![]() Drives: 2016 Black Camaro 2SS Join Date: May 2011
Bad luck or?
I replaced my stock wheels with American Racing wheels, daytona. Driving home from shop I noticed a shim/vibration in steering wheel at low speed and higher. The shop I go to thought it might be a bad tire or wheel. I went to the dealership I bought car at to have a road master test done, the test showed three bad wheels, one tire questionable. Just had the three wheels replaced and the car still does same thing. A friend said I should replace all the tires and it can't be the wheels again.
Anyone have suggestions? The shop I go to has very good rep, I can't see them messing the set up, up or having bad wheels again. The dealership f'd up and had put the tires on wrong after the test, fronts on back,backs on rear! But now I'm at square one again with a shim. Any positive input would be appreciated. Thanks. |
Sorry, I can't really help with your "shimmy" problem, but I sure would like to see some pictures of your car with those Daytona's (I want to get them for mine too). Did you go with the Chrome, Black, or Machined Grey???
I would say if you had three wheels replaced already, it "should" be highly unlikely to be a wheel problem again. Must be something with tires (which you wouldn't expect since the PZeros are supposedly a top-of-the-line product). Hmmm, interesting.... |
I'll post some pictures for sure, once i get my car back, i left it at shop while i decide on new tires or what, the shop offered to trade out my tires on credit and apply towards a better tire, offer seemed very good,my car is black and like a few others I've gone mainly blacked out. The wheels are the black ones, they look sick on and I've received alot of nice compliments. Thanks for your response.
376 cubic inches of fun
Well, since you didn't have the problem until you got the new wheels, you should put the tires back on the factory wheels. If the problem goes away, you know for sure it's the wheels. Then you need to get your money back for the bad wheels.
The last thing I would do is throw money at the problem by getting new tires put on the suspect wheels. |
Or did the tire shop screw up the belts/cords in your tires taking them off of your wheels?
Cars and women are both going to give you problems...but you can pay somebody else to fix your car!
#6 |
Toesuf94 that's a good question. I can't see this shop getting in three more bad wheels, and putting back on my stock wheels with tires rock-it-man is my next option for sure.
#7 |
The Original
They are balancing the tires after installation? Stupid question but you never know these days.
LETHAL RACING Phase V, "ECS Supercharger, Nightfury cam, Methanol Injected, Dual Fuelpumps, Kooks Headers with Hi Flow Cats, 3'' Catback Magnaflow Exhaust, Custom Tune, H & R Drop Springs,Barton Ind. STS 773 RWHP.
#8 |
I'm not sure if they are doing that after installation tlc9193.
#9 | |
Wheel balance
had my wheels balanced 3 times before getting them high speed balanced. nothing worked till then. it was around $150 for a set of 22. |
#10 |
Abelsspeedy is that what the road master test does? Sounds similar, it gave out a printout of the tires and wheels and what was wrong, showed three of four wheels bad one suspect tire, they replaced the wheels but not tire. Had test done at dealership, the shop putting wheels on has some machine they say the wheels are fine but tire showed a wave. I'll look into that balance you mentioned, not sure where in my area they'd do that.
#11 |
I dont know the actual name but i do know it displays the wheel and tire on the screen and will tell the operater wether to remount the tire into a specific place or just balance the wheel. And also advises the operator were exacatly to put the weights on the wheel.
#12 |
Sounds like same test. I'll have to look for another shop that does that then, the dealership won't remove the tires from aftermarket wheels in fear they might scratch them. I'll have to search the area I'm thinking for a different shop.
#13 |
pic
This is what the machine looks like. I recommend this to everybody that has aftermarket wheel done it to all my vehicles since my old pick up to my 2010 camaro ss. Hope this helps.
#14 |
Yes, it's called "Road Force" Balancing. It is usually used on high performance track wheels/tires where a precision balance is important. See if that is what your dealership did. If not, it might resolve or at least help troubleshoot your problem.
Thread Tools | |
What song are you listening to right now | Muscle Master | Off-topic Discussions | 6413 | Yesterday 09:04 PM |
How bad are burnouts? | boomskeet | Dragstrip and Launch Techniques Discussion | 8 | 04-27-2010 10:10 AM |
Of all the bad luck! | Rockin the BlueSS | USA - California | 21 | 04-23-2010 11:25 AM |
How bad is it??? | Susantroy1 | Off-topic Discussions | 5 | 10-27-2009 11:32 PM |
bad personal news | ChevyNut | Off-topic Discussions | 4 | 02-23-2007 11:36 AM |
