
Carmel color and brown deep in the plug
And yes killed the key at very end off pull
Old 06-28-2011, 10:15 AM   #9
Graham@N
You know why they call it old school? Because it still works!
The drill and hacksaw works great btw.
It sounds like the plugs are agreeing with the wideband. Definitely have more power with some timing pulled and leaning it out.
If you have knock you are way to aggressive.
Old 06-28-2011, 04:07 PM   #10
b20
What plug do u think I should try?
I just tapped tr6 to .30
With nano this thing really pulls up top
Old 06-28-2011, 04:19 PM   #11
Graham@N
Br7ef for sure.
The Tr6 should never be used with nitrous.
Old 06-28-2011, 10:43 PM   #12
b20
Maybe that's the problem
Old 06-29-2011, 12:55 AM   #13
Jason7
NorCalCamaros.com
Jason7's Avatar
Drives: 2010 2SS White
Rich is definately better than lean though right?
JASON
Jason7 is offline   Reply With Quote
Old 06-29-2011, 07:34 AM   #14
tylerSS
Drives: 2010 Inferno Orange SS 6spd
i almost have the exact same setup and will be going to the dyno next week....I'll let you know my numbers and a/f.....i wont be getting a tune.....unless 100% necessary
tylerSS is offline   Reply With Quote
Nitrous System ?????s PoleCat2SSRS2010 Forced Induction - V8 29 12-08-2010 05:55 PM
V6 Camaro's - NITROUS KIT!! Add 50-100 Horsepower - Phastek Performance Sean@Phastek V6 Bolt-Ons & Tunes 1 06-09-2010 12:29 PM
Zex Nitrous System for 2010 Camaro SS @ BMC Performance! Kris@BMCPerformance Forced Induction 2 02-18-2010 06:59 PM
