HeadlightArmor
Old 07-09-2011, 10:04 PM   #15
ayceman
Drives: 2007 Dodge Charger SXT, 2010 2SS
Great write up one of the best I have ever seen, let me say that due to price I was going to go with Energy Suspension, even with your first post where you stated having issues. But after seeing this and how Pedders is more firm I will be going with them in the near future, your post has sold me on these.
ayceman is offline   Reply With Quote
Old 07-09-2011, 11:24 PM   #16
caverman
caverman's Avatar
Drives: '69 SS Convertible
Price is why I went with ES originally as well but in this case it's worth spending the extra money for Pedders IMO. Get the Stage 1 Street kit so you can do the radius rod inserts as well. That will save you a little money and it's a great addition to the car. You won't be disappointed.
Build Journal
Old 07-10-2011, 01:45 AM   #17
DMSDesign
Suspension Specialist
Drives: 2011 Camaro
With respect to suspension, your experience definately shows that you do get what you pay for
mike
dms
DMSDesign is offline   Reply With Quote
Old 07-10-2011, 02:09 AM   #18
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Crap. I missed this.
Now you see how easy it was for us that did the Pedders stuff. I had a problem with the rear alignment pins too. Had to put sockets under the front cradle mounts to lift the rear in a level manner.
Well done. Hope you enjoy it.
Old 07-10-2011, 09:20 AM   #19
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
mike
dms
+1
Bruce@raymondsperformance is offline   Reply With Quote
Old 07-11-2011, 02:26 PM   #20
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Those rear alignment pins can bind metal to metal. They fit inside the OE bush ferule and not directly into the bush material. That means you can lube it a little bit. A smear of Pedders molybdenum lube or just a squirt of WD-40 works wonders. Just a bit allows it to slip into place.
Old 07-19-2011, 01:33 PM   #21
JusticePete
VIR Specialist
caverman,
It has been a few weeks since your install. Has your opinion or experience changed in any way?
Old 07-19-2011, 02:33 PM   #22
PQ
Booooosted.
PQ's Avatar
Well, I got carried away and lubed the CRAP out of ALL of them. THEN found out I maybe shouldn't have.
Old 07-19-2011, 03:41 PM   #23
caverman
caverman's Avatar
caverman,
Nope...opinion is still the same. They are working out great. Ride is nice and firm and I would definatley recommend Pedders over the other brand/style.
I still haven't had a chance to make it to the track and really put them to the true test. It's been extremely hot around hear lately. Last week I had to pick up my Yukon from the paint shop and in the driveway the temp guage was showing 108. Not sure if that was completley accurate but it sure has felt every bit that hot lately.
Build Journal
Old 07-22-2011, 11:16 AM   #24
JusticePete
VIR Specialist
Caverman, thank you for the update.
Old 07-29-2011, 12:41 PM   #25
JusticePete
VIR Specialist
Bump for Blacktip.
Old 07-29-2011, 12:48 PM   #26
JusticePete
VIR Specialist
I use an air chisel with a rounded tip to vibrate off the lower sub-frame cover plates. Here is the short version.
The longer version is in the middle of this West Coast Customs video clip.
Old 08-18-2011, 10:46 AM   #27
JusticePete
VIR Specialist
Lots of EP1200 incoming questions. I wish this thread was a sticky. Great Post and Thanks Again.
Would you mind if I copied over to our customer support section?
Old 08-18-2011, 03:51 PM   #28
caverman
caverman's Avatar
If you're asking me I'm good with you doing whatever you want with it.
Build Journal
Hotchkis versus Pfadt Sway Bars Avalnch Suspension / Brakes / Chassis 77 10-08-2010 11:37 AM
Newest Camaro Ugrade at a Seriously Knowledgable Pedders Suspension Export in Mt. Vie Info@PeddersUSA.com Suspension / Brakes / Chassis 8 04-22-2010 12:15 AM
Major Pedders Event in Houston! Saturday, Jan 30th! Meet DMS Info@PeddersUSA.com USA - Texas 9 01-11-2010 06:55 PM
Pedders suspension already for the Camaro Info@PeddersUSA.com Suspension / Brakes / Chassis 75 10-21-2009 08:25 PM
Pedderizing the Nickey Camaro! Pedders coilovers / suspension fitted & tested. DallasMike Wheels and Tires Talk Sponsored by The Tire Rack 57 06-15-2009 05:36 PM
