GM Parts House
Old 06-29-2011, 11:10 AM   #1
LarzII
Drives: 2010 Camaro 2SS/RS
Help please! Reverse lockout failing.
I have a 2010 2SS.
Suddenly last night, my reverse lockout stopped working. I was trying to shift into 5th and was unable to go into the gear, grinded, and then realize that I was actually attempting to shift into reverse at that point. This has never happened before, no warning signs, nothing. I only have 15,000 miles on the car and don't abuse it.
I did some research and found that it could be a computer glitch, so I disconnected the negative battery terminal for about 10 mins, and still nothing.
The car is still under warranty, but if there is a quick fix I can do myself rather than having my car stuck in the shop potentially for days, then that would be a big lifesaver.
Thanks.
LarzII is offline   Reply With Quote
Old 06-29-2011, 12:15 PM   #2
nancygrl
155 mil na godzinę
nancygrl's Avatar
Drives: '16 2SS,A8, NPP
Well....If it's the same as I had on my 97 Z28, the reverse lockout would be a solenoid. It's a quick fix, or at least it should be if its the same. I had to replace it in the Z, took longer to get the car up/down than it did to replace it. Since it's still under warranty, bring it in shouldn't take too long to fix.
'16 2SS A8, NPP
nancygrl is offline   Reply With Quote
Old 06-29-2011, 12:18 PM   #3
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
Have you tried seeing if it was a one time thing by gently shifting towards Revers while doing say 10 MPH or so? If it's still not blocking properly then take it in.
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 05-18-2016, 07:27 PM   #4
RichCamaro10
RichCamaro10's Avatar
I know this is old but any resolution on this? I'm having the same issue...
2010 Black Camaro 2SS
RichCamaro10 is offline   Reply With Quote
Old 05-18-2016, 08:39 PM   #5
RichSS2006
RichSS2006's Avatar
Drives: 2010 2SSRS
Rich, I had this happen to me last summer. I got under it and checked the wiring connected to the trans. Wiggled everything around and made sure it was all connected. Let it down off the jack and it worked. Must have been a loose wire/connector. Haven't had it happen again. Hope yours is that simple. Good Luck. Rich
No longer stock, but oooh so much more fun!
RichSS2006 is offline   Reply With Quote
Old 08-27-2016, 04:25 PM   #6
RichCamaro10
I finally got around to replacing the Reverse Lock-out solenoid on my car and when I got the old one off, there was transmission fluid coming out of the connecter on the back. I'm guessing that this had something to do with it it working intermittently.....
DIY: Cheap and EASY Reverse Camera Install (lots of pics) 13lade Camaro DIY & HOW-TO instructions & discussions 15 04-24-2016 01:34 PM
Camaro Reverse Lights... why do they stink? Answer and solution here. AACstyle Cosmetics and Lighting Modification Discussions 159 09-17-2013 07:24 PM
Trouble putting gear into Reverse! shadow09 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 6 12-28-2010 11:21 PM
Can not shift into reverse gear. HELP! Bryan 5th Gen Camaro SS LS LT General Discussions 16 07-25-2010 09:27 PM
Reverse lockout? (manual transmission) zq8colorado04 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 06-17-2009 09:37 PM
