Old 06-30-2011, 01:13 PM   #1
Kakashi
Drives: Camaro SS 2010 M6
Question TWS Nurburgring + Invos + Coilovers?
Well here's the thing, I wish to buy a set of TSW Nurburgring 20's with Nitto Invos.
So far I keep reading that this combo will work well on a stock car (ie. no rubbing, caliper clearing, no bulging past the fender).
TSW Nurburgring 20x9.0 (+20?+35?) and 20x10.0 (+35)
Nitto Invos Front 275/40/20
Nitto Invos Rear 315/35/20
However I keep reading of different offsets for the front wheels: +35 vs +20 on the 20x9. Which one would be better to avoid rubbing and avoid going past the fender line if I wish to go with a Rear & Front Swaybar plus Pedders or BC coilovers? (The reason I don't mention PFADT is because I read a few posts saying that they are "bigger than stock" and have clearance troubles with these wheels/tire combos, but if that is false please let me know! )
This is a daily driver, but I will take it to the track (solo 1) once in a while.
Kakashi is offline   Reply With Quote
Old 07-01-2011, 05:26 AM   #2
Kakashi
Btw, ignore the info on the side (forgot to update it) :( This is for a 2010 Camaro SS
Old 07-03-2011, 01:58 AM   #3
Kakashi
:( nobody has this combination that could share their opinion?
Old 07-03-2011, 02:03 AM   #4
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
I dont think you'll have any problem with that set up with some coil overs.
I think Erik from Torq is running 20x10 with 285 tires in the front with no rubbing. not a 100% on that tho.
But if it does rub you can always use a spacer.
Old 07-03-2011, 09:32 AM   #5
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Anything wider than a narrow 305 tire on those wheels will stick out on the rear. The 10.0 wheel is too narrow for the 315 tire, and the offset is too aggressive to tuck them under the car properly. Most of the members that run those wheels are using 295 or 305 rear tires if they want them to tuck and not rub.
Fquick.com/NineBall
Old 07-05-2011, 02:06 PM   #6
Speed Depot
Speed Depot's Avatar
Drives: 2010 Camaro
Send a message via AIM to Speed Depot
The best offsets to use are +20 front and +35 rear. They will give your a car a nice stance and you will have no rubbing issues.
Speed Depot is offline   Reply With Quote
Old 07-05-2011, 06:57 PM   #7
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Check out my post here.
http://www.camaro5.com/forums/showthread.php?t=135159
The tires fit, but are very bulged out.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 07-06-2011, 12:02 AM   #8
Kakashi
Thank you for the answers It means a lot. I love the pictures Avalnch!
Pedders Xa Coilovers and Springs | In stock | Free Shipping | Best Prices JDP Motorsports Suspension / Chassis / Brakes 115 02-16-2015 09:42 PM
Remote Reservoir Seperate Bound and Rebound Adjustable 5th Gen Coilovers JusticePete Suspension / Brakes / Chassis 144 12-07-2011 04:50 PM
pfadt and pedders coilovers bmbbl be Suspension / Brakes / Chassis 47 02-14-2011 05:50 PM
Pfadt Coilovers, special CAMARO5 member PRICING of $2099!! PfadtRacing Suspension / Chassis / Brakes 6 10-21-2010 11:47 AM
