BORLA
Old 06-28-2011, 11:42 AM   #1
ddavis
boostalicious
ddavis's Avatar
Drives: Blown Ls3
To the guys running stronger axles
Are you noticing more play in the rear now on your manual? The drivetrain seems loose now for me and theres some clunking going on, especially with pushing the clutch in or out. I can feel the slack on them if i grab the axle with one hand and twist it back and forth. Just wanted to hear some feedback before i send them off to get looked at. Its been driving me crazy, to the point i put the stockers back in. Just wanted to know if you guys felt a difference also in the drivetrain after installing
*Powered by Maggie**553rwhp 541rwtq*
ddavis is offline   Reply With Quote
Old 06-29-2011, 03:47 AM   #2
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
Didnt notice anything at all
DietCoke is offline   Reply With Quote
Old 06-29-2011, 08:52 AM   #3
flyby
Drives: 2010 Silver SS
Do you still have stock differential?
flyby is offline   Reply With Quote
Old 06-29-2011, 09:04 AM   #4
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
yes
Old 06-29-2011, 10:14 AM   #5
ddavis
boostalicious
ddavis's Avatar
Drives: Blown Ls3
Hey DietCoke, do you have a Auto or stick? I was told that the m6 will feel more slack then the auto does. I noticed it right away. I think I might just have to send these out now to be rebuilt. I bought them second hand from the forum and was told they only had 200 miles on them. Stock Diff for me also
Old 06-29-2011, 11:40 AM   #6
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
Hmmm, which axles are they? I have some GForce1320's in mine (A6) and no play/slack...
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 06-29-2011, 11:46 AM   #7
ddavis
boostalicious
ddavis's Avatar
Drives: Blown Ls3
they are the Gforce1320's. Gforce said i can send them off and they will replace them for me. They have been great answering my questions. I just wanted to see what others thought before shipping out parts that heavy.
Old 06-29-2011, 12:19 PM   #8
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
Do you have stock diff bushings? Mine started that after putting ing the harder bushings and taking out the slack from the stock rubber ones.
1977and2010 is offline   Reply With Quote
Old 06-29-2011, 12:22 PM   #9
hypurone
hypurone's Avatar
When you say you can feel slack in them. Are you able to see that the slack is contained with the axle and you are not feeling anything from the diff?
Say you were to set the PB, hold the inner axle stub (or have someone else hold the DS) and grab the center section of the axle and twist. Does the center axle section actually rotate?
Old 06-29-2011, 12:27 PM   #10
ddavis
boostalicious
ddavis's Avatar
Drives: Blown Ls3
Stock diff bushings are in. I put in the axles and noticed the extra play in the drivetrain when driving, so I put the stockers back in and it went away. I can hold 1 end of the axle and turn the shaft with the other hand back and forth with the axle off the car and feel about a 1/4inch of movement happening from the joint. I tried the same thing with the stockers and they shift maybe a 1/16 at the most. At first I thought it was just one side, but now that both is off im noticing it in both gforce axles. One side a little more then the other
Old 06-29-2011, 12:29 PM   #11
ddavis
boostalicious
ddavis's Avatar
Drives: Blown Ls3
It makes you feel like you cant drive a stick with the play in there. Its not possible to shift smooth without a clunk especially when babying the clutch at low speeds
Old 06-29-2011, 03:39 PM   #12
hypurone
hypurone's Avatar
Def sounds like the axles are defective or got hammered hard from the previous owner (competition mode launches repeatedly)...
Old 06-29-2011, 04:45 PM   #13
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
I have a stick. There is zero play in my axles (DSS/Hendrix), I don't really know what you're experiencing.
Old 06-29-2011, 05:14 PM   #14
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
Is it really necessary to change axles and driveshaft? I'm SC'd too and beat on my vehicle pretty hard sometimes (6+k RPM), no busted DS or axles.
2010 Camaro SS, P1SC SuperCharged Livernois LSX429ci., 1 7/8" LT Headers, full 3" MBRP exhaust, SPI built/tuned, a total
calbert1999 is offline   Reply With Quote
guys running skinnys 94guy Dragstrip and Launch Techniques Discussion 4 02-17-2011 08:37 AM
what kind of times are you guys running with the l99 to ls3 conversion JZM2ss Dragstrip and Launch Techniques Discussion 13 02-07-2011 11:48 AM
Guys running aftermarket 20's with a low drop, are you using the OEM tires or not? 55Designs Wheels and Tires Talk Sponsored by The Tire Rack 0 10-19-2009 11:39 AM
