Old 07-01-2011, 11:29 AM   #1
Pt_killa
Pt_killa's Avatar
Drives: Black 2010 Camaro V6
STS guys exhaust wrap???
Hey have any guys with a remote mount wrap their exhaust with exhaust wrap and use a turbo blanket to help spool times? I've read online that wrapping the exhuast is supposed to help tremendously with spool time but just wanted to see if anyone has done it on their camaro yet. I will spend this afternoon wrapping my exhaust so I'll post any differences I notice later tonight or this afternoon.
Pt_killa is offline   Reply With Quote
Old 07-03-2011, 11:25 AM   #2
Pt_killa
Pt_killa's Avatar
I managed to wrap the exhaust cat back and only the turbo side from the h-pipe back. I also wrapped the turbine housing on the turbo. Once warmed up the car spools about 500-1000 rpms faster at part throttle. At full throttle, the turbo starts to spool at the same rpm but I build full boost within 200rpm instead of having to build it over about 500-1000rpm. This mod seems like it was worth the $80 of wrap and coating and 2 hours of labor (couldve been faster if I wrapped with the exhaust off the car). I used 100ft of wrap.
Old 07-03-2011, 03:15 PM   #3
SIXJAK
SIXJAK's Avatar
Drives: MO's only SC'd LLT.
Very interesting.....had no idea that wrapping would make that much of a difference.
IPF supercharger kit, IPF tune, SW LT's, R. Tech HFC's, ARK DT-S catback, SS Brembo brake upgrade, BC Racing adjustable coilovers, Hurst STS, Pfadt rear arm package, Pfadt adjustable sways & end links, Pfadt diff bushings, BMR rear cradle full kit blk bezels,SS diffuser, Innovate gauges.
SIXJAK is offline   Reply With Quote
Old 07-05-2011, 09:01 AM   #4
Pt_killa
Pt_killa's Avatar
It's supposed to keep the heat in the exhaust and since the air is hotter the air velocity will be higher. More velocity, faster spool I think. Thats what I read anyways, but whatever the explanation is, wrapping the exhaust does increase spool.
Old 07-08-2011, 08:10 PM   #5
MyWorld
MyWorld's Avatar
Drives: RJT 2LT RS
This sounds really interesting, but that would be one hell of a wrap job. I was thinking about getting long tubes with a cat delete to reduce the time it tasks to spool. If I go that route, maybe I'll think about wrapping when I do that.
Sent from my DROIDX using Tapatalk
MyWorld is offline   Reply With Quote
Old 07-08-2011, 11:09 PM   #6
Pt_killa
Pt_killa's Avatar
Wrapping the exhaust would take less than an hour with the exhaust off the car. Since I only have a jack, most of my time was spent crawling under the car and dodging brown recluses. Even then it didn't take more than two hours to fully wrap and spray.
If you do get the longtubes, I've read that its recommended to wrap those with remote systems. Most people I read about lost spool when the only mod change was going from stock to longtubes (going catless might make up for the loss not sure ). It has something to due with slowing down the exhaust because of the design of longtubes I believe. However, some guys got their spool back after wrapping them while enjoying more hp. When you put the headers on take the rest of the exhaust off and wrap everything since part of the exhaust will be disconnected anyways. It should be really easy with everything off. Let me know how it goes if you do!
Old 07-11-2011, 06:07 PM   #7
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
The physics of this are impossible.
DietCoke is offline   Reply With Quote
Old 07-12-2011, 09:43 AM   #8
Pt_killa
Pt_killa's Avatar
Well I don't know what to say, my spool time decreased by that amount and the only mod was wrapping the exhaust and turbo . When I refer to part throttle it's from 25% to 75%. If the physics are impossible (Please explain why I would love to learn new info) maybe wrapping my exhaust did something else like partially covering an unknown exhaust leak or something?
Old 07-20-2011, 05:47 PM   #9
Wizzer
Drives: 2010 Cyber Grey
I never knock someone who has done the work. So I tend to lean towards you getting a performance gain. Answer his question... Why are the physics impossible?
Wizzer is offline   Reply With Quote
Old 07-22-2011, 08:34 AM   #10
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Because the amount of heat required to drop spool time by 1000rpm is insurmountable. It simply isnt possible.
Old 07-22-2011, 08:48 AM   #11
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
I would have to see the equations for this (he did say 500-1000 BTW). I know that there is quite a bit of difference between the head at the manifolds and the heat at the exhaust tips, so some hit is lost as it travels all the way back to where this turbo is sitting. It would be neat to figure out how much and what the loss would be.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 07-22-2011, 10:16 AM   #12
Pt_killa
Pt_killa's Avatar
It would be cool to do a test like that, would be interesting to see the results. I guess I should've done a more thorough report on my results to remove all of this subjectivity(ie do a 2nd, 3rd, and 4th gear pull individually before and after from low speed to see when it spools exactly). Next time I do any mods I will be sure to document better.
Old 07-28-2011, 01:17 PM   #13
Peter
Drives: 2010 Camaro
Something else that it could be is with wrapping the exhaust it might of lowered the harmonics, so the exhaust is vibrating less which is making the turbo more efficient with having slightly less vibrations on the housing of the turbo. So less random drag on the turbo shaft.
2010 JL Audio
Build Thread: http://www.camaro5.com/forums/showthread.php?t=139419
#280 MASTER MECP Certified
MECP - Sales, Basic and Advance Certified
ASE - 6 electrical certified
10+ years car audio installation, sales and manager
Peter is offline   Reply With Quote
Thinking about going 2.5" the entire System mike.nite Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 12 01-11-2011 04:57 PM
*/* Exhaust and Intake's */* Borla/Magnaflow/ Agency Power/ K&N/ AEM */* ImportImage V8 Bolt-Ons & Tunes 73 11-01-2010 11:21 PM
EXHAUST Milk 1027 Wiki 2 03-07-2010 10:20 PM
Heard exhaust of L99 tonight - OMG!!! Hylton 5th Gen Camaro SS LS LT General Discussions 60 03-06-2010 06:03 PM
New Billy Boat 2010 Camaro Exhaust Ragin Racin Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 10-20-2009 07:09 PM
