Old 03-15-2009, 10:22 PM   #1
JSOC_MQ1
Drives: 2010 IBM 2SS
L99 and Pulstar Spark Plug
Forgive me if this subject has been covered, but I was wondering what the opinion is on the use of the Pulstar Spark Plug (http://www.pulstar.com/index.htm) with the L99 engine and the active fuel management system.
Do you think the design of this plug would effect the AFM?
Thanks.
JSOC_MQ1 is offline   Reply With Quote
Old 03-15-2009, 11:03 PM   #2
Nexus6
More human than human
Nexus6's Avatar
Drives: 2010 IOM 2SS/RS
Stick with AC Delco,there are other ways to get better efficiency out f motors .or if anything get a Hotter AC Delco plug
1100 - 10/22/2008
3000 - 05/27/2009
3300 - 06/06/2009
3800 - 06/29/2009
4B00 - 06/29/2009
Warehouse 13 survivor
Blood stains,speed kills,fast cars,cheap thrills,rich women,fine wine,i lost my sense i lost control i lost my
mind.
Nexus6 is offline   Reply With Quote
Old 03-15-2009, 11:11 PM   #3
69 Hugger
69 Hugger's Avatar
Drives: 69 Convertible Camaro
Stick with Delco, but they'd be fine at least there made in the states.
69 Hugger is offline   Reply With Quote
Old 03-15-2009, 11:24 PM   #4
Parker
Parker's Avatar
Drives: 2010 Camaro SS/RS
Spark has nothing to do with the AFM components.
I wouldn't trust that product to do what it says it does.
Sounds like a tornado charger and other such snake oils.
Parker is offline   Reply With Quote
Old 03-16-2009, 05:21 AM   #5
duder4thgen
Drives: Bird
Would not go any hotter than what the factory recommends. Recipie for voided warranty and engine damage. Do agree, unless youre modding it, stick with what the factory puts in there, the ignition system on geniii/iv motors is more than adequate from the factory.
If you are modding, lots of ls1 guys are running ngk tr55's. Only problem is they burn out within 10k-15k miles, so you need to pull a couple to check regularly. General rule of thumb is if you add forced induction, or n/a about 100hp over stock, you need to move down a heat range to a cooler plug.
duder4thgen is offline   Reply With Quote
Old 03-16-2009, 05:49 AM   #6
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
What!?!... a tornado charger quadrupled my horsepower... Well okay, it was just a sticker for the tornado charger, but that stuff works!
Sterling is offline   Reply With Quote
Old 03-16-2009, 06:47 AM   #7
PatrickfromMD
PatrickfromMD's Avatar
Drives: Navigator/Corvette/2010 Camaro
Thanks.
Most of the tests I've seen to not support their advertising claims. I think its better to look elsewhere. I have read in the G8 forums where some programming changes have led to better mileage on the AFM engines (I think there’s are L76 motors). They tweak some of the parameters dealing with the AFM. Anyway, I may look more closely in this area when I get my L99 Camaro.
***56K miles and still going strong***
2SS/RS IOM ext w/cyber grey stripes, tinted windows, IO int Auto
ProTorque prototype Converter, Chuck Mosello of Westchester Corvettes Custom Tune
T&T installed SLP Longtubes, Powerflow X Pipe, and Powerflow axle back
JL 10W3 in custom side sub box, new door tweeters, Alpine 5ch 600 watt
T&T configured ACS front Fascia w/ heritage grill, splitter, dual color halos, , led markers, taillight bezels , all accented in CGM
Gary Custom Z vented fenders. Vararam ver 2
PatrickfromMD is offline   Reply With Quote
Old 03-16-2009, 06:50 AM   #8
spd98
Drives: had a goat
The bottom line is as long as you have enough spark to start combustion you don't need any more. Regular plugs work fine.
spd98 is offline   Reply With Quote
