Old 03-16-2009, 11:37 PM   #1
Camarofan123
Drives: None
Mid to High 11's in Camaro
What would be needed to hit mid to high 11's on a new camaro do you suppose?
For a comparison, a stock GT500(3900 vs 3860 camaro auto) with similar weight to the camaro on DR's runs low 12's with 500HP.
I am not trying to always talk about mustangs, but as of now, specs on them is all I know.
Camarofan123 is offline   Reply With Quote
Old 03-17-2009, 12:04 AM   #2
JMAN311
JMAN311's Avatar
Drives: 2013 F-150 Limited
I'm sure at the very least you would need a full exhaust system, CAI, cam and a good tune. Not sure if you would have to go as far as replacing the heads or not. At the altitudes at the tracks where I've been you probably would, but if you are around sea level
There just might be a 2016 Camaro or Corvette in my future...
Previous Chevy's
2013 Camaro ZL1 A6|SIM
2010 Camaro 2SS/RS|M6|CGM Exterior|Gray Int
2000 Camaro SS|M6|SLP headers|SLP center mounted quad exhaust|Magnaflow muffler|Hypertech programmed
2001 Corvette|M6|LG Motorsports Headers|Corsa Touring Cat-back|Magnaflow X Pipe|Hurst short-throw|Dyno tuned
JMAN311 is offline   Reply With Quote
Old 03-17-2009, 12:14 AM   #3
Camarofan123
Drives: None
Meh I think the camaro is around 12.8 stock, 12.6 with bolt ons, and low 12's after adding longtubes and cams.
Old 03-17-2009, 12:21 AM   #4
JMAN311
JMAN311's Avatar
12.9 for the stock SS according to GM....but we'll see later in the week when the media gets to release more info about their testing...I'm guessing they might get it a bit faster.
Previous Chevy's
Old 03-17-2009, 01:04 AM   #5
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Long tube header, full exhaust system, cam and ported head and cut to 11.5 to 1 compression,Tune ported T/B and intake, and a good set of slicks.11.6-11.8 E.T.
Old 03-17-2009, 01:36 AM   #6
Camarofan123
Drives: None
I say mid 11's fully modded(CAI,Tune,Manifold,Cams,Heads) engine and exhaust wise. But a stroker would run quicker, maybe low 11's with weight loss?
Your talking 550+ HP so that is POWER.
Old 03-17-2009, 02:53 AM   #7
Hoss
Hoss's Avatar
Drives: 2004GMC Extended Cab
Would this ever be considered a daily driver.....
Hoss is offline   Reply With Quote
Old 03-17-2009, 10:17 AM   #8
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
depends on what you can put up with (and afford to put gas in)
Old 03-17-2009, 11:57 AM   #9
UsedTaHaveA68
UsedTaHaveA68's Avatar
Drives: Hyundai Sonata
Full exhaust, CAI, and a good tune with slicks I bet you could hit 11's. It's already trapping at 111mph. If you could get that up to around 115, get good traction, you're definitely there. Drag Radials may even get you there.
Good luck finding a set of wheels/slicks to fit over those 14.4" Brembos though.
UsedTaHaveA68 is offline   Reply With Quote
Old 03-17-2009, 12:30 PM   #10
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
I say slap on a blower and call it a day .. very streetable and very fast .. Now put some internals in the engine and crank it up ... still very streetable and that much faster
Crowley
Crowley is offline   Reply With Quote
Old 03-17-2009, 12:32 PM   #11
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
slicks and spray
I piss excellence
and fart awesomeness
Old 03-17-2009, 03:00 PM   #12
SS 376
SS 376's Avatar
Drives: IBM 1SS
Gears will make a big difference. All this is just speculation though.
SS 376 is offline   Reply With Quote
Old 03-17-2009, 03:56 PM   #13
Camarofan123
Drives: None
Wouldn't it need cams too?
I think 11's with just bolt ons and exhaust on DR's with weight reduction.
Old 03-17-2009, 05:40 PM   #14
CamaroSpike23
Truth Enforcer
it'll do 11s with bolt ons. hell, other camaros have gone faster with less power... (and less weight...lol)
I piss excellence
Camaro Laws ChevyNut Off-topic Discussions 107 11-09-2016 06:40 PM
2010 Camaro SS not affected by closing of GM's High Performance Vehicle Operations Tran 5th Gen Camaro SS LS LT General Discussions 62 02-27-2009 11:18 AM
Car and Driver drives V6 Camaro! Xanthos 5th Gen Camaro SS LS LT General Discussions 63 08-26-2008 10:21 PM
