Drives: Several Join Date: Nov 2009
Camaro MAF sensor tip for maximum tuning results!!!
There are several electronic and mechanical nuances that tuners will find when extracting the maximum performance out of L99/LS3 engines. One peculiar find was a variation in the Mass Air Flow (MAF) sensor. As it turns out, GM has been sourcing from (at least) two different suppliers. The difficulty is that while each of these meet the minimum requirements, one of the two has much better capabilities for tuning.
Think of a stereo amplifier and the term “headroom”. A better more expensive 50w amplifier will have more headroom than a cheapie 50W amp. This means the better unit can operate at its maximum output and still be able to handle the occasional spike over 50W without excessive distortion. The cheaper amp is already starting to distort near its peak, then completely clips any signal that is greater. In the case of the L99/LS3 MAF, one supplier has built a unit that has more “headroom”, while the other clips the higher signals -- the very ones we need to tune a higher output engine correctly! This means a good tuner using the better MAF sensor will get greater results – all other things being equal. This goes a long way to explain why some cars tune up better after bolt-ons than others. Fortunately, we have discovered a couple of differences to help tell them apart even though they are nearly identical. ![]() -- See! They look almost the same, but sensor “B” is the winner here. ![]() -- View from the connector (visible without removing). Look at the arrow style and the part number font. The part number with the rounder font and the arrow with rounded corners are the visible giveaways (B). ![]() -- View after removal. The key identifier is a tooling reference. You want one with a single letter and two numbers (Sensor B). It doesn’t seem to matter what the letters or numbers are, but just thjat there is 1 letter/2 number sequence (per every one we’ve tested so far). If you want maximum power and efficiency from your Camaro after adding headers, hi-flows, cat-back, cam, etc., make sure you have sensor B!!! If you don’t, head to your local dealer and go through their stock to find one ASAP! It will make all the difference in the world when optimizing the entire map for power, drivability and economy. P.S. Note: Those wondering about the performance effects of aftermarket upgrades to 2010 cars versus 2011, we have been seeing the 2011 cars pull a stock baseline of around 25-30 more HP (rear wheel hub dyno) than the '10s. We have seen no official power rating change from GM, but there is definitely a different and more aggressive factory tune on the later cars. The overal maximum horsepower with carefully selected add-ons is roughly the same regardless which car we have been testing with, but the later cars are starting at a higher base point. We might also point out that there is still a LOT to be gained from the factory maps (which seem to us to contain quite a few errors), but the latest Camaros are definitely being delivered with a little more grunt than before.
Chris Bernal
Brake Maven |
![]() ![]() Drives: 2010 Camaro 2SS/RS White S/C Join Date: Aug 2010
Wouldn't it be easier to replace the Camaro MAF for the Corvette MAF?
"It does not matter if you win or loose, what matters is if I win" Carl Fogarty ![]() |
![]() ![]() ![]() Drives: 2010 IBM Camaro SS Join Date: Jun 2007
I have a K18 MAF. Havent done a tune though, so probably nothing I'd notice one way or the other.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
SoCal C5 Family Member
Drives: jealous vendors mad!! HAHA!! Join Date: Jan 2011
Good information but I think this is old news and has been tackled long time ago.
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
Vararam users mainly know about this but it's good that it's been brought to light for everyone else.
She is only memory now. |
#7 |
Thank yoy for your time and effort as well as informative post!
#8 |
![]() Drives: 2010 Black 1SS Join Date: Aug 2009
I've got a K15... new font... round arrow..
It's a hybrid!
2010 Black 1SS LS3 M6
Power: Kook's 1 7/8" Long Tubes and 3" Exhaust, Injen Full Length CAI, Jannetty Tune Drivetrain: MGW Short Shifter, Street Slayer Twin Clutch, DSS 1 Piece Aluminum Driveshaft, DSS 1000HP Axles, BMR Pro and Delrin Diff Bushings Suspension: BMR Trailing Arms and Bushings, FE6 Swaybar Conversion With Pedders 27mm Front and 32mm Rear ZL1 Swaybars and Links Chassis: Hotchkis Chassis Max Brace, BMR Pro Cradle Bushings Exterior:: Shine by Adam's. ...and plenty more |
#9 |
![]() ![]() Drives: 2010 Camaro 2SS/RS - L99 - CGM Join Date: Apr 2010
Just ordered my "strong" sensor from Patrick @ GM Parts. I hope this works.... (I've been having issues tuning my car on the Vararam.)
