HeadlightArmor
Old 07-04-2011, 05:56 PM   #1
steeleshark2
steeleshark2's Avatar
Best Clutch for less then $800
Well, my main rear seal is leaking a bit and I found a dealership that said they would fix it under warranty even with my mods. I figured it wont cost any extra labor to change the clutch so for around 500-800 what would be the best bang for the buck. So far, I was looking at the SPEC stage 3, the Centerforce 12" or even Monster for a little more. Has anyone have these clutches on your car? If so, what do you think? My mods are in my sig and in the future may look at some Nos (no more then a 150 shot).
Old 07-04-2011, 11:41 PM   #2
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
Save you cash until you have a bit more and get a serious clutch, mine will cost at minimum 1500 as I'd rather pay the extra cash up front than to have it break (again) just to buy another one. Go for something that "exceeds" your expected TQ / HP capacity.
2010 Camaro SS, P1SC SuperCharged Livernois LSX429ci., 1 7/8" LT Headers, full 3" MBRP exhaust, SPI built/tuned, a total
calbert1999 is offline   Reply With Quote
Old 07-05-2011, 07:41 AM   #3
steeleshark2
I would but the transmission is coming off anyway so no extra charge in labor for the clutch install. I also do not think the stock clutch is going to last much longer.
Old 07-05-2011, 02:46 PM   #4
steeleshark2
Well, looks like it was not the rear main seal. I guess no clutch for now and will save my pennies to get a better clutch for when this one dies!!
Old 07-06-2011, 02:34 AM   #5
HRC
Drives: 2010 2SS
I've got a Monster stage 3 in mine and really like it. I had my factory throw out bearing/slave cylinder grenade at around 3500 miles. Read the other threads about this, it might be a good idea to replace it, and install the remote bleeder. Regular fluid changes to the slave seems to be helping many who have been fighting this issue?
HRC is offline   Reply With Quote
Old 07-06-2011, 08:16 AM   #6
steeleshark2
Great info, thanks!!
Old 07-06-2011, 04:58 PM   #7
Chris@SPMC
Drives: '99 H/C FRC Corvette and '07 TBSS
Honestly a Level 2 would hold your power as our clutches are rated at the rear wheels, you could combine it with a lightweight flywheel to free up a little more power. Feel free to call me with any questions, thanks.
Chris@SPMC is offline   Reply With Quote
Old 07-06-2011, 05:46 PM   #8
steeleshark2
Thanks Chris! I was actually looking at the Level 3 or 4 for a little more. I may get NOS in the future. But found out the leak was not the rear seal so I am going to stick with the stock clutch until I kill it. Then I think you will get a call from me!!
Old 07-07-2011, 11:24 AM   #9
Chris@SPMC
Sounds good, let me know whenever you're ready and I'll get you taken care of.
Old 07-09-2011, 11:46 AM   #10
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
1) I have a 2000 Corvette with 451 RWHP and 430 RWTQ. I have harden output shafts, 3.90 gears, tranny brace. Id like to take it to the track, but havent yet just to see what I can run. I drive it maybe 100-200 miles a month, but I do drive spirted.
LS7 Clutch lasted me a couple months before it started to stick to the floor. I currently have the textrila 0z700 which grabs great, but has chattered since day one and I hate that.
What level clutch do you recommend?
2) If by chance this engine fails, and I add an additional 100 RWHP to the above, what level do you recommend.
Tampa Tuning is offline   Reply With Quote
Old 07-13-2011, 11:14 AM   #11
Chris@SPMC
At your current power level I'd recommend a Level 2, but if you're serious about increasing another 100hp then I'd have to say Level 3.
ZR1 Clutch at the Track JM10 Dragstrip and Launch Techniques Discussion 19 02-16-2011 12:02 AM
Camaro 2010 Issues Tim's.2010.Camaro.SS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 57 06-04-2010 10:27 AM
Clutch "Sticking" Issue - Not Clutch Dust - Not Boiling Fluid Embalmer Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 09-11-2009 10:52 AM
