SDTW Custom Wheels & Tires
Old 06-28-2011, 05:43 PM   #1
Pollock
LT1 M6
Pollock's Avatar
Drives: 2018 1SS/1LE
Clutch Sticking to the floor service bulletin
I am taking my car in tomorrow. They claim there is an adjustment at the master cylinder. Any one know what they are going to do?
Thanks in advance.
Pollock is offline   Reply With Quote
Old 06-28-2011, 05:57 PM   #2
kevin1106
kevin1106's Avatar
Drives: 2015 ZO6 3LZ Stage 2 A8
I'm having the same problem.... dont know why, but it just started for me since I've put in the ZR1 clutch.... Never had this problem till now...
kevin1106 is offline   Reply With Quote
Old 06-28-2011, 07:02 PM   #3
Pollock
LT1 M6
Pollock's Avatar
I did this and my clutch felt better. Might help you too.
http://www.rangeracceleration.com/Clutch_Care.html
I am interested to see what the dealer does to try to fix it.
Old 06-28-2011, 08:00 PM   #4
Jason@
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@ Send a message via MSN to Jason@
They just did this on my car last week... They claim that they actually moved the master cylinder BACK 1.0625, and then did a clutch pedal relearn. Not sure how this is possible, I've never looked at it. Also can't tell if it made a difference or not by itself because they also changed the flywheel, slave cyl, throw out bearing, pressure plate, and clutch at the same time....
They told me that particular TSB came out this month also.
Jason@ is offline   Reply With Quote
Old 06-29-2011, 01:14 AM   #5
Bigslick440
Drives: 2011 SS
does anyone have a tsb #? i'am also having this issue along with the 2nd gear grind. i really want to have my car fixed i'am getting tired of this.
Bigslick440 is offline   Reply With Quote
Old 06-29-2011, 12:12 PM   #6
Pollock
LT1 M6
Pollock's Avatar
Sorry I do not have the number in front of me. Maybe it is on my paper work.
So far the dealer told me my clutch is fine and they do not see any issues. And they say the clutch disappearing is a safety feature to prevent damage to the clutch. Sounds like BS to me. I am going to get a lingenfelter spring and work on my driving habits. Maybe I overheated the pressure plate.
Old 06-29-2011, 12:15 PM   #7
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
It's a band aid fix for the clutch actuator issue. Welcome to the crappy M6 transmission world....
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 06-29-2011, 12:16 PM   #8
Pollock
LT1 M6
Pollock's Avatar
What is the real fix you think? I would rather do it right the first time.
Old 06-29-2011, 12:24 PM   #9
MillerTime
MillerTime's Avatar
I had the same sticking issue. As is typical they said that they couldn't duplicate the problem and said to bring it back when I could. While driving home from the dealer on the freeway it stuck, so instead of re-applying the clutch I allowed it to stick and stick and stick... for about 5 miles. It soon overheated and the pedal went to the floor with a stream of smoke coming off of my car.
Had it towed in, and they replaced my clutch acuator cylinder, clutch plate, and replaced the fluid. Haven't had an issue with it sticking since. Now the grinding, and other transmission issues are popping back up again :(
2G1FS1EWXD9163847
Old 06-29-2011, 12:29 PM   #10
Pollock
LT1 M6
Pollock's Avatar
So is it the master cylinder or slave cylinder?
Old 06-29-2011, 12:48 PM   #11
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
I've had the same issue. Same response from My dealer. "Nothing wrong, acting normal". I'm just waiting to have mine go out completely then I'll have JDP Motorsports put in the LS9 dual disk clutch and flywheel
Old 06-29-2011, 01:28 PM   #12
MillerTime
MillerTime's Avatar
whichever cylinder directly links to the clutch actuator... but I'm not sure which one that is sorry man.
2G1FS1EWXD9163847
Old 06-29-2011, 02:16 PM   #13
Pollock
LT1 M6
Pollock's Avatar
I know what the clutch costs.. How much is labor to install?
ACT twin disk clutch install by Mike Norris Motorsports ducatisl V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 34 09-06-2016 08:38 PM
I want a new clutch, you too????? Sign here tjbusa V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 370 08-10-2013 04:27 AM
clutch sticking halfway fix? GQ4Life V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 10-13-2010 01:20 AM
deleted post Kubi V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 02-21-2010 06:35 PM
clutch sticking to floor BatmanX Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 11-21-2009 04:39 PM