2007 Corvette Z06 - Velocity Yellow
Halltech | Forgestar | Bilstein |
#10 |
![]() Drives: z28 Join Date: Jul 2011
So the only difference is head room?
#11 |
![]() Drives: 1999 500 HP Corvette Join Date: Jan 2010
That tip is not valid for most NA powertrains as no performance gains would come of using a higher MAF output to a PCM that only can compare to the lower max freq value in MAF table of PCM
If the MAF frequency tables in the PCM is looked at you find most GM newer cars like Camaro have a maximum value of 12,200 Hz ( NA engines) or 15,000 Hz for like boost, IE, new ZR1 If you look at a 2010 ZR1 at a drag strip recorded scanner data even at high boost the maximum MAF (air mass ) moved is about 9900 Hz. No where near the maximum ability of the MAF output or MAF PCM table In this case max airmass was about 75 lbs and about 1.4 grms/cyl Stock 2010 ZR1 at drag strip in 90 degree weather Code:
MAFLb MPH MAP BoostPSI MAFRQ MAFgrms grmcyc MapKpa 75 65 51 11 9720 569 1.389 173 75 65 51 11 9720 569 1.263 173 75 65 51 11 9720 569 1.263 173 75 65 51 11 9888 569 1.263 173 75 65 51 11 9888 569 1.263 173 70 88 47 9 9673 531 1.358 160 70 88 47 9 9673 531 1.281 160 70 88 47 9 9673 531 1.281 160 70 88 47 9 9768 531 1.281 160 70 88 47 9 9768 531 1.281 160 74 89 48 10 9673 558 1.392 162 74 89 48 10 9673 558 1.309 162 74 89 48 10 9673 558 1.309 162 74 89 48 10 9925 558 1.309 162 74 89 48 10 9925 558 1.309 162 74 92 48 10 9768 560 1.350 163 74 92 48 10 9768 560 1.257 163 74 92 48 10 9768 560 1.257 163 74 92 48 10 5298 560 1.257 163 74 92 48 10 5298 560 1.257 163 70 115 47 9 9626 531 1.343 160 70 115 47 9 9626 531 1.296 160 70 115 47 9 9626 531 1.296 160 70 115 47 9 9673 531 1.296 160 70 115 47 9 9673 531 1.296 160 71 117 48 10 9673 539 1.323 164 71 117 48 10 9673 539 1.294 164 71 117 48 10 9673 539 1.294 164 71 117 48 10 9720 539 1.294 164 71 117 48 10 9720 539 1.294 164 73 119 48 9 9673 550 1.341 161 73 119 48 9 9673 550 1.295 161 73 119 48 9 9673 550 1.295 161 73 119 48 9 9828 550 1.295 161 73 119 48 9 9828 550 1.295 161 71 121 49 10 9720 539 1.294 165 71 121 49 10 9720 539 1.262 165 71 121 49 10 9720 539 1.262 165 71 121 49 10 9876 539 1.262 165 71 121 49 10 9876 539 1.262 165 74 124 49 10 9876 560 1.310 166 74 124 49 10 9876 560 1.273 166 74 124 49 10 9876 560 1.273 166 74 124 49 10 9937 560 1.273 166 74 124 49 10 9937 560 1.273 166 maximum MAF output is about 8,700 Hz ( no where near the 12,000 HZ MAF limit) and less then 50 lbs airmass peak In neither case did 400 HP or 640 HP was limited by MAF and that is clear because you would rarely see anyone post having a DTC error of HIGH MAF value hit. 2010 LS3 Camaro Code:
