ADM PERFORMANCE
Old 06-28-2011, 10:10 AM   #1
LarryCook
LarryCook's Avatar
Drives: 2011 2LT RS
False Alarm .. Trunk Open
I was sitting in my 2LT Camaro yesterday waiting for my wife, and the “Trunk Open “alarm flashes in the DIC panel. I checked the trunk but it was closed. I cleared the alarm with the button on the turn signal lever. A little while later the false alarm on the trunk came on again and this time I opened the trunk and closed it and the alarm went off. We drove over to the Mall which has a Baskin Robbins and while we were walking back to the car I heard a car alarm going off. I couldn’t see my car from where we were at. The alarm stopped and when I saw my car I tried to remote start it but it wouldn’t start. I unlocked the car and it honked and flashed the lights, and when I started it up the ”Theft attempt” alarm flashed on the DIC and then the “Trunk Open” alarm showed up. I checked the trunk and it was closed. So I opened it and closed it again. Anyone else getting false alarms?
LarryCook is offline   Reply With Quote
Old 06-28-2011, 10:19 AM   #2
garcmol
garcmol's Avatar
When you pop your trunk, look at the trunk lid and you'll see two black bolts with a black piece sticking out of both of them. You can push the black pieces back inside the bolts (this is all plastic by the way). Now sometimes those will loosen up and may be what's happening. if that pin doesn't push in far enough when the trunk is closed to make contact with the sensor, the DIC will say trunk open. That may be what's happening. I haven't had the problem you have had, but I did find them loose before. If you can't finger tighten them then one of them may have backed all the way out.
Oh, the pieces I'm talking about are left and right of the latch assembly on the trunk lid.
Old 06-28-2011, 11:09 AM   #3
LarryCook
LarryCook's Avatar
Drives: 2011 2LT RS
Thanks for the Tip .. I checked the sensors and they both feel secure. It happen about 4 times yesterday. So far today it's OK.
Old 06-28-2011, 11:11 AM   #4
garcmol
garcmol's Avatar
Your welcome. If it persists I would take it in though.
Old 06-28-2011, 11:14 AM   #5
BenningJ
BenningJ's Avatar
Drives: 2013 AGM 1SS/RS LS3
Body Control Module or main computer is my guess. They have a tendancy to screw things up if they happen to be bad. It will make the car do some really crazy stuff. I have a buddy that has an newer Saturn Vue and the door locks would cycle and the dash lights would come on and the gauges were going hay-wire while driving down the road. It turned out to be the BCM and they also replace the ECM too eventually.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R
BenningJ is offline   Reply With Quote
Old 06-28-2011, 11:22 AM   #6
KFH
1LT Victory Red V6 Manual
KFH's Avatar
Drives: 2010 1LT 6 speed manual #117
I've had a couple of "Trunk Open" false alarms.
1st Car-77 Type LT Rally Sport, Manual 3 speed, Inline 6, 3rd-94 Red & Black Z28, 6 Speed Manual V8
4th-2010 1LT, Manual V6, Injen CAI, RX Catch Can, Flowmaster American Thunder & Magnaflow Resonated "X"
KFH is offline   Reply With Quote
Old 06-28-2011, 11:29 AM   #7
LarryCook
LarryCook's Avatar
Drives: 2011 2LT RS
So far this is the only thing I noticed. I did have a Service StabiliTrak message displayed at startup for a few seconds once and the theft attempt a couple of times without the Trunk Open alarm. Scheduled a appoint with the Dealer next week to have it checked out.
Old 06-28-2011, 11:47 AM   #8
proj3ktpat
Drives: 2010 Camaro 2ss/rs
The false trunk open alert has happened to me a handful of times since owning the car, and it's usually been right after closing it. I just open it back up and close it again and it goes away. It never set the alarm off or anything though.
proj3ktpat is offline   Reply With Quote
Old 06-28-2011, 03:49 PM   #9
CUPRA
CUPRA's Avatar
Drives: 2011 2SS/RS - IOM/CGM Stripes
I've had this happen one time and was taken by surprise. Got out and checked the trunk, it was closed. Opened it and closed it again, message went away and haven't seen it again since!
2011 - 2SS/RS - IOM/CGM Stripes • CUPRA • Ordered: 4/10/2010 Mine: 7/1/2010 - 426BHP+CAI
CUPRA is offline   Reply With Quote
Old 07-06-2011, 09:20 PM   #10
denferg
denferg's Avatar
Drives: 2010 Imperial Blue Metalic 2SS LS3
I have had this happen a couple times as well. For me it was on cold days. I haven't noticed it during the summer months. So I am curious if it will happen again when ..if ( I live in Teas) it gets colder
denferg is offline   Reply With Quote
Old 07-06-2011, 10:18 PM   #11
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
I went out to my garage and my trunk was open. And my keys were hanging up on my key rack. I don't know why that happened. And then it has happened again. Still researching this. I might have to take it in to the dealer.
=Stephens= is offline   Reply With Quote
Old 07-06-2011, 10:35 PM   #12
Modern07
Mid-Florida Camaro Club
Modern07's Avatar
Drives: 2013 ZL1 #2303
I've had it say Trunk open incorrectly quite a few times too.
I just open it, close it, and then do the same a few weeks later when the issue reappears.
Modern07 is offline   Reply With Quote
Old 07-06-2011, 11:18 PM   #13
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
I've actually had a "hood open" false alarm fiasco.
Dizzy82 is offline   Reply With Quote
Old 07-07-2011, 03:03 PM   #14
LarryCook
LarryCook's Avatar
Drives: 2011 2LT RS
Update ....
Had the Dealer check it out and they are ordering a new trunk sensor
Trunk light LED replacement guide with pictures JKEP44 Cosmetics and Lighting Modification Discussions 15 03-12-2015 08:00 PM
Sub sounds much worse when trunk closed...need different box??? KMPrenger Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 6 03-17-2011 11:47 AM
Can't get into my trunk... KenH Canada 15 02-16-2011 01:14 AM
SEIBON trunk problems bubbykong Cosmetics and Lighting Modification Discussions 15 02-08-2010 10:13 AM
Gap below trunk lid scorpio 5th Gen Camaro SS LS LT General Discussions 8 09-24-2008 09:09 AM
