Old 06-28-2011, 10:45 AM   #1
full of days
full of days's Avatar
Drives: Camaro GT
pfadt coilovers and 20x10 forgelines -- wheel rub on the coilover
I'm running 20x10 forgelines on all four corners with pfadt coilovers. Im running 275/40/20's up front and the tire is just barely rubbing on the coilover. Custom spun 5mm spacers from Forgeline too and they're still not clearing.
I'm not comfortable running even a 5mm spacer up front.... and a 6-7 mm spacer just wont give enough stud for the lug nut.
The wheel should clear the coilover without a spacer running the right offset, right?
Are the offsets wrong? I've got a call into forgeline and am awaiting a response, but wanted to see if anyone running pfadt coilovers and forgelines with custom offset have had this issue... I gave my pfadt coilover setup to forgeline for the right offset but it looks like the clearance for the tire just isn't enough.
Can anyone with Pfadt coilover experience or forgelines chime in with proper clearance for the front coilovers?
Post Tenebras Lux
full of days is offline   Reply With Quote
Old 06-28-2011, 03:01 PM   #2
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Pretty common with an aggressive front wheel fitment, and aftermarket coil-overs. KW and Pfadt have a little less clearance that stock struts, Pedders and BCR have slightly more clearance than stock. You might consider sending the front wheels back to Forgeline to get them to re-hoop them into 9.0 or 9.5 widths, depending on the offset you have milled into the lug pad already. 9.5 would be perfect for that tire size, but it will need to be a perfect offset in order to clear the shock spring perch and not stick out of the fender.
Tony
Fquick.com/NineBall
Old 06-28-2011, 04:32 PM   #3
full of days
Drives: Camaro GT
Forgeline has been so helpful. What an awesome company!
The offset is perfect for pedders coilovers or lowering springs with the stock struts but the Pfadt coilovers are bigger than stock at the spring perch... Dave is turining some custom billet 7 mm spacers to clear the coilover spring perch and is mailing them out this week. Gotta love a fellow camaro owner!
Now I'm concerned about fender clearance and the fronts sticking out beyond the fender...
If these custom spacers dont work, Ill have to send 2 wheels back and get a 9.5 hoop- I wonder if the 1/2 inch will be enough to clear the spring perch??
Am I going to have bearing issues or chatter up front with 7mm spacers?
Post Tenebras Lux
Old 06-28-2011, 04:40 PM   #4
xavier02832
xavier02832's Avatar
Drives: 13 Camaro ZL1, 13 Shelby GT500-Sold
Shoot Erik@Torq a PM, he had the same issue with his forgelines and pfadt coilivers.
I believe Pfadt offers a smaller/shorter spring for the front coilovers which ended up taking care of the problem.
xavier02832 is offline   Reply With Quote
Old 06-28-2011, 05:05 PM   #5
full of days
Drives: Camaro GT
sent E a PM... Curious to know what offset he's running on his GA3R's
Post Tenebras Lux
Old 06-28-2011, 05:07 PM   #6
full of days
Drives: Camaro GT
Did a search and came up null.... Any threads out there on this or can Pfadt chime in?
Post Tenebras Lux
Old 06-29-2011, 09:52 AM   #7
Nine Ball
Nine Ball's Avatar
I'd recommend giving Pfadt a call, they are very good and always glad to help when it comes to their products. A shorter length coil spring would definitely solve the issue, as it would move that lower spring perch nut higher and out of the way.
Tony
Fquick.com/NineBall
Old 06-29-2011, 04:33 PM   #8
full of days
Drives: Camaro GT
UPDATE:
Offset is at +36 on the front 20x10's and with a 5mm spacer the tire is barely touching the spring perch.
Camber is at -.90 right now which is falls into "aggressive street" tolerances. I wonder if I took camber to -.70 if that small amount give me about 2-3mm clearance at the spring perch? I dont see this affecting performance too much...
What would be the minimum tolerance allowed b/t the tire and the spring perch? 2mm? 1mm?
Post Tenebras Lux
Old 06-29-2011, 04:52 PM   #9
Nine Ball
Nine Ball's Avatar
1/8" is a general rule for clearance minimum.
Fquick.com/NineBall
Old 06-29-2011, 05:05 PM   #10
full of days
Drives: Camaro GT
Just got off the phone with Erik @ Torq. What an awesome guy!
Erik went through the exact same issue as he's running forgeline GA3R's and pfadt C/O's. He & Aaron worked together to develop a proper weight spring with a 2 inch shorter length that brings the perch above the tire to solve the problem. This solves the clearance issue b/t the tire and the spring perch and maintains adjustability on the coilovers.
Thanks everyone for the help and feedback! This forum and its members are incredible!!
Post Tenebras Lux
Old 06-30-2011, 03:34 PM   #11
xavier02832
Glad I could help
Old 07-01-2011, 10:24 AM   #12
full of days
Drives: Camaro GT
For those with pfadt coilovers wanting to go with a wider wheel and 275-285 up front, you need these shorter 8 inch springs from Torq... This will raise the spring perch above the tire and still allow for full adjustability.
Thanks to all for advice and assistance.
http://www.gettorq.com/store/chevrolet-camaro/replacement-springs-for-pfadt-camaro-coil-overs-8-2010-camaro-ss-v6.html
Post Tenebras Lux
Old 07-07-2011, 05:36 PM   #13
JMAC2011
MONGOOSE
JMAC2011's Avatar
Drives: 2011 SS Camaro M6
This is an awesome thread. Thanks for directing me to it.
JMAC2011 is offline   Reply With Quote
Old 07-07-2011, 06:10 PM   #14
PTS
PTS's Avatar
Drives: 2011 Camaro
Excellent Information....Many Thanks!!!
PTS is offline   Reply With Quote