MAF MPH MAFRQ MAFgrms grmcyc 47 75 8686 355 0.834 47 75 8686 355 0.781 47 75 8686 355 0.781 47 75 8247 355 0.781 47 75 8247 355 0.781 47 75 8247 355 0.781 47 74 8492 355 0.840 47 74 8492 355 0.786 47 74 8492 355 0.786 47 74 8438 355 0.786 47 74 8438 355 0.786 47 106 8492 355 0.816 47 106 8492 355 0.795 47 106 8492 355 0.795 47 106 8583 355 0.795 47 106 8583 355 0.795 46 57 3511 351 0.780 46 57 3511 351 0.923 46 57 3511 351 0.923 46 57 8230 351 0.923 46 57 8230 351 0.923 46 91 8602 351 0.963 46 91 8602 351 0.919 46 91 8602 351 0.919 46 91 8385 351 0.919 46 91 8385 351 0.919 46 70 8501 350 0.882 46 70 8501 350 0.821 46 70 8501 350 0.821 46 70 8686 350 0.821 46 70 8686 350 0.821 46 70 8359 350 0.950 46 70 8359 350 0.827 46 70 8359 350 0.827 46 70 8492 350 0.827 46 70 8492 350 0.827 46 94 8385 350 0.916 46 94 8385 350 0.880 46 94 8385 350 0.880 46 94 8547 350 0.880 46 94 8547 350 0.880 46 94 8547 350 0.880 46 100 8547 350 0.880 46 100 8547 350 0.831 46 100 8547 350 0.831 46 100 8359 350 0.831 46 100 8359 350 0.831 46 104 8359 344 0.818 46 104 8359 344 0.791 46 104 8359 344 0.791 46 104 8492 344 0.791 46 104 8492 344 0.791 45 90 8528 340 0.943 45 90 8528 340 0.903 45 90 8528 340 0.903 45 90 8565 340 0.903 45 90 8565 340 0.903 45 48 8429 339 0.920 45 48 8429 339 0.801 45 48 8429 339 0.801 45 48 8447 339 0.801 45 48 8447 339 0.801 45 65 8510 339 0.872 45 65 8510 339 0.855 45 65 8510 339 0.855 45 65 8501 339 0.855 As the elevation increases the airmass decreases and the same cars above that were at sealevel would require or use less airmass and see lower MAP. Being NA engines will never reach 12,200 Hz there would be zero reason or gain changing MAF and in fact the new MAF output would not match the MAF table such as if maximum MAF frequency your PCM is 12,000 Hz and the new MAF outputs 15,000 Hz the PCM would not understand any values above the 12,000 Hz and would require a PCM code segment from another PCM that did support 15,000 Hz |
#12 | |
Its what i was going to go into if not explained. That is headroom. Or the ceiling of the MAF function. These MAF's are pretty Bad ass compared to earlier lt/LS models. Now, is one sensor more sensitive/accurate than the other? |
#13 |
No as makes no difference how high the MAF output frequency is as explained as most NA engines never even get close to the existing stock MAF max output.
I was tuning a 2008 ZO6 yesterday with a CAM and even at 580 HP, up to 130 MPH the max output of MAF was only 8,800 Hz. Not only that the MAF table is broken down in freq blocks and do not understand freq up 12,200 or 15,000 Hz ( depending on car model) and lastly the PCM is not doing constant realtime updates from MAF, more about once every half second so would not care about max freq for NA engine as fuel trim adjustment are done not every few seconds but minutes. Lastly as mentioned the PCM hardware logic would limit how well or poor another design of a MAF's output is. |
#14 |
Here is a little more infomation about the differences in sensors and it's not all about headroom. http://www.vararam.com/camaro.html
| Tags |
| maf tune l99 ls3 power |
| Gran Turismo 5... No Camaro? | 5thGenOwner | 5th Gen Camaro SS LS LT General Discussions | 111 | 12-06-2011 11:06 AM |
| Modern Camaro Performance Parts - www.PartsTaxi.com | PartsTaxi.com | Sponsor Announcements / Giveaways / Contests | 0 | 10-06-2010 05:26 PM |
| Official Camaro Convertible CONCEPT Press Release | Tran | Camaro Convertible Forum | 12 | 11-18-2009 08:05 PM |
